Best way to remove grips without compressed air or cutting them?
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12776 Post(s)
Liked 7,693 Times
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
Just had to remove a set of grips myself from the bike I PMed you about, I used a screwdriver very carefully to open up the end sprayed in some windex and with 3 twists it popped right off. However I was very diligent with the screw driver and it already had a slightly angled shaft that played in my favor.
Quoted: 90 Post(s)
Liked 18 Times
here recently i've also used windsheild washer fluid (it was where i was working. i guess it could be comparable to windex). not sure if it has any tackiness once it dries, but it worked as well for removal.
Bikes: Seven Axiom Ti, Trek 620, Masi cylocross (steel). Masi Souleville 8spd, Fat Chance Mtn. (steel), Schwinn Triple Bar cruiser, Mazi Speciale Fix/single, Schwinn Typhoon
Quoted: 7 Post(s)
Bikes: everywhere
Liked 7,693 Times
Probably want to keep screwdrivers away from carbon bars as well.
No drivers on anodized bars either. If you score some NOS of these, chopsticks or bamboo skewers only!
Bikes: many
ROGER THAT ULTRA!!! I used some Remington Wonderlube spray to juice up a brake cable the next day "I must have over sprayed a little" because as I was taking off I hear "SLOOP" it came off with minimal effort. The thing is I wasn't expecting it to come off and ended up ass up and over the bars on the ground, still & only holding the grip wondering WTF just happened to me "I didn't even get out the gate!!" . ...Yes a bit of oil works very well
Bikes: Too many to count
Quoted: 8 Post(s)
Slip in a pop-sickle stick, spray in a shot of Windex, slip them off.
Took longer to type this than to get them off.....
WD40 always works for me. The best part is that it comes with a little red tube that will slide into the grip.
WD40 is a petroleum product, I believe, but it'll dry and keep the grip tight on the bar after it dries.
Likes For roots4x:
Location: Colorado-California-Florida-(hopefully soon): Panama
Bikes: Vintage GT Xizang (titanium mountain bike)
I try to use power tools whenever justified. Try WD-40, then inject compressed air from a standard shop or gas station air compressor. You might try a needle injector - the type used to air up basketballs and footballs.
Yep. There really is no need to use anything else. Particularly, WD40 seems like a waste of time and effort given that you have to use some sort of alcohol-based substance to remount anyway. Just my £0.02.
Bikes: everywhere
Liked 7,693 Times
That sounds like the best possible non-marking tool! I never thought about that cuz I never have popsicles in the house. I'm gonna have to grab a handful the next time in the coffee shop, though! Should be way easier than chopsticks. I'm kinda worried about their strength, but...
You can use oil if you like, but wash the grips in hot soapy water straight away after getting them off. Silicon spray lube might be good if you have it - wiggle the straw in under the grip if poss.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
The flash point of WD-40 is 122 F (50C) and the boiling point is around 365F (185C). With that high a flash point and that high a boiling point, there's not going to be much evaporation at ambient temperatures. WD-40 also contains mineral oil that has an even higher flash point and boiling point. If you pour the stuff out and wait around for it to evaporate, it's going to take a very, very long time as it would under the grips of a handlebar. It will probably oxidize and polymerize before it will evaporate. I...and I might speak for many here...would rather not have my grips spinning around like tops while I wait for the WD40 components to polymerize.
WD40 is just silly and messy when it comes to handlebar grips. It might take them off lickety split but so will a knife. If you want to keep the grips, use water, windex or alcohol.
Stuart Black
Stuart Black
WD40 is a petroleum product...not fish oil...but so is motor oil, diesel fuel, kerosene, wax and, for that matter, carbon fiber. Just because the material is a petroleum product doesn't mean that it will eventually evaporate at room temperature or even at temperatures that we humans find slightly uncomfortable.
Have you actually tried WD40? No, huh? I have used it many many times and after a day, the grip is on tighter than you could imagine. I wasn't implying that being a petroleum product makes it dry quicker. Quite the contrary, I was stating that it may damage some rubber grips, but it always works just fine for me.
Please tell me you for some reason knew the flash point and boiling point of WD40 before posting that. I can't imagine someone would go to the trouble of trying to prove a person wrong by researching and stating irrelevant facts. Go ahead, try it, your grips will be bone dry and stuck to your bar lightly.
EDIT: you ever notice that puddles of water will evaporate even when it's near freezing? That's a desirable property since it's not often close to the boiling point of water in Chicago during fall/winter.
I understand the skepticism, but I HAVE TRIED IT and people are trying to prove how smart they are by pretending to know what happens when they haven't tried it. I just do not understand that mentality on a message board where we are trying to share tips and tricks.
Hmm, have you tried it? Like I said, I have and it requires no washing. Contrary to popular believe, WD40 WILL evaporate and leave a slightly sticky residue that is perfect to keep the grips from spinning.
My point was that when you have found a substance that definitely works (for me, hairspray), why risk something that has a chance of not working?
How long does it take for WD40 to evaporate in this application?
Liked 4,218 Times
I've used alcohol and had the grips stick to the bars after 10 minutes because alcohol isn't a lubricant. I've used water and had it stick within a few minutes for the same reason. I've use hair spray and the grips are stuck in place after just a few minutes too. All of the above won't damage the grips which is a plus.
You might be getting some grips to stick with WD-40 but that's only because you are damaging the grips. Since the question asked by wernst was how to remove the grips without damaging them, perhaps he would like to stick them back on the bars without damaging them.
Water is kind of different. But I suspect that if you really observed the evaporation of water a low temperatures, you'd see that there is wind involved. You don't have that with WD-40 under grips. Another irrelevant fact: Water can go from the solid form (ice and snow) to gaseous form (water vapor) without going through the liquid phase. It's called sublimation. But it also requires air movement or a good vacuum. Still has nothing to do with WD-40 used on grips.
Stuart Black
Stuart Black
Map maker
Bikes: Ventana El Ciclon, Walt Works 29er, Specialized Enduro (fixed up for my son).
it doesn't make a mess at all and it dries pretty quick.
Bikes: American Breezer mtb, American Classic ti road bike w/SRAM Force and XO, Crotch Rocket, SOMA 69'er w/XX-1 mtb, Handsome Shop Bike w/700c wheels. Bianchi SS 'cross
I've removed and replaced grips 100's of times on motorcycles and bicycles for over 40 years using a chop stick (Wood or plastic) and Coleman fuel (A few drops). Takes but a few seconds and the grips stay put - and, yeah, yeah, I don't want to hear it...*
However, since their introdution I've switched to clamp-on grips, which is the best solution.
*I don't subscribe to threads, so I won't read it anyway.
Yesterday I had good luck with snow and a tire iron. I just scooped up some snow with a tire lever, inserted the end of the lever under the grip and let the snow melt and run down the lever under the grip. Voila.
(I was working in the parking lot of the local co-op at the time. Usually I'd just run to the sink and get some soapy water)
You know what's awesome though? You say you're a chemist and you think you know so much. But you are so wrong and that's really all that matters. I have done this many many times and within hours my grips are tight on my handlebars with no oxidation (steel, aluminum) and I repeated this many many many times in high school on my old trek and Schwinn.
I mean, do you think I'm making this up for fun? I tell you my grips stick right on yet you don't believe me? Lol.
As a scientist you should know that FACTS and EVIDENCE trump conjecture and hypothesis every time. LOL. Done.
