Rear disc/sprocket clearance with Syntace dropouts
I've been working on new frame design in RattleCad, and for the life of me I can't get proper clearances for either the 140mm rotor, the 11t sprocket, or both when playing with the chainstays. For the record I want to use Syntace dropouts which means the CS offset to the dropout is minimal. I can get it to work if I use a Paragon DR2085, but I don't want to use that for this design. I've used various Columbus and Dedacciai S Bend stays and straight stays and moved them forward and back and still can't get the clearances I need.
What is everyone else doing for the Syntace dropouts? What could I be missing?
Thanks in advance.
Brandon
Thanks in advance.
Brandon
Looks like I may have figured it out with the some help from the FB page. Still learning the ins and outs of RattleCad and the various disc brake options available.
