11t single speed?
Non omnino gravis
Non omnino gravis
Non omnino gravis
Quoted: 586 Post(s)
Liked 612 Times
If you are replacing a cassette, why not just use an 11 tooth ring off of a cassette along with a single speed conversion kit? I think Jenson sells the 11t cogs for around $3.99. Add the spacers from the conversion kit and you're all set.
aire díthrub
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times
If you’re looking for a thread on freewheel with 11t, you won’t find it. If you’re doing a multispeed freehub conversion and looking for an 11t sprocket (I’m assuming shimano/sram) well, you likely won’t find it. The easiest option I can think of would be to modify the standard 11t sprocket so it will slide all the way on the the freehub body and be used with a conversion kit. I wouldn’t recommend that though unless you have access to and experience with matching equipment. There’s a reason an 11t stand-alone sprocket likely doesn’t exist. Use a 12t, problem solved.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
A first position sprocket won’t slide all the way onto a freehub body. It has ‘stops’ and would need to have those precisely machined off in order to be useable.
I am potato.
Quoted: 1782 Post(s)
Liked 1,621 Times
Maybe the OP has a 22 tooth chainring?
Quoted: 20808 Post(s)
Liked 9,450 Times
Liked 2,563 Times
Any poseur can climb a mild grade in a 22/11.
Quoted: 18350 Post(s)
Liked 4,502 Times
Perhaps they could be modified to work with extra thin spacers.
Chainline would be an issue. But there are a couple of different freehub widths. For Shimano hubs, the 7-speed freehubs are the narrowest that are commonly available that accept hyperglide sprockets & lockrings.
A few brands have "single speed" freehubs that are closer to 5 or 6 speed width, that could possibly be used.
I have some Capreo freehub bodies that are also narrow, and could potentially be modified to accept an 11T sprocket. But, the Capreo freehubs attach slightly different than other Shimano freehubs, so you'd be needing to replace the hub too.
That's what I was thinking.
It looks like there is a 11T Odyssey Driver
https://www.ebay.com/itm/Odyssey-Dri...D/332942620630
https://www.ebay.com/itm/Odyssey-11t...D/283375341289
In many senses, the BMX Driver's look a lot like the road sealed bearing freehubs (not Shimano), and it is quite possible that one could be substituted with a bit of tinkering.
Odd, the pawls look backwards in that Driver from Down Under. Perhaps they do things backwards down there.
Overall, I think the smallest freehub/cassette style single speed sprocket that is available is 12T, and as mentioned, you could probably adjust your chainring to work with it.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12736 Post(s)
Liked 7,647 Times
As far as I know, the 11T cogs will only work in first position, and requires the notch on the end of the Shimano freehubs.
Liked 4,502 Times
Quoted: 41 Post(s)
That was my original plan, however all 11t rings on cassettes are designed to be stationary at the end. I could remove the rest of the cassette, however I won't be able to shift it on the hub.
Bikes: everywhere
Liked 7,647 Times
Many BMX hubs/drivers/freewheels, etc are available for either side.
This Odyssey driver has symmetrical pawl cubbies so you can flip the pawls for LHD or RHD:
https://fullfactorydistro.com/produc...driver-rhd-lhd
Bikes: everywhere
Liked 7,647 Times
This is a 76, along with a 53T little ring:
Likes For LesterOfPuppets:
@tellmethetruth you're also gonna want to choose a saddle carefully for this build as its gonna have to support your evidently enormous manhood
Honestly though, build your bike how you want man, don't let all of us skeptics get in your way. I just ask that you follow up once this build is done. Everybody on this forum loves bikes, whether they appeal to the popular formula or are a bit kooky. I think most of us here just want to see what you come up with!
good luck with the build
