Garmin 705 Mount
Garmin 705 Mount
I have a Garmin Edge 705 and today I broke my 4th mount while taking the unit off the bike after today's ride. I'd like to be ale to convert the current mounting system to the newer 1/4 turn mounts of the newer 800 and 810. Does anyone know if there is an adapter that is for sale that would allow me to do that? I currently mount mind on the stem and that is just fine with me.
Thanks
Thanks
Thanks
Thanks
I too have mine mounted on the stem. The only other option is to bar mount. I would be thrilled if someone made a quick release mount for the 705's.
It is a quick release mount but as you know you have to push down on the release lever and that is the part that broke.
Yes, the mount is quick release with the Garmin but the ( base ) mount itself is attached to the bike via plastic ties. To remove you have to cut the ties and use new ones if you wish to reuse the mount.
Quoted: 14 Post(s)
Liked 13 Times
I've been using a 705 for 4 years now (on several bikes and a motorcycle) and am a bit puzzled that the mount broke at all, much less 4 times.
Funny, but I know of many who have had issues with the 500-800 twist-in mount, usually breaking the ears on the device, but never breaking a 705 mount.
Bikes: Bacchetta Giro, Strada
In case it's not clear where it breaks --
... there's two mounts on the left side of the picture, and the small clip that extends below the top one and to the right of the bottom one is what breaks. It breaks when you push it down to release the GPS.
If you leave your GPS on the bike, it'll never break. But if you remove it all the time, it's probably going to break.
I don't know of a solution, beyond buying several at once. I wonder if that flaw is part of what lead Garmin to change the mount for the newer models?
I guess you could break the tab off entirely, and come up with something else to hold the GPS on once it's mounted, but that doesn't sound like a very practical solution.
Quoted: 14 Post(s)
Liked 13 Times
Mine has broken several times as well.
Bikes: Scott Spark 30, Scott Sportster 10,Chesini X-Uno, Miyata Century, Cannondale SuperSix
Quoted: 16 Post(s)
My 705 came with two mounts. One has the "Garmin" text and arrow, the other doesn't.
I have also bought some extra - official Garmin - mounts and not all of them are marked.
don't try this at home.
Quoted: 972 Post(s)
Liked 509 Times
I've done at least 400 rides since I got my 705 in the fall of 2010, and the mount is still good. Even the little tab sticking up that locks the 705 on the mount looks like new. I remove it on almost every ride, and often took it off again when I put the bike on my old bike rack.
I only have to use very light pressure and push the release lever down about a millimeter to release the Garmin. I put a little sideways force on the 705 and I can feel when the tab releases.
My mount looks like the one Looigi posted:
It has a textured surface, not smooth like your photos. The base of the tab arm has no discolored, warped look like plastic gets when it's about to break off. Maybe they've changed the mounts in the last few years?
Maybe we're being rougher on the tab than is needed, but I'm just pointing out that the problem isn't that rare. Though I am surprised to hear that many people don't seem to have the problem at all.
I lost my beloved 705 on a downhill because the mount broke. I retraced my steps and searched for an hour but never found my 705. The new design is far superior.
Quoted: 14 Post(s)
Liked 13 Times
I had my 705 fall off twice, but both times was able to find/retrieve it. It was not due to the mount breaking, but due to the tab dissengaging the recess in the bottom of the unit. I since bend the tab upward a bit to improve the engagement and haven't lost one since (mtbing and road). Despite bending the tab, they haven't broken. The material of the mounts I have is pretty tough and not at all brittle.
