Attachment Rivit for rear derailleur
If the derailleur has play side to side and there is no way to tighten the rivet and the high limit has no more adjustment and you still can't get to the highest gear should the derailleur be replaced.
Getting to the highest gear should never be a problem since the default state of the vast majority of RD's is for the spring to pull it to the highest gear. Perhaps you actually mean the lowest gear?
Knows the weight of my bike to the nearest 10 pounds.
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
...and are you sure this rivet is the source of play? There are other possible sources of slop, in the derailleur itself and how it mounts to your frame.
If you're using an old derailleur, like a 5- or 6-speed unit, it may not be able to span newer, wider cogsets with more gears.
...and if your derailleur hanger's out of alignment, that can also affect whether or not the derailleur can reach all the cogs in the cluster.
The spring tension is pulling the derailleur toward the bicycle away from the smallest gear.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Not seeing this. Picture?
Bike and derailler brand?
This info will help get you an answer.
There is a metal arm on the bicycle frame to which the derailleur is solidly bolted. The next position down on the derailleur has a rivet. One end is exposed the other end is under a plastic cover. The loose rivet allows the derailleur to rock side to side. That rocking prevents the derailleur from being adjusted to the (H) gear, the smallest one toward the outside.
Tgroen1
Bicycle Mechanics
8
12-14-18 06:28 AM
gryffinwings
Bicycle Mechanics
5
02-16-13 05:09 PM
