Can someone recommend me some new tires?
Hey guys, I need to order some new tires for this season, but I'm still new to cycling and have no idea what to get. I bought a Trek 1.2 last year, and the tires on it are fine, but they're nearly impossible to remove/install. The bead is so stiff and makes changing on the road practically impossible. So I need some new ones.
I'm a big guy, 270ish, so I'm not sure if that should be a deciding factor when it comes to tires. I'm just looking for something that is durable and will last long and not puncture easily.
I'm a poor kid saving for college, so I can'y spend too much. Preferably something like ~$30/tire, but I'd be willing to spend a bit more if it was worth it.
Thanks in advance!
Thanks in advance!
Bikes: 2006 DBR Podium 2
I run conti gp4000s (1 puncture) and gatorskin(0 puncture). I haven't been running them very long though. Both are kinda pricy. I used ultra sport before that, and NEVER had a flat due to puncture on them. You might not be as lucky though.
PS. I am about your weight.
Socrates Johnson
Being somewhat heavy myself, I found I flatted like crazy on skinny tires so I run wide tires on all my bikes (between 28mm and 35mm). I'm not exactly sure how wide of tires the trek 1.2 can take though, I would guess 28mm but I'm not sure.
(I use Schwalbe Marathon Plus's on all my bikes because I hate dealing with flats, they're about $40 each. They're probably slower, but the convenience is worth it for me)
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Guessing you may be limited to 700 x 23's
25's may or may not have enough clearance.
https://theultimatefitchallenge.files..._blackred1.jpg
Fred "The Real Fred"
Quoted: 7 Post(s)
I guarantee you that you can run 700x25's, which you should run at your weight. It'll give you a far better ride without sacrificing your "speed."
Your current tires are hard to get off because they're likely a steel bead instead of a folding bead.
In your price range?
I'd recommend the Hutchinson Atom:
https://www.performancebike.com/bikes..._1088178_-1___
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
700x25 contis, Michelin Pro 3 if you shrink a bit.
Liked 6 Times
700 x 28 Continental Gator Hardshell. And if you're having difficulty with the installation/removal,
1. replace the stock rim tape with something very thin yet strong, such as Stan's Yellow Tape stretched on super-duper tight like the instructions say.
2. when removing, gently apply "scoopage" force with a tire lever while pushing the bead into the middle of the rim elsewhere. The slack you generate will get collected at the tire lever. Now angle the lever about 45 degrees and slide it along the rim.
I've always found steel bead tires to be easier to get on and off. Steel stretches, kevlar doesn't. But I still stick to folders for road bikes. The easiest I've had to mount were Panaracers. Continentals are usually not bad, but Michelins tend to be tight.
I have no experience with Trek/Bontrager rims, but that might be your problem and not the tire. Maybe somebody else can chime in.
And lastly, do you have much practice at changing tires? It gets easier. The tires themselves tend to loosen a bit the longer they're on.
Bikes: Litespeed Liege, Motorola Team Issue Eddy Mercxk, Santana Noventa Tandem, Fisher Supercaliber Mtn. Bike
Quoted: 14 Post(s)
Liked 11 Times
best deal around for big guys are the Vittoria Rubinos - wire bead.. work fine with 200+ guys and price is right with lots of colors.. Buy mine here, 46.00 / pair and free shipping. They have 700x23 / 25 and 28's depending on what you need.
https://www.ebay.com/sch/bellsbikesho....c0.m270.l1313
Liked 6 Times
I work at a Trek dealership and can verify 28s work fine on the 1-series frameset. A small 32 might fit, but could start gnawing on the frame with wheel flex (or certainly with a broken spoke). Fat 32s will actually hit the rear of the seat tube above the FD clamp and almost certainly gnaw on the fork blades.
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
First go to eBay, then go to nice bike tires .com, that's an eBay store. I get the cst top speed tires with kevlar beads for $52.00 a pair shipped. They roll great, low resistance, corner well, and are very durable. They have a kevlar belt for puncture resistance.
Liked 1,245 Times
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
I am 235 and 6'-1" so I am close. I used the Michelin Pro3 Race, Service Course on my old R500 and got excellent use out of them. I'll probably use either the Pro4 or stick with the stock Schwalbe Luganos on my new bike, depending on how they work out.
Semper Fi, USMC, 1975-1977
Thanks for the replies, guys. So from what I've gathered, a larger tire than 23 is the way to go. And it sounds like my 1.2 will work with 28s, so I think that's what I'll do. Or 25s should be good too, right?
If the Ultra Gatorskin and Gator Hardshell are as durable and long lasting as it says they are, then I'm going seriously consider them.
Also, just to clarify. Folding tires are easier to install than the non-folding?
Middle-Aged Member
Bikes: Bianchi Infinito CV 2014, TREK HIFI 2011, Argon18 E-116 2013
Quoted: 24 Post(s)
Folding tires are easier for me to install over wire-bead... some said the wire stretches: I have never noticed that!
either 25 or 28 should be plenty comfortable ride.
Ahh, I see. Thanks. The stock tires are insanely stiff. I was worried about getting a flat on the road because I knew I wouldn't be able to change it.
What do you mean by comfortable? I think I'm far too new to cycling to even notice or care about that. Haha.
