Campagnolo Nuovo Record RD Jockey Wheels/Pullies?
Bikes: 1983 Austro Daimler - Puch Pacifica, 1984 Miyata 310, 1983 Univega Gran Tourismo, 1989 Peugeot Triathlon, 1989 Bridgestone MB-1, 1992 Klein Rascal, 1992 Cannondale M-700
Quoted: 86 Post(s)
Liked 73 Times
hi all,
I am restoring a late 60’s Frejus and the jockey wheels/pulleys from the rear derailleur are cracked. Does anyone know of a replacement part for these? I do not need them to be, OEM as would rather not spend $100 on the bay. I just want something that would work!
they have 9 teeth, and are much wider than other jockeys that I have on hand. I have a shop that stocks old derailleurs for parts, but is an hour drive away, and there is no guarantee that he will have them on hand, so I would like to know what will work and call him before heading over.
Thanks!
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
There are lots of theories why the 35 to 50 year old Campagnolo derailleur pulleys crack like that. A Google on the subject will come up with a lot of discussions.
Soma makes some "Faithful copies of a classic Campy style" 10 tooth knock offs with the same dimensions as the originals for $35.00 USD list.
https://store.somafab.com/sonujowh.html
Never looked into the pros and cons of 9 tooth vs, 10 tooth pulleys so I can't comment. Google this too.
Here's some Shimano made 10T pulleys that will fit Campy NR RDs on eBay for $19.00 shipped:
https://www.ebay.com/itm/2-New-Vinta...QAAOSwmYFcc2oo
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 1639 Post(s)
Liked 829 Times
They all pretty much crack at the seam where the plastic flowed from two sides and met inside the mold you will see it in the flow pattern visible on the surface of the jockey wheels.
The plastic must have cooled too much before the mold was filled so it did not fuse very well at that point and presented a weak point where they crack, after 20 or so years.....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
The Shimano 10 tooth ones fit fine and work great. That's what I have on the SR RD on my Colnago.
Quoted: 3015 Post(s)
Liked 3,802 Times
9-tooth. Nice. You could very well have a first gen RD. Worth a pretty penny. You could sell it and buy a half dozen later versions of the Nuovo Record. Use those until they wear out.
Death fork? Naaaah!!
I like these, from V/O:
Top
Top
Likes For top506:
verktyg
Liked 1,238 Times
6-7-8 Speed Pulleys On Amazon
The links that I posted above should be for 10mm wide pulleys.
verktyg
Chas. ;-)
Chas. ;-)
According to the first user's review, he measured 10.1 mm.
verktyg
Liked 1,238 Times
Shimano Pulley Width
That's good to know. I have some Shimano pulleys NIB. I'll have to check the part number and measure the width to compare them with the Amazon offering.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
verktyg
verktyg
Chris
Crapmaster Emeritus
Chris
Crapmaster Emeritus
Quoted: 3464 Post(s)
Liked 2,829 Times
I could see that might not be that strong and or a real bear to assemble.
The Nuovo Record rear mechanism reminds me of the original Volkswagen Beetle, over time till the Super Beetle, looked the same but was not.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
Unless your planning on entering your ride in a Concours' event, just buy an old quality deraileur and swap out the pulleys. Or like people have said,go the Ebay route and buy new ones for under $15. Ive done it a couple of times with no ill effects and the deraileurs work just fine.
BTW, I have about 3 Nouvo Record deraileus all with the same crack in the pulleys.
Quoted: 86 Post(s)
Liked 73 Times
Wow! Thanks everyone for the advice! After seeing you can use old Suntour pulleys, I remembered that I have an old suntour derailleur that I’ve had for like a decade. I will try to find it and try it out, if these don’t work I will probably go the eBay route and get the Shimano ones for $5.
Im going to keep the old and cracked 9 tooth ones, just in case I sell it and the new owner wants a wall hanger in original condition.
Thanks again everyone! I continue to learn so much on here everyday and I appreciate the knowledge and support!
verktyg
Liked 1,238 Times
Shimano 10mm Wide Pulleys
I have a couple of NIB sets otherwise I would have grabbed some more. (didn't want to hog them up so that someone who really needs a set could get one).
They fit 5-6-7 speed Simplex RDs too.
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Quoted: 86 Post(s)
Liked 73 Times
So, pulled a pulley from my old suntour and noticed the diameter of the pulley is quite a bit larger than the original 9 tooth campy pulleys, will this effect its performance? The suntour pulley is also a bit rough, so I went ahead and ordered the $5 eBay pulleys. Thanks for that link! I don’t know if the diameter of the shimano ones is also larger, but, they are new so at least they will spin freely. And for $5 I’m okay if they don’t work, I’m sure I’ll need them someday.
thanks again everyone!!
Liked 3,802 Times
10 tooth is a larger diameter than 9. The larger diameter makes it less prone to breaking,
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
I think the red anodized aluminum pulleys look really slick on older derailleurs.
Commence to jigglin’ huh?!?!
señor miembro
Liked 6,480 Times
Quoted: 86 Post(s)
Liked 73 Times
Likes For chico81:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
verktyg
Liked 1,238 Times
Suntour, Shimano, Simplex vs Campy Pulleys
What I found was that Campy NR pulleys had smooth rounded edges on their teeth. Notice the seam line or, the beginning of a crack in this NOS mid 70's Campy pulley.
Mid 70's Suntour pulleys were wider at the tops of the teeth and didn't fit into the chain as smoothly. Also the plastic was much harder than on Campy pulleys and it took much longer to wear in and smooth out the vibrations.
NOS 1975 era Shimano Crane pulleys. The teeth had chisel edges at the tops but sharp corners. The plastic was hard too like Suntour and took a while for the corners to wear down.
Simplex pulleys had rounded edges and quickly wore in. These Pulleys were used in Simplex Criterium derailleurs until the early bike boom days. They have adjustable ball bearings.
Now to @golden boy ['s] comment about red aluminum pulleys, in 1975 I switched from Campy NR derailleurs to first generation Suntour Cyclone derailleurs.
Maybe I'm and example of the "Princess And The Pea" but the Cyclone pulley noise and vibrations were bothering me so I tried a set on Bullseye Sealed Bearing Pulleys.
It had NOTHING to do with the pseudo engineering BS about lower friction and so on. I figured that alloy chainrings smoothed out the feel over steel ones so maybe alloy pulleys would do the same thing.
I was right. After about 20 miles the corners wore off and the pulleys smoothed out. They run quieter too.
I still have red Bullseye Pulleys on several bikes plus a spare set that I pulled out of a worn out Cyclone RD.
When I installed these pulleys the chain was running rough so I had to file a little chisel edge on the tops of the teeth because I was running an SRAM PC48 6-7-8 speed chain rather than a wider 5 speed chain these pulleys were made for (what price glory).
I've replaced the grease in Bullseys pulleys several times. It's easiest if they are removed from the derailleur. I used a dental pick tool to gently remove the rubber seals then flushed out the old grease with solvent. Repacked them with Phil grease and voilà...
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Hello. This forum is incredibly useful!
Does anyone have an up to date ebay listing for the Shimano jockey wheels that fit right up perfectly on a Nuovo Record derailleur?
Much appreciated!
Much appreciated!
verktyg
verktyg
