air helmet
air helmet
i need to get a new helmet. walmart helmets are so cheap compared to the ones at the bike shops. are they less safe? why aren't helmets just made inflatable? (not just upon a crash) they would fit better too.
Quoted: 6191 Post(s)
Liked 4,807 Times
Bicycle helmets sold in the USA have to meet specs of the Consumer Product Safety Commission. They are pretty decent. The only question will be how much more safety do you want and are willing to pay for.
What's really unanswered is how many more people would be saved if everyone used the highest rated helmet vs the lowest rated helmet.
We've got plenty of threads here where that has been thrashed and re-hashed and discussed to minutia.
So just pick your most comfortable cycling helmet in your favorite color at the price you are willing to pay.
https://helmets.org/standard.htm
Your air helmet will likely need to meet CPSC standards if you are anywhere that requires a helmet here.
Likes For Iride01:
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Just wrap your head with bubble wrap.
BTW... i'm joking.
BTW... i'm joking.
Likes For GlennR:
Quoted: 1074 Post(s)
Liked 295 Times
Pretty much all helmets are tested to the same standards. Which means all helmets that pass testing provide AT LEAST a set amount of minimum protection.
Data on how much more protection than required that a helmet supplies is scarce.
There used to be a persistent rumor that cheap helmets actually provided MORE protection, since they generally were heavier and with less vents and cutouts.
If there ever was any truth to that, I don’t know.
But it’s easy to see where the idea came from.
Air helmets kinda-sorta already exist, look up ”Hovding”.
Whether they overall provide more protection has been somewhat debated.
The Hovding does better in some impact geometries and poorer in other.
Planning to land on a flat surface, the Hovding can do a great job.
Expecting to end your trajectory against a corner or an angle/ridge, better use a rigid helmet.
Likes For dabac:
In any case, the problem with a bike crash is that the true injuries do not come from a fractured skull but rather from a concussion. So a CPSC helmet approval is actually a dangerous helmet though this will IMMEDIATELY bring claims that "MY HELMET SAVED MY LIFE". If your life was "saved" it was not an accident strong enough to kill you.
However, Trek did some serious research into the proper way a helmet should work. And under the their brand name "Bontrager" they market a helmet with the appellation of "Q-cell". There is not enough data to know if they really increase the safety of a helmet but I bought one and wear it because it actually has some science behind it.
But as a resume, I raced motorcycles with the American Federation of Motorcyclists (AFM) and checked out helmets since the speeds are so much greater. Well, road racing crashes aren't usually what you could call a crash but losing traction and sliding out. Motorcycle helmets have a hard shell and so the actual foam padding inside the helmet doesn't do anything, the hard shell allows your head to bounce and slide along the ground without skin damage,. When I realized that I was doomed to a perennial third place I retired and they asked me to become the Safety Director. So I went down to Bell Helmets and talked to them about their safety standards. Believe me, the hard shell was by far the most protection. And as proof, Many years later I was riding through a parking lot at about 5 mph and a first generation carbon fiber fork fell apart and dropped me on my face/helmet. I was released from the ER as perfectly fine. I wasn't and spend the next two years having no idea what I was doing. I couldn't even remember to eat. When a friend asked me to the Club dinner and while there his wife, a nurse, observed me having a seizure. He made arrangements for a Stanford neurologist to see me. The neurologist told my friend that he had never seen a concussion this bad. It took about six months to balance the medications required to stop several different types of seizures and suddenly it was just like waking up from a nightmare. Nothing made sense and it took me years to recover a large part of my memory. At first I couldn't even drive up to the supermarket without getting lost.
While it would probably be possible to make an inflatable helmet they would have to be especially "tuned' to the rider weight which makes it impractical. Part of the problem with helmets is that you cannot wear a helmet over a certain overall diameter since any larger it would block your vision which is especially important on a bicycle.
I suggest the Q-cell from a Trek Dealer and there is no reason to get the expensive version. I paid $100 for mine but a friend recently bought one for $60. So they are coming down in price. You can recognize them from the "standard" helmet by the padding looking like honeycomb.
Likes For RiceAWay:
Quoted: 18409 Post(s)
Liked 15,525 Times
Quoted: 1581 Post(s)
Liked 1,189 Times
Last edited by badger1; 03-06-21 at 10:02 PM. Reason: Correct appalling spelling error.
Quoted: 4802 Post(s)
Liked 3,923 Times
Two comments here. 1) There is a feature that could make helmets significant;y better that is not addressed by the CPSC standard. Slippage to minimize head rotation as exemplified by MIPS but there are others. 2) The "best", most expensive helmets are designed to just meet CPSC (or CPSC and MIPS) so they can be as light, cool and comfortable as possible. I have no proof but I'm guessing that an $80 helmet has more protection than a $25 helmet but that a $150+ helmet is probably close the the $25 one.
Likes For 79pmooney:
Clark W. Griswold
Quoted: 4347 Post(s)
Liked 3,984 Times
The difference in helmets is the Wally-Mart version is likely built as cheaply as possible to barely pass CSPC standards while nicer helmets will have some R&D behind them to make them safer. My helmet is expensive yes but it is really light and really comfortable and that is important to me. I also know that Lazer is doing a lot of in house testing on helmets to improve everything including safety.
Wally-Mart might take a basic shape from the 90s and sort of recreate it and slap a Schwinn Quality sticker on it so you think their is at least a smidge of quality to it. Plus the Waltons don't need your money, they are plenty wealthy and their employees are plenty poor. Not a great business to support. Your local shop however is a good business to support and getting yourself a nicer helmet will feel better on the head. Even the base model Specialized helmets are coming with MIPS and other neat features and are pretty well designed and not super expensive considering it is a safety item.
Inflatable helmets would look pretty goofy as you can see above it looks like Spaceballs: the Movie and Victorian era wigs came together and crapped that thing out.
Likes For veganbikes:
the cpsc standards are for hard helmets. they really should rethink things. cars use AIRbags to soften crashes. i think they should apply the same concept to helmets. vets used to put hard plastic cones to stop my pets from chewing off their stitches. they were heavy and uncomfortable. now they have soft donuts for the neck instead. makes way more sense.
i did google hovding before i posted but theirs inflate on impact. i think it should just be an inflated design, like wearing a cushion on your head.
Liked 4,807 Times
I know a lot of people are ashamed to wear Bell anything, but for an inexpensive product they are pretty good.
Likes For Iride01:
Clark W. Griswold
Liked 3,984 Times
Were does all the hate for Walmart come? Their helmets are usually Bell, which scores high on Virginia Tech's list. https://helmet.beam.vt.edu/bicycle-helmet-ratings.html
My dislike for Wally-mart is vast but mostly has to do with massive labor and income inequality issues and destroying local business amongst other things
Likes For RiceAWay:
Quoted: 1062 Post(s)
Liked 665 Times
But it's certainly an interesting area for research.
i am so sorry about your accident. how absolutely awful for you. yes, i would imagine riding a motorcycle would need a hard shell helmet. i googled the q cell helmet and i am not sure what the honeycomb is made of. it certainly is expensive. my idea is to have a hard shell but for the inside to be inflatable without changing the dimensions of the outside so it would not impair one's vision. thank you for sharing your experience. wishing you all the best.
Not all are Bell and Wally-mart Bell and bike shop Bell are of a different quality level. However yes Bell makes fine helmets.
Quoted: 6958 Post(s)
Liked 10,959 Times
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
In motorcycle helmets there was a semi scandal about 15 years ago when motorcycling magazine published a story with data that DOT level helmets provided more protection than Snell certified helmets. They lost a lot of advertising and the fallout for the reporters went on for years. A very rare instance of enthusiast press standing up, and boy did they get slapped. The DOT only helmets were superior in the magazine’s test because they were thicker foam and made a little bit less G force, as I recall. So that might be behind any rumor that a cheap bike helmet is superior to some other standard.
This all pre-dated MIPS helmets completely, iirc.
The inflatable interior helmet is not a terrible idea, it’s how some football helmets work, I think. The idea of having some kind of eggshell plastic or foam also goes back pretty far. But of course, Trek’s version changed cycling forever. We all know that because they told us so.
Genesis 49:16-17
Genesis 49:16-17
Disco Infiltrator
Liked 2,105 Times
Meanwhile, on the topic of Walmart helmets, I got my boy a helmet from Walmart about a year ago. For most of that time he has refused to wear it, and since it’s only going balance bike speeds I haven’t really pressed the issue. So it’s not very used. It’s completely faded, without having been in the sun, all the plastic shell is cracked and the visor has broken off. The straps are just comically badly fitted. You get what you pay for.
Genesis 49:16-17
Genesis 49:16-17
Clark W. Griswold
Liked 3,984 Times
It would most likely pop or deflate well before it needs to protect you and probably will not have the same effects that EPS foam or Koroyd or similar materials have when impacted. There is a reason behind a lot of this stuff and not because Big Foam has shut out Big Air.
Patently incorrect. I hope this is not what you meant to state. And by the way: the Trek/Bontrager design that you refer to is WaveCel, not Q-cell.
I have two helmets from the same brand (Specialized). They have the same general design in terms of shape, vents, retention system, etc. One cost $75, the other was $250. The cheaper helmet is heavier (though comfy for all-day rides), has slightly smaller and fewer vents (though still not too hot on warm days), and significantly thicker styrofoam. I suspect it would, indeed, provide better protection in a crash.
I forgot that they now call that "wavecell" when I bought mine they called it "q-cell". They also make a high end version that includes that IRS or whatever it is called that allows the helmet to rotate within limits on your head in a crash. Their testing showed no improvement since the wavecell reduces the impact to the point that your neck is not really threatened. Like I say, there is insufficient data on whether the wavecell makes any difference but if they are at least trying to use real science then I am willing to believe them.
