Ultrasonic Cleaner
Quoted: 741 Post(s)
Liked 412 Times
Ultrasonic Cleaner
I would like advice on a ultrasonic cleaner for home use. My plan is to use to clean small parts like chains an cassettes. What is a good size in terms of liters
Really Old Senior Member
Hint-
Put your chain in a plastic tub of cleaning solution and put the tub in the tank of water.
I use the kind of rectangular flat tubs that deli meat comes in.
Quoted: 1438 Post(s)
Liked 1,092 Times
You only need an inch or so of water to couple the ultrasonic energy into the tub (or beaker) full of solvent.
Likes For dsbrantjr:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I have the 2.5 liter one from Harbor Freight. It is absolutely great. For best results I add Simple Green and put the heating of the water on. When I have larger items, such as a crankset or household baking pan, I dip a half and clean it, then turn it around and do the other.
I was hesitant about getting such a cleaner, but I had a coupon for Harbor Freight and it took me over the hump. Now it is an essential everyday tool. If I have any bolts coming off anything they go into the cleaner without any second thoughts. As an extra piece of info, in my workplace people use such cleaners routinely in their shop and, for high class stuff, they fill the cleaners with alcohol, presumably without heating .
If parts were being washed in cleaning solution within other vessels (e.g., glass beakers), then those vessels were suspended within the tank; nothing resting on the bottom of the tank.
For the ultrasonic cleaners that I have used, the instructions stated clearly that the unit should be filled to a specified level (which was fairly close to the top of the tank).
Different sizes/shapes to fit the job.
Whatever container used, you do want the water level to the fill mark.
elcraft
led
Quoted: 1106 Post(s)
Liked 1,328 Times
As a commercial goldsmith,I have used ultrasonics for 35 years. I would caution against running an ultrasonic with only an inch or two of water- the transducers that create the ultrasonic waves can delaminate from the bottom of the tank. the transducers are engineered to operate with adequate “cushioning” and heat dissipation with the fluid at the intended level. An inner container holding the cleaning solution will dampen the sonic waves, but will allow for different solutions to be used in a single bath. The cleaning time will be greatly affected. The proper cleaning solution is key, as well. A degreaser, with a detergent will clean best. Try Top Job as an all purpose cleaner, it has both the degreaser and detergent , along with a wetting agent or surfactant to leave a clean surface. Different cleaners can alter the finish on alloy parts, particularly if heated. Simple Green will discolor some polished alloy parts- when in doubt, run it with cold or only Luke warm Simple Green solution. Be warned. The cleaning cycle on most Ultrasonics is only a fraction of the needed time to clean most things. I used to clean my chain from a bike used for commuting, it took at least an hour to clean, sometimes a lot more. Any container you use to hold a part will dampen the effect of the sonic waves. Suspending the part on a rubber covered hook in the middle of the tank oriented above one or centered between the two transducers works best. Sieves are best for items like chains. If the part is a rare vintage one, only have it ina nylon sieve or expect the surface to be dulled by vibrating against a metal sieve.
led
led
Quoted: 164 Post(s)
Liked 44 Times
i dont think and ultrasonic cleaner is made for chains and cassettes , you will get a cleaner part for a cheaper price just using some glass jars and some gasoline , or white clear oil , like WD or even lamp oil , save your self the time and money and just invest in glass containers, BUT if you can prove an ultrasonic cleaner will be more cost effective than just a 3 dollar gallon of gas or 4 dollar liter of lamp oil , keep in mind the much that will come off a chain will most likely ruin your cleaner !
Quoted: 569 Post(s)
Liked 582 Times
Your cleaner will do chains and cassettes and make you smile. Make sure a crankset fits if you are like me.
Glass jar.
Volatile solvents.
Quoted: 194 Post(s)
Liked 204 Times
Shucks, there goes my whisky habit....
For cleaning I prefer to conduct things in the open air, and reusing old glass bottles is good, often better than buying newly manufactured items that then consume space and electricity. I cannot remember when I last used gasoline, but a little bit of paraffin is nice.
