Go Back  Bike Forums > Bike Forums > Framebuilders
Converting French BB to English
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Old 10-25-09, 06:51 PM
calikid2006
Is there a good way to convert a french BB to english?
Will running my english tap through to the trick, or should I fill with brass and cut new threads?
calikid2006 is offline
Old 10-25-09, 10:45 PM
unterhausen
Randomhead
Liked 3,684 Times in 2,508 Posts
I think you'll end up with a mess on the fixed cup side since french is right hand thread and english is left hand thread. I don't know if brass will be a lasting solution. If the french threads are in good shape, I'd figure out a way to use a crank that can utilize one of the many french bottom brackets available.
unterhausen is offline
Old 10-25-09, 10:49 PM
Sixty Fiver
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 67 Post(s)
Liked 129 Times in 96 Posts
There are not many options for French bottom brackets (unless you have a deep parts bin) and the most economical and sound solution would be to buy a French threaded cartridge from velo orange.
You can retap Raleigh threaded bb's to standard and usually have things work well because the threading is the same as to right and left but French bb's are right and right like Italian bottom brackets (which are 2 mm larger in diameter).
Sixty Fiver is offline
Old 10-25-09, 10:50 PM
Sixty Fiver
Quoted: 67 Post(s)
There is also the Phil Wood solution but that is very pricey.
Old 10-26-09, 05:44 AM
tuz
Bikes: Eight homemade, three very dusty
Quoted: 10 Post(s)
Liked 12 Times in 7 Posts
BSC diameter is 1.37"=34.8mm so 0.1mm smaller in radius than French (35mm). So on top of the cross LH vs RH thread on the drive side, you'll have a bit less material to dig in. As far as I know it is not recommended, but I've heard many people doing it. If it is a long lasting solution I don't know.
tuz is offline
Old 10-26-09, 08:55 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,393 Times in 1,927 Posts
If you fill with brass the new threads should be fine. I'm assuming the frame is unpainted?
Why do you need to change the threading?
JohnDThompson is online now
Old 10-26-09, 08:59 AM
unterhausen
Randomhead
There is one alternative solution, which is to find some Italian taps and get the Italian to English conversion sleeves that Ceeway sells. I've never tried this, seems like it would work fine. Since Italian is nearly obsolete, it might be worth getting some taps and a supply of the sleeves for doing repairs. Back in the day, tapping a stripped bb to Italian was a very common repair.
Old 11-14-09, 09:12 PM
hrtmnstrfr
Bikes: Kona Jake the Snake, Surly Cross Check
Velo orange now sells French bb's for about $30.
hrtmnstrfr is offline
Old 11-16-09, 07:25 PM
calikid2006
Thanks for the input guys.
I put some brass in and ran the taps though. Worked great.
Old 11-25-19, 12:51 AM
gnyatko
Tapping a French bb to English thread
hiw did you add brass? Did you mean by melting with a torch like mapp gas or so you need more heat or what did you do?
gnyatko is offline
Old 11-25-19, 04:32 PM
unterhausen
Randomhead
His last post was in 2016, so it's not likely that he will see your question. I am pretty sure he means he flowed brass in there with a torch
Old 11-25-19, 04:48 PM
JohnDThompson
Old fart
You'd need at least a fuel/oxygen flame to get hot enough to effectively melt brass into something with the mass of a bottom bracket shell. If it were my bike, I'd either go with the threadless cartridge (the easiest path), or ream and tap the shell for Italian threads. Either approach would leave the paint intact as well.
