Can not fit speedo drive unit on wheel.....
Old 06-06-20, 02:13 PM
interceptor
not revenge...punishment
interceptor's Avatar
Quoted: 40 Post(s)
Liked 21 Times in 12 Posts
Have a '70 Raleigh Sports with original wheel, can not get speedometer drive unit to fit front wheel.
Can not get fork spread to fit unit!
interceptor is offline
Old 06-06-20, 02:20 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
May be incompatible tru again on a beach cruiser.. Pegging @ 60kph, in your dreams..
fietsbob is offline
Old 06-06-20, 02:48 PM
interceptor
Quoted: 40 Post(s)
Forks not spreading at all to fit unit.........looking for pics to see if I can find Raleigh with this speedometer.....
PIC OF DRIVE UNIT IN SPOKES IS JUST SHOWING WHAT I HAVE!!!
I know how to install but unit is too tight.......I believe I had this type of unit on a Raleigh wheel before!
Old 06-06-20, 05:40 PM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
You might have to pry the Raleigh axle loose from its moorings in the fork tips. I know that when I've worked on them (had three Sportses and am now down to two) it seems like they sometimes hang up on removal. Approach from the front and remove the axle nuts, then invert your hands and wrap your fingers around the lower parts of the fork blades at the curve with your thumbs on the axle ends and see if you can pry things loose. Might need the proverbial Bigger Hammer or a pry bar. It'll come out.
Adding that speedo drive will make things even tighter when you put it back together, so get your best words ready.
thumpism is offline
Old 06-06-20, 06:02 PM
alcjphil
alcjphil's Avatar
Quoted: 1821 Post(s)
Liked 1,697 Times in 977 Posts
Where is the speedometer cable? Won't work without it
alcjphil is online now
Old 06-06-20, 06:06 PM
interceptor
Quoted: 40 Post(s)
Yea, very hard to remove wheel. Hoping I never get a flat on a hot miserable day!!! Would be using EXTREME words and would
probably go into crazy mode and destroy the bike!! I might just not use the speedo and save my sanity by leaving the wheel alone.
Thanks!
Old 06-06-20, 08:24 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2747 Post(s)
Liked 3,401 Times in 2,058 Posts
See front hubs
https://www.sheldonbrown.com/english-3.html
dedhed is offline
Old 06-06-20, 08:46 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4212 Post(s)
Liked 3,883 Times in 2,318 Posts
Those Raleigh ft hubs and drop outs have a less common design which make mounting this type of spedo drive problematic.
First is that the cones butt right up against the drop out inner face with no locknuts, the outer axle nuts do double duty as both wheel securing and bearing cone lock nuts. Knowing this will avoid crushed or loose bearings in the future. Do your homework here.
Second is that without a cone locknut each time the ft wheel is removed the spedo drive unit will come loose. The "right" way to install this is between a cone and a locknut, trapping the drive unit in place (and the cable is unscrewed from the drive unit when the wheel is removed).
Third is that the fork blade end often will contact the drive unit and cause it to cock and not spin with minimal friction. Over time this will wear the soft metal that these low cost units are made of.
The last thing has nothing to do with the mounting but that these spedos are never spot on. Or even close. I had a few when I was a kid, back in the late 1960s. There's a hill near where I grew up that my Stewart Wagner 26" spedo would register near 50mph as I descended on my Huffy Mk10 (26x1 3/8" tires). Years later with a SKY tire drive spedo I "saw" about 35mph at full tilt. Being stronger and on a bike with 27x 1 1/4 tires anyone would have thought even more speed was to be expected. later with my earlier electronic "computers" which had a tire circumference setting ability I saw closer to 30mph typically. I was even stronger, heavier and by then riding sew ups. Andy (who still goes that fast in his dreams)
AndrewRStewart
Andrew R Stewart is offline
Old 06-06-20, 09:46 PM
interceptor
Quoted: 40 Post(s)
OK, thanks for the info.....it's a no for this speedo!
Old 06-06-20, 10:04 PM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1152 Post(s)
Liked 341 Times in 251 Posts
I have this mental picture of you on the sofa, asleep, with your legs peddling.
I remember seeing dogs lying asleep and then seeing their little paws zooming around as they chased the squirrel in there sleep. I guess we can be happy for dreams: I still scream on my (now gone) Paramount in MY dreams. You zip on your bike in your dreams. And the dogs - the dogs catch the squirrel I guess. But only in dreams. Sigh.
WizardOfBoz is offline
Old 06-07-20, 07:01 AM
Andrew R Stewart
My feet cramp up when I sleep, others might see this as me dreaming of riding. I see it as old age. Andy
AndrewRStewart
Old 06-07-20, 07:25 AM
bldegle2
Dangerous Old Man
Bikes: 2 custom built full Carbon road bikes, built by Moi...
Quoted: 28 Post(s)
Liked 12 Times in 10 Posts
Or, for less than $7 (hint, I bought one on a lark) you can get this...works great. A little modern with the old...does the same as my uber expensive older Cateye wireless on my other bike.
https://www.ebay.com/itm/1-100PCS-IP...72.m2749.l2649
bldegle2 is offline
