Budget friendly tubular wheels
Sensible shoes.
Bikes: A few.
Seems to be slim pickings, if any. I'd like a set of tubular wheels for road and CX use, but I can't afford to play in the big leagues (go ahead P-Cad, rub it in). My desires:
Sub 1600g/set range
sub $500 range
No carbon (should be obvious already)
Good quality suitable for 220lb (100Kg) rider.
Campy compatible
So far we're talking handbuilt Record hubs/Reflex rims. Nice, but are there other options I'm missing? Post 'em up! Or tell me how silly my idea is. Really it's slow here.
Sub 1600g/set range
sub $500 range
Campy compatible
I think you've got it. Go 36 spokes for 220lb rider/cyclocross, 3x, brass nipples... I know it's kind of boring, but those will be really nice wheels.
Question, though, are you going to change tires for road and cyclocross? That'd be a pain. You could probably get some used hubs, or re-use hubs you have, and build two pairs of wheels for around 500 dollars.
Sensible shoes.
Bikes: A few.
I think your only options are for handbuilts in that price range. This seems like an ideal solution considering that your wheels will likely need semi-regular maintenance at your weight + CX usage. You should consider contacting Mike Garcia to spec out some different products as well. You could use DT Swiss's spoke calculator (dtswiss.com) to spec out weight on different builds.
Originally Posted by CastIron
Shameless bump.
pan y agua
Quoted: 1441 Post(s)
Liked 709 Times
there is no such thing when you consider the cost of the tires.
Sensible shoes.
Bikes: A few.
Thanx 14. I'd prefer to start fresh, though. Merlin the tires aren't horribly more expensive than good clinchers, unless I get silly with Dugast or the like. It is one more thing to keep shod, though.
Quoted: 3009 Post(s)
Liked 3,785 Times
If you don't mind used and since most people don't care for tubulars, their price drops more than half after a 100 miles on ebay.
Bikes: Dawes Kalahari, Puch Prima Super Sport, Graham Weigh 853
Cane Creek do a tubular Volos. I'd probably go handbuilt though. Not sure about Record hubs. Sounds a bit nice for Cyclocross, especially with the new Mirage hubs being so cheap!
Bikes: Custom Custom Custom
I'd say go with record hubs with mavic reflex or velocity escape rims. Yeah you could go with cheaper hubs in the campy line (centaur, veloce, mirage, no chorus in 2007) but they all used sealed bearings. I would much rather have cup/cone. This is of course for the 2007 line. Pre-2007, go for chorus or centaur hubs.
Sensible shoes.
Bikes: A few.
It seems settled then. Handbuilts. I've a shop to lace 'em and would certainly pursue Record hubs. Now all I have to do is get the matter past the Mistress of Finance.
chorus hubs, super comp spokes, and ambroso f20 rims. rims weigh 320 grams, and are tough as nails, it was probably the most widely used rim at paris roubaix.
https://www.starbike.com/php/catalogu...turer=Ambrosio
done, actuatly I'm lacing up this exact set for cross wheels.
Those ambrosia rims are pricey, but I'm getting tingly thinking about the climbing wheels I could build with them.
1241 grams without skewers on DT Swiss hubs and revolution spikes. Race ready for under $500
Burning Matches.
Quoted: 4077 Post(s)
Liked 1,002 Times
Out of shear curiousity, why tubular only? There's plenty of clinchers in that weight/price range.
ElJamoquio didn't hate the world, per se; he was just constantly disappointed by humanity.
Sensible shoes.
Bikes: A few.
First, these would be racing wheels for CX (where tubies are still king), but with proper road tires could also be for road racing as well.
Second, why not?
Now Racer Ex
https://www.cyclingnews.com/photos/20...bHosteRidley07
I rode on the 32h Crono's for several years laced to AC hubs and Sapaim XRay spokes, and while they are light, they aren't very tough and went out of true on a regular basis. The also flat spotted, after my second pair I changed over to Mavic Reflex, I would have done the Nemesis but I got a deal. I hope you have better luck.
I wouldn't even think about the Crono's if I was 220.
Another rim option for the OP would be the FIR ST 120. It's in between the Crono and some of the other rims mentioned here in weight, and a bit stronger.
And there's always Ebay:
https://cgi.ebay.com/Bontrager-Race-X...QQcmdZViewItem
64 49' N
Originally Posted by Vinokurtov
Have to disagree. The Ambrosio rims they used at Paris Roubaix were almost all the heavier Nemesis, not the Crono.
