Derailleur In Correct Position?
Hi,
Recently swapped an old Shimano derailleur for this new Tourney, just something cheap to get the bike back on the road.
I have noticed the end of the frame does not extend like my other bikes, Raleigh Flyer and Dawes Amora. On the other two frames there is an extra part of the frame the derailleur fits on.
This is not aparent with the Saracen frame and instead just two holes of 5mm around the real axle quick release nut. Am i meant to be placing the derailleur in like i have shown in the pics?
Thanks
https://img.photobucket.com/albums/v1...x/DSCF0003.jpg
https://img.photobucket.com/albums/v1...DSCF0009-1.jpg
https://img.photobucket.com/albums/v1...DSCF0011-2.jpg
Thanks
Liked 3,480 Times
No, your derailleur is not mounted correctly.
The hanger that came mounted to the derailleur is designed to slide into a forward entry horizontal dropout of the type used for many decades. Mounting it as you did won't work because it effectively closes your vertical dropout.
I see that the frame does have extra holes, and these may (or may not) be for a specific hanger made for the job. Check with the manufacturer, or where you got the bike. Of there is a correct hanger, it mounts to the frame, and replaces the hanger that came with the RD.
If there isn't a hanger made specifically for the frame, you'll have to improvise one or modify the one on the RD so it'll work properly.
FB
Chain-L site
FB
Chain-L site
Well I have checked the hanger which came with the original Shimano Acer X derailleur and it seems you're right.
But I have also managed to get it all assembled and stolen some parts from the front derailleur i have gotten rid of, just 8 speed you see.
Just been for a ride and out of the 5 push bikes in our house its the smoothest I have felt as far as crank/rear gears are concerned.
So do I really need to find a hanger that will fit it? It seems the hanger on the other/older I replaced would have just sat in the same position, bolted to the frame and then sit within the rear quick release nut.
It shifts up and down the 8 gears effortlessly and this is with minimal work on aligning everything too.
Liked 3,480 Times
I suggest you keep riding it this way while checking to see if there's a correct made to fit hanger for your bike. Hangers aren't expensive, and having the right one will make service easier, even though it apparently isn't necessary
FB
Chain-L site
FB
Chain-L site
Will see how it is over the next two weeks.
Did notice that I would have a problem getting the wheel out but didn't think nothing of it until you mentioned above.
Will definately be sourcing a new hanger if they are cheap as it's what I am use to.
Thanks so much for your help!
