Secondary retention on panniers
Bikes: Surly Cross-Check, '85 Giant road bike (unrecogizable fixed-gear conversion
Does anyone not entirely trust the attachments that hold panniers to racks?
If so, does anyone normally use additional straps or bungees to hold their panniers more securely to the rack?
Does anyone have horror stories about pannier attachments failing?
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
I've flung off panniers that use a simple hook to hold them onto the rack...and that's even with the supplemental bungies on the back. The attachments used on my Ortliebs, on the other hand would probably rip the bag off before they let go of the rack. They grip like a pitbull on a rope
Stuart Black
Stuart Black
Professional Fuss-Budget
I haven't heard many "horror stories." A secondary attachment would also make it harder to take the bags off, which could be bad (less convenient) or good (if you're nervous about someone stealing your dirty underwear).
If you get good panniers, though, I don't see any cause for concern. Just inspect 'em every once in awhile.
I looked down once and saw that I was missing one of my rear panniers with a traditional hook and bungie connection. I freaked out and backtracked, luckily it had come off at a particularly bumpy attachment joint at the bottom of a nearby bridge. I was lucky because the pannier had some important pieces of gear.
Incidentally, I also use ortlieb now and I like Cyccommute's description, it's spot on.
I have these Avenir Excursion Panniers.
They have a top, spring loaded clip that keeps them from going up as well as two hooks that hang the bag on the rack.
tgbikes
Bikes: Volpe,Eros, Voyageur, LHT, Ochsner
Put a zip tie around each hook, and rack bar. the 4 th hand tool ? the one that pules cables tight , works wonders on zip ties too.
Dances a jig.
Bikes: 2007 Surly Long Haul Trucker 54cm (Commuting/Wanna' go tour so bad), 1985 Trek 670 21" (Road), 2003 Gary Fisher Tassajara 17" (MTB), Cannondale DeltaV 600 (commuterized MTB), some junker bikes in my garage
I don't worry about it with my Ortliebs. They are the classics with the more basic retention system. I once had the lower hook disengage, so the pannier was only hanging on by the top two hooks. I'm pretty sure it happened because I was carrying a light load so the bag could flop around a lot. Even with only the top hooks engaged it didn't fly off (the top ones wrap around the rack rail).
Quoted: 19 Post(s)
Liked 7 Times
I would worry about retension with an old-fashioned hook and elastic system but with a well designed modern locking system it is not a concern. Ortleib and Rixen&Kaul are both well proven. I have ridden some pretty wild descents on mountain trails with no problems at all.
There are some modern system (here)which use a hook in 2 parts, ie not a hook at all. If this mechanism fails,there is nothing to prevent the panniers pivoting out and down in a Bad Way. That link has lots of great touring info so take a look.
Bikes: Surly Karate Monkey (dsk/cmpy/mstcheBrz), Kona Jake the Snake
I retrofitted all of my panniers with a cut inner tube with a knot in it.....no episodes since.
totally louche
Bikes: the ever shifting stable loaded with comfortable road bikes and city and winter bikes
Liked 10 Times
I have Ortliebs with a buckle for a secondary retention strap. I use it during rough road (gravel-fire road) tours) and usually not on road tours. I had a (inexpensive) pannier jump the rack in the 80's on a washboard gravel descent, spilling the contents down a steep gully. I lost some gear that I couldn't recover. I doubt orts could jump the rack, but the secondary strap limits the rattling on rough, high speed descents.
lesson learned.
lesson learned.
My Seratus have a good system, the lower "hooks" are attached with webbing loops that adjust with fastex buckles, and the tail ends of the webbing velcro down for additional security. The system was really designed for the Blackburn rear rack that have little horns on them. The paniers don't actually have hooks, but metal loops. once the metal loops are popped over the horns, and the straps are velcroed, it's never coming off, and it's a 4 point system so it doesn't shift at all, that used ot be only on stuff like Needleworks or Gordon.. The only problem is that isn't how the Blackburn front racks worked, and this pannier was lousy for them. When I built my new front rack, horns were part of the deal.
Overall you best consider the bike, racks, and panniers as a package. Just radomly sampling and assembling off the net may get you into more trouble since the integration is pretty key. The three best individual products may be a disaster together.
Hooligan
Location: Base of the Rocky Mountains, Canada. Wonderous things!
Bikes: 2010 Cannondale Hooligan 3
MEC panniers are so snug on my rack that I have a hard enough time taking them off as is.
I'm made of earth!
Bikes: KTM Macina 5 e-bike, Babboe Curve-E cargobike, Raleigh Aspen touring/off-road hybrid.
Quoted: 10 Post(s)
I think the normal hooks and bungee arrangement is pretty adequate and consider the elaborate attachment systems to be a solution to a problem that doesn't really exist. Don't get me wrong they are nice and also have other advantages like being able to move the attachment points along the rail to their optimum position for the rack and bike in question.
I do inadvertantly use a second retention system of sorts though. The way I attach the tent and sleeping pad on the top ties the two rear panniers together so even if one were detatched from it's mounting it still would be hanging from the straps.
The Ortleibs are nice and if you have the money to spend and the inclination that is fine. OTOH: I don't see how they would have enhanced my summer of living on the bike a bit beyond the experience I had while using a set of 4 panniers (Nashbar waterproof) that totaled about $50 with a good sale price and a 20% off special.
Bikes: Trek 5200, Giant Rainier, Devinci Destination,Motobecane CF, Bike Friday family tandem, Bike Friday NWT
Quoted: 15 Post(s)
Axiom panniers have a great locking device that holds the pannier snug against the rack. It can be difficult to initially set up if your rack has multiple tubes.
Hockey
Hockey
Liked 4,201 Times
I don't get this. I can't imagine how a pannier can fall off without you hearing it. I have had things that were tucked under a flap fall out and I always heard them, even if they were smallish items. I guess I am careless that way, but I have had stuff that was tucked under a flap fall with an embarrassing frequency. A tube of Fig Newtons, a ziplock with lunch, a full waterbottle, and a package of jerky all were noticed instantly and retreived. Gloves or a jersey could fall off un-noticed, but a loaded pannier? You would have to be deaf or unconcious to not hear it.
Rattling down a dirt road with all kinds of stuff clattering and clanking around and the bag takes a flier? I can see how you'd miss it flying off.
Stuart Black
Stuart Black
Bikes: LeMond Buenos Aires, Trek 7500, Scattante CFR, Burley Hudson
I threw the Performance brand panniers off the rack. The come with a safety strap that holds them on if they come unhooked so no damage. The Arkels that I have now won't come off without major metalic failure so I don't worry about them.
-MEC panniers are so snug on my rack that I have a hard enough time taking them off as is.-
Those would be the new ones with the snap on plastic mounts. Im still using the old ones that have metal hooks, as they did when I bought them 20 years ago, or whatever it was. I like the hooks because they are very simple and clean to attach and position, but they need a 4 point attachment to work properly. The four point is super secure adjustible, but hasnèt been all that popular, and now we have these snap on ones. i tried some new MECs and hated them compared to the earlier models. There were far fewer positons they could mount on a rack, and they were as heavy empty as my odd one is loaded. I think I have internal frame backpacks that weigh less.
40 yrs bike touring
Bikes: Bruce Gordon Ti Rock N Road [1989], Fat Chance Mountain Tandem [1988], Velo Orange Neutrino (2020)
Quoted: 14 Post(s)
Liked 6 Times
The idea of needing "secondary retention straps" for panniers made me laugh a lot!
Robert Beckman Designs Panniers solved the retention problem long ago. They will not move unless I want them to no matter the on or off road conditions.
A well designed pannier should include an attachment system that does not spontaneously eject the panniers at random moments.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
I hook the handles on my rear ortleibs under the spring thing most carriers have, to be extra secure. They don't come off until the top of the rack is cleared of junk.
I've had a few issues with front ones, they are cheap phillips ones and the mount is not the best. Ok now Im very careful about putting them on.
My MEC panniers don't let go for anything. I used to have Lugger panniers with metal hook mounts, but they were never as secure.
Hooligan
I don't get this:
"I think the normal hooks and bungee arrangement is pretty adequate and consider the elaborate attachment systems to be a solution to a problem that doesn't really exist. "
Every pannier I've owned with the normal hook and elastic had a problem of flying off if the rear wheel hit a good bump. I have a pair of Performance tranist epic panniers with the plain rubber coated hook, but no elastic. Instead, of an elastic it uses an adjustable nylon strap that doesn't flex if you hit a good bump. They've never come off. I've also owned Eclipse panniers with a sliding rail attachement--they never flew off. Neither do my deuter's which have a locking hook. Friends of mine with lone peak panniers--which also have a locking hook system--have never had their Lone Peak panniers jump off. Only the panniers with plain, non-locking hooks and elastic bottom hooks jump off. So the problem is indeed real. What I don't get is how you can use these and never have them jump off. The only way I can figure is:
1. The roads and routes you use don't have any serious pavement issues and are butter smoothe.
2. You ride really slow.
3. You are super observant, and slow down for any bump which will throw your panniers.
Bikes: 2008 Surly LHT complete & 1988-ish fuglyfixed Specialized RockHopper
My purpose for the original post here was that I had just bought a pair of Avenir panniers with locking hooks. But they looked flimsey and I didn't trust them.
6 months later, no problems.
