pedaling too fast? causes...
When I pedal too fast, I hear a clunk and my footing on the pedals make my feet slip. Has anyone experience that? Can I get any tips on how to prevent this from happening?
Bikes: '84 Centurion Accordo RS, '06 Gary Fisher Marlin, '06 Schwinn Fastback 27, '06 Litespeed Teramo
Can you be more specific? Is the clunking from the cogs or front plates? Its possible your chain is skipping cogs at the rear and the likely culprits are a stretched cable or deraileur adjustment. I've only seen this happen when my bikes were new and the cables stretched out misaligning the derailleurs.
not a role model
There's really no "break in" of a bike.
It may "wear-in", meaning it will require some maintenance and adjustment after a ride. Break in seems to imply that a problem will go away with use - which is never the case with a bike - at least not that I can think of.
it has something to do with the gearing. I'll probably bring it to the bike shop and see if they can tune it once more.
Bikes: Surly CrossCheck, Xootr Swift
You're inadvertently shifting (or slipping the chain) when pedaling hard. Take it to your LBS to get the derailler/cables adjusted.
Is it when you're pedalling fast, or pedalling hard? If you're pedalling fast and not completely smoothly, you might induce some slack at the top of the chain that'll make a clunk when you take it up.
Bikes: Schwinn Empire XL
I had a problem like this due to a cheap deraileur. It's the chain slipping due to the cheap deraileur. See if that is the problem.
Dances a jig.
Bikes: 2007 Surly Long Haul Trucker 54cm (Commuting/Wanna' go tour so bad), 1985 Trek 670 21" (Road), 2003 Gary Fisher Tassajara 17" (MTB), Cannondale DeltaV 600 (commuterized MTB), some junker bikes in my garage
Does the "clunk" happen on every pedal stroke?
Smiling and Waving
Bikes: -
It wouldn't be coming from the BB would it? I find that no shop puts enough grease in the bearings. Even on a brand new bike I take the BB apart and regrease it. That way I know that there's enough.
