Addiction LXXVIII
Addiction LXXVIII
Old 05-28-20, 08:28 AM
  #7526
Bah Humbug
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times in 2,026 Posts
Originally Posted by LAJ
Crikey. If I didn't have 10 sets of rim brake rims.....
https://www.excelsports.com/main.asp...ajor=1&minor=1
Not as tempting as that R5Disc, honestly.
Bah Humbug is offline
Old 05-28-20, 08:29 AM
  #7527
mvnsnd
mvnsnd's Avatar
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times in 78 Posts
Too bad it's so ugly.....
However, for a similar cost, I'd much rather have one of these: Factor O2 Disc or Rim
Hopefully they'll carry it soon.
mvnsnd is offline
Old 05-28-20, 08:45 AM
  #7528
WhyFi
WhyFi's Avatar
Quoted: 20810 Post(s)
After growing tired of my girl fawning over Paw Patrol and Daniel Tiger, I got her hooked on a great, "new" show - Reading Rainbow.
She totally loves it and I feel better about plopping her in front of RR and LeVar when I need a little time to take care of something.
WhyFi is offline
Old 05-28-20, 09:13 AM
  #7529
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 12768 Post(s)
Liked 7,682 Times in 4,077 Posts
Originally Posted by abshipp
The way I understand it is that the shape and size of the tubes that make up the instrument are sized in order to facilitate resonance of the air at certain frequencies. The instrument is at atmospheric pressure on the inside, and the only real airflow that moves through is a byproduct of the moving air required to create the initial vibration with your lips. The valves just change the length of the tube that the sound waves travel through, with each valve combination tuned to resonate at a specific frequency. Most brass instruments I've tried are quite free-blowing, there is some resistance but not a whole lot. The smaller the ID of the tubes, the more resistance there is. Try blowing through a straw vs blowing through a paper towel tube.
I have played both trumpet and tuba. The tuba does require a bit more airflow, but that just seems to be a necessary consequence of the amount of air it takes to vibrate your lips at frequencies that the tuba is designed to resonate at. If you want to try a silly experiment, try to buzz your lips at a high frequency and then at a very low and floppy frequency. I think you'll find that the latter will exhaust your lungs a lot faster than the former.
TL;DR - You just make the air inside the horn vibrate from buzzing your lips, any air movement through the horn is a necessary byproduct of that.
I've played trumpet, trombone, and didgeridoo. Never could figure out the didgeridoo. I damn near passed out trying to figure out all 3. I remember trying to emulate The Dizz on the brass, but that didn't seem to help.
LesterOfPuppets is offline
Likes For LesterOfPuppets:
Old 05-28-20, 09:15 AM
  #7530
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
Sell off 8 of those rim brake wheelsets, and you'll have the money(and space) for that frameset.
noodle soup is offline
  #7531
LesterOfPuppets
Bikes: everywhere
I was a little old for Reading Rainbow, but I'd still watch it everyday after highschool, mainly waiting for Bob Ross to come on though.
Old 05-28-20, 09:20 AM
  #7532
datlas
Should Be More Popular
datlas's Avatar
Quoted: 22596 Post(s)
Liked 8,925 Times in 4,158 Posts
You can get it for a fraction of that price from the same factory off a certain website...
Originally Posted by rjones28
Addiction is all about class.
datlas is offline
Old 05-28-20, 09:33 AM
  #7533
big john
big john's Avatar
Quoted: 8279 Post(s)
Liked 9,033 Times in 4,471 Posts
meh
big john is online now
Old 05-28-20, 09:37 AM
  #7534
abshipp
abshipp's Avatar
Quoted: 3359 Post(s)
Liked 3,638 Times in 1,244 Posts
emulate The Dizz
That technique was drilled into us in school as absolutely verboten, but I did try it once anyways. It hurt.
abshipp is offline
Old 05-28-20, 09:41 AM
  #7535
LAJ
So it is
LAJ's Avatar
Quoted: 11401 Post(s)
Liked 4,753 Times in 2,766 Posts
My buddy has a Dogma, and it really seems to just go. I haven't ridden the R5, but a teammate has the Factor. I liked the ride of the Dogma, but that was only a 15-20 minute ride, on each of them.
LAJ is offline
  #7536
LAJ
So it is
LAJ's Avatar
And some bikes... That's hard to do.
LAJ is offline
Old 05-28-20, 09:42 AM
  #7537
bampilot06
Quoted: 10236 Post(s)
Liked 5,183 Times in 2,225 Posts
Where did you find the show? Mine is hooked on sesame, daniel and all things disney.
bampilot06 is offline
Old 05-28-20, 09:46 AM
  #7538
WhyFi
WhyFi's Avatar
I used to put the girl in front of Bob Ross when I wanted her to nap.
WhyFi is offline
Likes For WhyFi:
Old 05-28-20, 09:48 AM
  #7539
WhyFi
WhyFi's Avatar
It's out there - iTunes, Amazon, the seedy underbelly of the 'net, etc.
WhyFi is offline
Old 05-28-20, 09:51 AM
  #7540
LAJ
So it is
LAJ's Avatar
Such a good pic
LAJ is offline
Likes For LAJ:
Old 05-28-20, 10:01 AM
  #7541
datlas
datlas's Avatar
On my way into work today, the Saturn was acting funny. The power was obviously stuttering. Initially I was askeered the clutch was going, but I saw the check engine light was flashing intermittently so I am guessing there is some moisture in the ignition system that is causing the problem (it was wet out there). I have the car at the shop, fingers crossed it's an easy and simple fix.
datlas is offline
Old 05-28-20, 10:02 AM
  #7542
LAJ
So it is
LAJ's Avatar
Flashing Malfunction Indicator Light=Cat damaging misfire.
LAJ is offline
Likes For LAJ:
  #7543
abshipp
abshipp's Avatar
There's a size 56 "Canyon Aeroad CF SLX" frameset for $400 on the local marketplace...
To be fair to the person selling it, they are describing it explicitly as a "Chinese CF frameset with Canyon paintjob".
abshipp is offline
Old 05-28-20, 10:05 AM
  #7544
LesterOfPuppets
Bikes: everywhere
Flash Malfunction Indicator Light=Cat damaging misfire.
I had that happen a couple of brief moments before I replaced my plugs. What's the deal there, is your cat toast as soon as that happens or does it take an hour or two driving in that condition to ruin your cat?
Old 05-28-20, 10:09 AM
  #7545
LAJ
So it is
LAJ's Avatar
"They" say the cat starts sintering within minutes, but you don't know it, because it starts from the center out. Many cars have a strategy that will shut off fuel to the offending cylinder, which will actually save the cat. God Save the Cat is the mantra of the OE's, at least for 8 years, and 80,000 miles. PZEV cars and the like, have an even longer emission component warranty.
LAJ is offline
Old 05-28-20, 10:42 AM
  #7546
BillyD
Administrator
BillyD's Avatar
Quoted: 11966 Post(s)
Liked 6,632 Times in 3,478 Posts
Ahhh so that's the answer I'm looking for, you're not actually pushing all the stagnant air all the way through. I think I got it, now I understand Vol's answer.
There's no quiz though is it, I need to maintain my Dean's List status.
BillyD is offline
Old 05-28-20, 10:46 AM
  #7547
rjones28
Mostly Harmless
rjones28's Avatar
Bikes: Have two wheels
Quoted: 13711 Post(s)
Liked 4,525 Times in 2,504 Posts
Who's such a stud he killed his OG Hammer this morning?
Upgrade opportunity.
rjones28 is offline
Old 05-28-20, 12:39 PM
  #7548
Trsnrtr
Super Modest
Trsnrtr's Avatar
Quoted: 10963 Post(s)
Liked 4,620 Times in 2,123 Posts
I suspect you know and are going for pedantry, but the original generation Saris Hammer.
I didn't know, either.
Keep the chain tight!
Trsnrtr is offline
Old 05-28-20, 12:40 PM
  #7549
Trsnrtr
Super Modest
Trsnrtr's Avatar
Lloyd, I stared at that for a long time, also. And I have the same problem.
#MajorDrool
Trsnrtr is offline
Old 05-28-20, 12:44 PM
  #7550
Bah Humbug
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
I’m being good and having my LBS see if there’s an easy part to replace. Failing that... well I’d been drooling over the Neo 2T anyway.
