6 speed shimergo question
I have an old 6 speed, shimano 600 equipped bike, that's mostly original except the rear mech is a newer (8 or 9 speed era) 105. The bike has sat unused for most of its life so has really low mileage, so my only complaint is the downtube shifters. I am intrigued by the idea of shimergo, as outlined at this page: https://www.ctc.org.uk/desktopdefault...=3946#Shimergo
ergo 8 speed levers, or old 9 speed levers would work, but are getting harder to find and offer less of an upgrade path to more speeds in the future. ergo 10 speed levers would index right with my 6 speed freewheel if I got an old dura ace mech for the time being, and then I'd be able to have the frame spread at some point in the future and the same shifters would also index with an 8 or 9 speed cassette.
My main question so far is this: what about the extra four clicks? would the limit screws have enough range to dial these out? I've seen posts indicating that you can dial out the extra two clicks when using 10 speed shifters with an 8 speed cassette, but I worry that 4 extra clicks is too much.
Bianchi Goddess
Liked 3,263 Times
is your current setup indexed? unfortunately you can't just put the STI "Brifters on your bike. you can't use 8 or 9 speed shifters ona 6spd freewheel. the spacing between the cogs is different, so it not simply a matter of seting the limit screws. at a minimun you would need a new 8 or 9 spd rear wheel to match your new brifters.
the bike has sat unsed simply because of the shifters?
Sugar "Kane" Kowalczyk
Liked 3,483 Times
If can get the right adapter to convert the pull ratio, then you're good to go. The limit screws are on the RD, so and should have enough range to do their job on a 6s cassette. But not, you you can sub a longer screw. As for the extra clicks, don't worry about them, you just don't use them. Set it up with them at the high end and use them to slacken the cable for service.
Just so you know, you'll be increasing the cable pulled, so it'll increase the force required. If you like light action shifting, this may work against you.
FB
Chain-L site
FB
Chain-L site
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
I think I understand what you're saying. You've found a way to index Campagnolo shifter to your 6-speed freewheel?
Well if it'll work, then it'll work. You'll need to set the limit screws as you mentioned. You can either lockout the 4 lowest or 4 highest gears. You can do either.
When you set things up, just put the shifter into whatever gear (shifter position) you want to use for the highest gear (smallest cog) with the chain on the smallest cog. Obviously, it will need to be shifter position 6 through 10, so that there are enough positions for the 5 lowest gears/largest cogs.
If you set the highest gear to be on shifter position #6, be aware that you'll still be able to upshift into 7-10, but the high limit screw won't let the rear derailleur move and so you'll just create slack.
If you decide to start in shifter position #10, then you will effectively lockout the 4 lowest shifter positions. If you try to shift into position 4, then you'll be fighting an unmovable cable. This could cause potential damage if you repeatedly and forcefully do this. (A similar issue developed for some people who locked out one of the shifter positions on their triple shifter while using a double crank).
HOWEVER, keep in mind that the brifters are the most expensive part of the drivetrain. If you're already going to get new shifters and you have a rear derailleur that will work with a modern drivetrain (if you stick to Shimano), you may want to consider just going all-out and upgrading. In your case you'd need a new rear hub/wheel, so that will increase the cost (but you'll have to pay for it eventually).
You can do the step-by-step approach, but you'll be buying an old Dura Ace RD that won't be used later on.
I realize that the cog spacing is different, but according to the ctc page linked above, certain combinations of ergo levers and shimano freewheels or cassettes will work together because the "incorrect" cable pull accounts for the wrong cog spacing. When you throw an old dura-ace derailleur into the mix, which expects a different cable pull than other shimano mechs, you get even more possibilities. You can also trick the derailleur into working with other combinations through an alternate cable routing.
So apparently lots of possibilities, but since keeping the existing wheel seems cheapest for now, I was hoping someone could confirm whether 10 speed ergo levers would actually work in practice with a 6 speed freewheel and an old dura ace mech, or whether it's just noted in the table because the indexing works out, but is not really practical.
Constant tinkerer
I can't for sure that your idea will or won't work, but Sheldon ran Ergo shifters with a 6-speed freewheel on his Brown:
"Most recently, further in the spirit of breaking the rules, I installed a set of Campagnolo Veloce 10-speed Ergo shifter...still with the 30 year old Cyclone and the 6-speed Regina Oro freewheel...and that works too!"
https://sheldonbrown.org/brown/index.html (Scroll down to "Later Equipment Changes")
I agree. Brifters are very expensive, and if you're willing to shell out the cash for them you might as well get a new rear wheel too and run however many speeds you want (since your 105 RD can handle it.)
True that brifters, cables, and stops alone will be expensive, but I'd rather not have to shell out the extra all at once to have the frame spread and get a new wheel, cassette and chain too. Just an old dura-ace mech, although useless further down the road, seems a more managable solution until I really need to replace my rear wheel.
Constant tinkerer
Another thought: have you considered bar-end shifters? I put them on my downtube shifter bike to avoid buying brifters. You could get a Shimano Hyperglide 7-speed freewheel, 8 speed bar end shifters and (in my experience) you could get it to index pretty well. I don't think you'd have to spread your frame with the 7-speed freewheel.
I have an old 6 speed, shimano 600 equipped bike, My main question so far is this: what about the extra four clicks? would the limit screws have enough range to dial these out? I've seen posts indicating that you can dial out the extra two clicks when using 10 speed shifters with an 8 speed cassette, but I worry that 4 extra clicks is too much.
Ignore the rest of the muddled and irrelevant postings here - the understanding of how index shifting works is limited to a very small number of cyclists; even only few shop mechanics understand the proper relationship between the shifter cable pull, the rear derailleur mechanical advantage and rear cog spacing.
The limit screws on the rear derailleur will lock out the 4 extra positions on the shifters. There are no negative effects. Make sure you do carefully adjust the limit screws to work with the 6-speed freewheel, as you don't want the derailleur jumping into the spokes.
Downsides:
Old Dura-Ace rear derailleurs were designed for racing cogsets. They handle a 26 tooth max cog. In my experience a Suntour Accushift mountain derailleur has the same mechanical advantage as old Dura-Ace. These will handle much bigger cogs.
Suggestion:
For a much cheaper and conventional approach to integrated brake/shift levers, buy some Shimano Sora 7 or 8-speed shifters, get a basic Shimano rear derailleur (not old Dura-Ace - almost anything else made in the last 25 years will do, including the Shimano MTB stuff), and change your 6-speed freewheel for 7-speed Shimano HG freewheel ($15). The width of the 8 and 7-speed freewheels is close. This way you will not have to do expensive overhaul/mods on your rear wheel.
https://www.bikeforums.net/showthread...ity?highlight=
If DaveSSS is correct Campy and Shimano shifters have different cable pull across their range, and the action of their derailers varies across the range of motion. If this is true you may still be able to use 10 speed ergos with a 6 speed freewheel, but which six clicks you use would make a great deal of difference.
Suggestion:
Campy 10 speed shifters with shimano 10 speed spaced cogs isn't one of the combinations that works, although I did consider trying to find a 7 speed cassette hub wheel at one point and doing just what you mentioned with shimano 10 speed shifters. Didn't have much luck finding an old 126mm cassette hub wheel though.
- I had a brand new wheelset Shimano 7sp w/ campy Ofmega rims I gave away. You can try to ask if anyone on this site has a used one for cheap? The effort might negate itself, but any Shimano Mtb 7 speed cassette hub would work.
To throw in another cheaper option: Jagwire Barcon adapters https://www.amazon.com/s/ref=nb_sb_no...barcon&x=0&y=0
- convert the DT to barend shifters.
Liked 732 Times
Presumably Campy derailleurs have a much more linear relationship between cable pull and derailleur movement. I've noticed Sheldon can be a little slap-dash when it comes to the finer points of drivetrain compatibility...
Perhaps this setup can be tuned to work perfectly, but I wouldn't be surprised if the best you could manage is slightly sub-optimal.
Now that I've read the whole thread,
IMO there's no good reason road bikes shouldn't have 135mm OLDs. A 2.5mm compromise in chainline versus the extra strength of the rear wheel you can spend on durability or a lighter rim is a no-brainer for me...
I wonder how close you could get spoke tensions with the right lacing, an OCR, and 135mm OLD...
Strip the gizzards out of the <C> levers, then they're just brake levers.
friction shifting elsewhere, bar end , down tube or 'Kelly take offs' to put downtube levers
inside of the brake levers..
with a little hand labor, any combination will work.
Originally Posted by DaveSSS;
Campy 10 shifters pull 2.5mm five times, 3mm twice and 3.5mm twice.
Ye gods man, there's no call for such heresy as losing the whole point of the Ergos.
Ultra 6 begat 7,8.. then 9,etc,
gear heads [shakes head]
Liked 3,483 Times
So does this kind of B/S spam actually generate business for the spammers?
FB
Chain-L site
FB
Chain-L site
Liked 732 Times
How about a DDOS for your trouble, scumbag...
It also indexes beautifully, due to the space between cogs.
It occurs to me that Ergolevers are the only brifter that would lend themselves to be converted to friction...
Friction Ergos would be sweet! What compatibility drama?
