Thread for Specialized Sirrus
#1476
It looks like the cap is simply integral to the stem itself. So you'd pop the stem on top of the steer tube with the appropriate number of spacers to keep it off the top of the steer tube, then you'd run the center bolt down enough to preload the bearings, then you'd tighten the side bolts.
The only real benefit to the standard "through hole" design of most stems is you can lower them on the steer tube and stack spacers above them. You can't do that with Specialized's stem, but it looks like there's also no reason you couldn't replace the stock stem with any other stem of your choosing (including a "through hole" stem that uses a separate cap). Most stems do not come with a top cap, so you'd need to buy that separately.
Thanks,
Mike
#1477
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Edit -- I didn't remember that you don't have the bike yet and are contemplating purchase. I think the best course of action (absent positive confirmation here) is to either call Specialized and ask or visit the bike shop to see if they have any such models with that style stem and see if they'd pop one off for you to see if a standard stem will fit.
Likes For hokiefyd:
#1478
Pedaling Curmudgeon
If it has future shock, you should be able to run any non-proprietary stem but the bike should have come with a bushing for that purpose that allows a conventional 1-1/18" stem to fit over the future shock assembly. At least that's what came on my 2021 Future Shock 1.5.
Likes For GrizzledBastard:
#1479
Thanks for the info guys, I want to be educated about the bike. I'm not sold on it unless the price gets (much) better. I'm more interested in a new Sirrus x 5.0.
Likes For LazyMike:
#1480
I took a Trek FX Sport Carbon 4 for a ride at the bike shop to compare to my nephews Sirrus X 5.0 which admittedly I took a longer ride. I just think the Sirrus felt like home, a perfect fit.
I already have a road bike, would really like a comfortable fatter tire ride for the up coming season. I want a new red one when they are available.
Likes For LazyMike:
#1485
Likes For Bliip:
#1486
Likes For Bliip:
#1487
More upgrades done.
Did the Gator Hardshells a few weeks back.
This weekend: SRAM Force 1 Carbon Cranks. It was an easy swap since I already had Apex 1’s and the GXP BB already done at the LBS for the old recall.
Love how they look. Now if it would stop raining and warm up a bit.
Now I love a new wheel set...any suggestions? Not carbon...just a good set that doesn’t break the bank. Maybe DT Swiss ER 1600’s?
Likes For hugorodrigo23:
#1488
#1490
Sirrus X 5.0
Hi everyone, this is my Sirrus X 5.0, it is my main commuter bike. I upgraded the wheels and saddle. I also added some must have accesories, lights, bell and bottle cages. I will try to post the upcoming upgrades ✌🏼
#1491
2019 Sirrus expert carbon - freehub parts/replacement
Does anyone know what freehub I can use for this? The only identifying marks don’t return any results. It’s a shimano cassette.
my cassette was wonky so I took it off and the freehub was loose. I removed it and cleaned it but noticed a few ball bearings weee missing and the plastic cover was ripped a little. I can’t find anything online that names the freehub
wheels are axis expert and hubs just say axis
any help appreciated!
thanks
russ
thanks
russ
#1492
Help w/ Brooks saddle on Sirrus X 4.0
I purchased the 2021 Sirrus X 4.0 a few months back and am enjoying the heck out of the bike except for the saddle. After 15-20 miles each ride, I'm hurting you know where (it's ridiculous that Specialized can't put a comfortable saddle on an otherwise quality bike). Since I am a novice when it comes to cycling, looking for some assistance from the forum with choosing the proper Brooks Saddle.
Background: I do primarily 60% suburb riding on paved trails, 35% city streets, and 5% gravel trails. I wish to purchase Brook's traditional old school leather product line (aka B series) instead of the Cambium saddles because of reports of Cambium models showing no mercy tearing up pants/shorts/bibs which will then need to be replaced on a regular basis per many users posting on the Internet. I'm a 6 ft male weighing 165 pounds.
Questions:
(1a) Is the seat post for my model a single or double rail saddle? I'm guessing that it's a single rail since Brooks uses the term "modern single rail ". If that's the case, I would get the B67 (as oppose to the B66 which is a double rail clamp) but I would like to get confirmation here.
(1b) Brooks say if you ride in an upright position, get the B66 / B67. Given the Sirrus X 4.0 is classified as a hybrid, I'm assuming I am riding in an upright position since there's no drop bars. Need confirmation here.
(1c) I get confused because Brook's marketing further says choose the B66 / B67 if your seat is higher than the handle bars. When my LBS fitted me, the seat height happens to be equivalent (or just very slightly lower) than the handle bars. If that's the case, maybe I should get the B17 which is the old classic, more neutral saddle.
(1d) The B66 / B67 comes with springs which I'm not sure I really need given how amazingly effective the Sirrus 4's Future shock system is when I ride . The B17 doesn't have those springs. Given my riding style, not sure if I really need those springs.
My gut tells me to get the B67 but I would like to get input from more experienced / knowledgeable riders. Also, am I missing something while doing my research on saddles? Saddles seem to be so subjective!!
Questions:
#1493
New wheel/tire combo for the Sirrus X
I’m riding my Sirrus X mostly on paved roads and I felt the Pathfinder tires where to much, so I installed back the GP 5000 TL 32mm. The bike rides great with this combo, light and fast, I think the only thing that stops me from doing faster average speed during my commute is the wind, because of the riding position.
#1494
Quoted: 2975 Post(s)
Liked 1,182 Times
#1495
Also, would you please elaborate on your experience with the Pathfinders? I ride mostly on pavement too so I am wondering if I am missing something.
Thanks!
#1496
Friend, you didn't say which Sirrus X you have, but it looks like it doesn't matter. Can you confirm that the Sirrus X wheels are tubeless ready? I have an X 2.0 and your change interests me.
Thanks!
Thanks!
Pathfinder tires are nice, they are not heavy at all for a 38 mm size, but they are heavier and slower that the GP 5000 TL in 32 mm. I do miss them on the 2 km gravel path that my commute includes, but overall, the advantage of weight, speed and rolling resistance with the 32 mm GP 5000 makes them better for my daily commute.
#1497
Bikes: Specialized Sirrus 6.0
i just purchased the Brooks C19, with the middle cut out, for my Specialized Cross Tour Elite. Its a polymer seat and extremely comfortable. Much better than the stock seat
#1498
Quoted: 1581 Post(s)
Liked 1,189 Times
Finally some good news on the parts front: my brake upgrade for my Sirrus (X Comp Carbon, now the X 5.0) has been ordered, and should be in the shop in April. This is step 1 of my 2-step plan: brakes > wheelset/drivetrain. Brakes first, because the stock ones have never been consistently quiet and because I just want nice ones! So, all XT: flat-mount calipers, resin pads, Ice-Tech rotors, levers. Wheelset/new XT (12spd) drivetrain to follow in due course.
Likes For badger1:
#1499
Bikes: Sirrus X 5.0
Suspension seat post
Hi Everyone,
Has anyone moved to a suspension seat post? If so, which did you choose, and would you recommend it?
Thanks!
Thanks!
#1500
This was before I got the Sirrus.X/Allez. Sorry I couldn't help more.
