How to avoid making a mess when storing a commuter winter bicycle indoors?
Quoted: 7 Post(s)
Just curious what other winter cyclists have tested and kept when storing a bike indoors between winter work days.
So far I've just carried the bike up to my 3rd story apartment, placed it down on a laid out towel immediately next to the front door. Thinking of putting a tarp underneath the towel to prevent moisture from seeping into the wooden floor of the apartment.
Any simple, inexpensive, and practical ways to avoid creating a mess in your indoor storage space when your bike's tires are filled with snow, salt, & grime?
Wash off outside with 2 water bottles filled with warm water. Hang in shower and rinse off. Put some carpeting down over a waterproof layer.
aka Phil Jungels
Yep, the carpet remnant over a piece of carpet runner (the vinyl kind) works great. Rinsing off in the tub or shower also helps, but keep stuff lubricated so rust doesn't creep in.
Bikes: 1997 Kona Hahana Race Light, 2010 Surly LHT(deceased), 1999 Rocky Mountain Turbo
Quoted: 86 Post(s)
Those plastic boot mats are nice.
I like the carpet remnant idea to keep it from sliding around.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Park it in the garage....floor drain takes care of the rest
If you have a tile floor somewhere, that is a good place to store it until it dries. After it dries you can put it outside on the porch with a cover on it to keep it out of the way. Or in the cold storage shed if you have one.
Quoted: 4894 Post(s)
Liked 4,064 Times
I have used 6' clear plastic carpet runners. I've always had them on carpet where they conveniently indent to permanent water catching basins under each wheel which are usually dry by morning. Perhaps you could get that effect with a matching piece of carpet foam under the runner. (I'd bet a carpet place would hand you a good scrap for the job.)
(Tested in the cities of Alameda, CA, Ann Arbor, MI and Seattle, WA. It saw lots of salt in AA. I lived in apartments with no garage and no outside hoses. My commuters got put away wet/salty.)
Ben
Ben
I have a garage now nd have to remind myself to bring the bike inside at work to give it the cleanup & lube periodically.
Cardboard moving boxes for me. Those absorb moisture and dry by themselves and are thick enough to not let moisture go through.
Bikes: 2015 All-City Spacehorse, 2014 Specialized Allez Race, Mid 80s Takara Acknowledge Fixed Gear
Take off the wheels and put your bike on one of these guys: 4' x 6' Pig Mat w/Lip and Handles | QC Supply meant for pigs, great for wet camping or cycling gear
was using hall way rugs from big lots. interior design isn't my strong point so I dont care if the rug matches the carpet.
Now that I have 4 bikes in my dining room I have a bunch of area rugs in there under the bikes.
Bikes: Various "modded" eZips and multiple econversions
Used to use a multi-angled toilet brush to knock off all the heavy stuff.
Got a 1 gallon pump up garden sprayer at local thrift store. A quart of hot water and spread spray pattern makes quick work of the snow and salt. Then I park it on an old carpet remnant.
Just don't leave an ice puddle where others will be walking.
Note: Paste waxing your frame helps ice and snow clean off easier ... good for your cables too,
Quoted: 5234 Post(s)
Liked 3,609 Times
Bikes: '09 Trek 2.1 * '75 Sekine * 2010 Raleigh Talus 8.0 * '90 Giant Mtb * Raleigh M20 * Fuji Nevada mtb
I used 2 ft wide tarp, long enough to go from the door to the back of a room where the bike was stored. Wheel the bike in, roll up the excess tarp right up to the bike. All the above floor mats, $1 carpet remnants work well under the bike. I did this in my house from winter riding when I was bringing the bike inside.
FB4K - Every October we wrench on donated bikes. Every December, a few thousand kids get bikes for Christmas. For many, it is their first bike, ever. Every bike, new and used, was donated, built, cleaned and repaired. Check us out on FaceBook: FB4K.
Disclaimer: 99% of what I know about cycling I learned on BF. That would make, ummm, 1% experience. And a lot of posts.
