Advice on Brake Pads for Carbon wheels
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,183 Times
I hope some of you can offer some advice regarding a high quality brake pad that you have used on your upgraded CV ride with a carbon wheel up/downgrade.
I am planning on using some CF wheels on my next build and see a wide range of choices and prices...what have some of you used with moderate cost and good results, are there some brands to stay away from?
Are there good ones that can replace the pads in my older campy brake holders or do I have to buy pads and holders?
Thanks, Ben
Thanks, Ben
Quoted: 378 Post(s)
Liked 1,412 Times
My yellow Kool Stops are soft. "They call them Mellow Yellow" (Jello) I use them on Zipp 343's (dimpled 303F/404R).
They make a heck of a whistling noise, and they wear quickly, very quickly. I had nothing to compare them to at the time.
My blue Shimano seem good, came with Dura Ace C35 full carbon wheels, and that's what I use them on.
I have red/black Campy that seem like normal pads, so I’ve not mounted them. They did not come in an unsealed package, so I'm not 100% sure they are for carbon.
I want an unopened package to say “for carbon” on it. I worry more about the wheels than stopping.
I was going to try @ldmataya's idea farther down this thread, but I'd already typed this in...
Quoted: 1649 Post(s)
Liked 845 Times
Corima made brake pads supposedly specific to carbon rims/wheels.
The pads feel more like a synthetic cork than rubber. I have a set from them to go with my Zipp carbon/kevlar Predator disc rear wheel, but I have not tried them out yet as the wheel is for a still in progress funny bike project. I suspect they wear out fast as the pads feel quite light and delicate, compared to regular rubber based brake pads.
Quoted: 2953 Post(s)
Liked 3,106 Times
I've been pleased with the blue pads I got from Williams. Unfortunately, they're no longer available.
Non omnino gravis
I've been quite pleased with Token Brake Pads for carbon (also available for Campy holders.) Less than half the price of something like Swisstop. Only been using them for about 1,000 miles, no complaints so far. Quiet, easy to modulate, seem to be relatively slow-wearing.
Liked 2,183 Times
Thanks to all for the recs.
Best, Ben
Best, Ben
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,132 Times
I have a set of Zipp 202 and 303 wheels. One bike has the Campy red pads for CF wheels and the other has Zipp pads (Gray). Both work nicely and have held up pretty well. I think I like the Campy pads a little better, but it might just be I like the 202’s better. The instructions on the Campy pads give all kinds of warnings to not use on anything but Bora wheels, but not an issue for me.
I have a set of no name cheapo pads I got from Amazon, that I used on my TT bike, theorizing that I would never be screaming down technical descents on it, and they worked fine but I only used them for about 100 miles and the bike is consigned to the indoor trainer now.
Quoted: 3464 Post(s)
Liked 2,834 Times
C&V and carbon wheels, you mean wood rims right?
Cork for those most often, in the thickness you want of probably going to be ground and resin infused. More predictable performance.
Bikes: Numerous
Liked 3,132 Times
Shhhh . We're trying to keep this on the down low. Don't tell Dad!
Quoted: 2354 Post(s)
Liked 2,870 Times
old maybe....not classic
Liked 2,183 Times
Speaking for yourself? couldn't resist...Just Joking
Thanks all for taking the time to reply..have a good one, Ben
Liked 2,870 Times
Yep that is the truth......as my 22 year old reminds me on a regular basis......
Likes For squirtdad:
low end rider
Bikes: 80's. hoarder.
Quoted: 56 Post(s)
Liked 43 Times
Speaking of old carbon wheels.. Shopping around I've seen warping, not sure if its from downhill brake heat or just natural aging. I'm guessing ambient ozone and UV are what "age" the old carbon out eventually if abuse doesn't get em.
Quoted: 378 Post(s)
Liked 1,412 Times
Showed up at a bike trail dedication on one, and a group of young, fit bearded guys grinned and nodded.
I had cred! When they blew by us later, it was "hey, ya, cool Y, dude."
To that generation, a Teledyne Titan is just an old grey bike.
Likes For RobbieTunes:
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
So, with the "best" pads, how is emergency braking in the wet with carbon rims?
Let's say
1 is wet steel rims with dried up old pads - don't brake, swerve!
5 is wet alloy rims with old pads - squeeze for all you're worth and the bike will eventually stop, its just scary
8 is wet alloy rims with salmon Koolstops - weak braking for the first wheel revolution and then good braking, enough that you have to modulate to avoid front lockup
10 is wet discs - good braking right away, modulation required
Where are wet carbon rims with the best pads?
Let's say
Likes For jyl:
Liked 845 Times
Also try to get only old wheels that had minimal use/brake track wear, as a lot of old CF wheels were retired by their owners mostly because if this wear, which can compromise the wheel.
Tears and cracks on the skin of solid disc CF, wheels are also deal breakers.
One thing I would really check too, is the integrity of the aluminum hub attachment to the CF disc. Any sign of damage or looseness here is of course, not good.
Liked 3,106 Times
so, with the "best" pads, how is emergency braking in the wet with carbon rims?
Let's say
8 is wet alloy rims with salmon koolstops - weak braking for the first wheel revolution and then good braking, enough that you have to modulate to avoid front lockup
where are wet carbon rims with the best pads?
Let's say
low end rider
Quoted: 56 Post(s)
Liked 43 Times
Another question. What do you guys with carbon rims do for your valve lock nuts? Am I seriously supposed to torque down that metal lock nut into my nice composite rim to secure it? SERIOUSLY? Or if not, how do you secure the valve?
Quoted: 392 Post(s)
Liked 49 Times
Why use the lock nut at all? The valve isn't going anywhere if the tire is inflated.
Likes For jyl:
Non omnino gravis
Liked 3,106 Times
I don’t use valve nuts with tubes.
