Metal shavings during / after headset installation
fareless square
Bikes: crabon
Let me start by saying I'm an experienced home mechanic, have done about a dozen headset installations in the past. Ran into something new last week that freaked me out: metal shavings that squeezed out as the cups seated.
The bike is a brand new frame, retro steel randonneur with 1" head tube, reputable brand manufactured in Taiwan. Working with the Park HHP-3 headset press, installing a 1" FSA Duron X headset (aluminum external cups), also new, with both surfaces thoroughly lubed with Park Polylube. Each cup went on a little crooked but straightened themselves out eventually, nothing out of the ordinary. Was a little tougher than normal getting the cups to go in, but I continued (foolishly?). When the cups seated, out came a couple long, thin scraped-off bits of metal. The largest grabbed a small bit of the head tube paint and lifted it up, which made my stomach sink, ughh.
Checked to see if the metal bits were magnetic and, thankfully, they seemed to be aluminum from the cups, not steel. That gave me the slightest bit of relief.
I put the frame aside and got back to it today. I removed the headset cups and inspected. No damage or marring inside the head tube, thankfully, but the aluminum cups seem to have been lightly scraped by the head tube. One cup had a bunch of shavings jammed around the 90 degree angle where the frame seats; I gently removed these with a utility knife and cleaned up all surfaces in anticipation of re-installing.
So my question is.... is this normal? Never experienced this before. Should I have had a shop check tolerances and ream the head tube? I'm expecting the re-installation to go smoother, but should I swallow my pride and have a pro take a look?
Quoted: 837 Post(s)
Liked 1,061 Times
Could be you have an ISO headset-(30.2mm) in a JIS-(30.0mm) headtube. Usually not an issue though but your fit could be extra tight. If you have some calipers measure them. I wouldn't ream the headtube unless it's out of round or has some rough edges as it's not necessary but take some sandpaper to smooth out the gouges in the cup.
fareless square
Bikes: crabon
Think I should look for a proper JIS set or roll with what I've got? I honestly had no idea these two standards were out there and didn't expect to encounter them on a bike manufactured in 2020 (with disc brakes and thru axles, no less...). Now wondering if I should worry about the crown race spec too!
Looking at other manufacturers' 1" offerings, the cups are listed 30.1 (Cane Creek), 30.15 (Chris King) etc.
Quoted: 2026 Post(s)
Liked 1,096 Times
Just reinstall the cups and forget about it. No harm done. Did the crown race seat normally or was it too easy to seat? If you really have a JIS headset (27.0 mm) the crown race would be oversize if the fork is ISO (26.4mm).
fareless square
Bikes: crabon
EDIT: misread your reply. Haven't installed the race yet, but will be checking measurements first thanks.
Quoted: 4205 Post(s)
Liked 3,864 Times
I generally deburr/chamfer the HT faces' inner edge so that the cups will both initially fit easier and not do what yours did. A fine tooth rat tail file and/or sand paper. Andy
AndrewRStewart
AndrewRStewart
