Shimano GRX gravel group
#51
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I'm pretty surprised this hasn't come up yet. Shimano is sadly notorious for "introducing" components that don't see the market for 12+ months. What's the over/under on how many months it will take these components to actually come to market? (Shimano doesn't have road 1x YET. It's not real until it's no longer a "pre-order.")
#52
Chases Dogs for Sport
#53
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Well Di2 will probably have its entire stock go to OEM MY2020 bikes until December at a guess.
#54
#55
Randomhead
Liked 3,696 Times
This doesn't kill their own sales on their existing groups, so there is no hurry for them
#56
Quoted: 6961 Post(s)
Liked 10,960 Times
Coincidentally, my brand new custom gravel frame was delivered to the shop on the very day that Shimano announced this new GRX groupset -- and they are already building it up with Ultegra Di2. No way am I waiting until they might ship this groupset to shops. Shoot, the RD, brakes, and cassettes are identical to 8070, I subbed in a Praxis 48/32 crankset (so, no need to wait for Shimano's subcompact crank), and, well, those brifters look nice -- but not nice enough to let a new frame sit idle for 3+ months.
#57
Occam's Rotor
Liked 2,331 Times
I didn't get the Praxis Alba, because it wasn't low enough to climb Alba.
Likes For Cyclist0108:
#58
I think the higher pivot point in the levers seems like a great idea, but unfortunately it's only in the DI2 levers at the moment. Mechanical levers have the new ergonomics but not the higher pivot.
#59
Interested too but not compelled enough to swap out my existing mix and match 10 speed setup to get it. I'm setup for and in the drops over 90% of the time so I got used to not using the hoods much on my freakishly flared Venturemax bars anyway. The option would be nice though.
#60
The only really interesting thing is the interrupter levers, in my opinion. I don't even want them but it's cool tech and I can see where that would be a motivator for some people.
#62
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
I think I need to take a closer look at what gears I'm using. These smaller front gears may be great for me.
I have always been fine with a 50/34 compact crankset with an 11-32 cassette and can always find a gear, but do I ever really use the 50/11 combo? Never.
#63
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
I also feel like Shimano needs to work on releasing road/gravel Di2 12 speed. Hopefully they make all the 11 speed Di2 levers compatible with the 12 speed Di2 derailers. Sram already beat them to the market, and may very well get my money once the individual components become available separately.
#64
I know the early adopter market is clamoring for 12-speed but, to be honest, I don't use all of 11-speed. I tend to shift the rear two cogs at a time, almost every time. I don't like the range limitations of 1x (I tried it for over a year), but I could easily be happy with a 2x7 or 2x8. I wouldn't miss anything compared to a 2x12.
Likes For FlashBazbo:
#65
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The GRX calipers are the same but the levers are completely different.
The hoods are shaped to help hands stay planted over bumps. The lever has texture and a notch for fingers.
Most importantly however, the new levers are progressive. They move lots of fluid fast when first pressed to bring the pads into contact with the rotors quickly. They then fluid volume for better modulation. This is one of the reasons I want to try them.
To be clear, I would not wait either. I'm with you on that.
-Tim-
#66
Occam's Rotor
Liked 2,331 Times
The Ultegra calipers are rebranded XT, so one caliper now has three different naming conventions.
#67
Yeah, I'm in the process of scoping out a new bike, so this kind of news is interesting to me but I certainly wouldn't be needing to switch it up if I had a gravel bike that was set up the way I liked it already. As someone else said above you can run road 105 or Ultegra with a Praxis crankset and you have basically the same setup.
#68
Liked 10,960 Times
Re red/bold...
-Tim-
-Tim-
#69
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
I am running a 1x11 right now. The main gripe I have is the large percentage gaps between the gears. Take a similar range cassette and add another cog and now the gaps become smaller. 2x set ups benefit by having smaller range cassettes which have smaller gaps.
I'm not 100% sold on 1x gravel drivetrains but I think the shimano 12 spd 10-45 cassette is worth a try. I think it would make a great gravel set up with a 36t-40t chainring.
#70
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
https://bike.shimano.com/en-US/techn...ve-action.html
#71
Quoted: 353 Post(s)
Liked 92 Times
Re red/bold...
-Tim-
-Tim-
#72
Expired Member
Quoted: 3664 Post(s)
Liked 5,412 Times
I'm going to be happy to get a decent Shimano crank with 46-30 for road as well as gravel bikes.
#73
- Soli Deo Gloria -
Liked 736 Times
Yep, you're right, and I knew all of that. I should've been more specific. In fact, I think those levers are potentially the best upgrade in the new GRX groupset...And having the FD sit proud of the seat tube by an extra 2.5mm might allow more tire clearance in some frames.
If they work as advertised then the progressive levers are the most compelling part of the whole product line.
-Tim-
#74
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
i am excited about this and would love to get my hands on it.... except I just bought a chain and rear cassette for my Salsa Journeyman.. I would love to put all shimano on it.
#75
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,173 Times
Shimano dedicated gravel group set thread merged with Shimano GRX Group thread because they are very similar. This will make for better discussions.
