Go Back  Bike Forums > Bike Forums > Fatbikes
So, I buy a Soma Sandworm frame...
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 02-16-18, 07:23 AM
Abu Mahendra
Bikes: In service - FSIR Spin 3.0, Bannard Sunny minivelo, Dahon Dash Altena folder. Several others in construction or temporarily decommissioned.
Quoted: 897 Post(s)
Liked 17 Times in 17 Posts
...mate it with the Surly Krampus fork I have, and have two wheelsets, a 26"+ and a 29"+ wheelset for it. What's wrong, if anything, with this one-frame-two-wheelset approach?
Abu Mahendra is offline
Old 02-16-18, 10:41 AM
FrozenK
Quoted: 175 Post(s)
There is a significant difference in diameter between 26+ And 29+ tires. So the 29+ may not fit on the frame, or the BB may be too low with the 26+ (or too high with 29+)
FrozenK is offline
Old 02-16-18, 01:39 PM
Leebo
Bikes: Kona Dawg, Surly 1x1, Karate Monkey, Rockhopper, Crosscheck , Burley Runabout,
Quoted: 854 Post(s)
Liked 111 Times in 66 Posts
Front fork will be too tall? What is the A-C spec for the frame. Will the krampus fork fit a 26 x 4.00 -5" tire? Me thinks not. Get a fat fork?
Leebo is offline
Old 02-16-18, 05:44 PM
Abu Mahendra
Quoted: 897 Post(s)
Soma specs the frame up to 29x3.0, same spec as the Krampus fork. Soma also specs the frame up to 26x4.0. Obviuosly the 26" wheelset would need much wider rims and tires than its 29" counterpart.
Old 02-16-18, 05:53 PM
Abu Mahendra
Quoted: 897 Post(s)
Soma specs a fork like the Krampus fork for the Sandworm frame, so we are all good as far as that goes.
My calculations show that a 26" wheel with a 4.0" tire has a radius of about 38cm while the Krampus axle-to-crown dimension is 48cm, so we are all good as far as that goes too.
Old 02-20-18, 12:34 PM
Leebo
Quoted: 854 Post(s)
You are mixing parts and specs. A 26x4.8 tire will not fit in a 29er x 3" space. Are you looking to only run a 29 x 3 and not fat? What you want to measure is the A-C spec on the sandworm frame. Seems the krampus fork will be too tall and result in handling issues. Check with sandworm.
Leebo is offline
Old 02-20-18, 12:59 PM
Abu Mahendra
Quoted: 897 Post(s)
Am I?
No one here, including myself, ever said 26x4.8 will fit in 29er x 3" space. Why did you bring that up?
Once again, the Krampus fork, A-C and all, is within the specs recommended by Soma.
Old 02-20-18, 01:04 PM
Leebo
Quoted: 854 Post(s)
You posted it in the fat bike forum? Not the plus bike forum. Carry on.
Leebo is offline
Old 03-03-18, 11:07 AM
Derekve
Derekve's Avatar
Bikes: 2015 Specialized Sirrus Base, 2018 Jamis Renegade Expat
Quoted: 23 Post(s)
The sandworm frame should fit 29x2.6 tires correct? Considering it can fit 29x3.0.
I'm considering this bike because of its versatility in tire sizes, steel frame, and as my one bike mountain bike
Derekve is offline
vdub6541
Mountain Biking
1
04-18-17 05:37 AM
Andrew_Henry
Mountain Biking
0
06-03-14 01:06 PM
giantcfr1
Mountain Biking
6
06-23-13 03:21 AM
fullyfixed
Singlespeed & Fixed Gear
11
10-31-10 11:51 AM
schpetra
Bicycle Mechanics
10
08-03-10 03:45 AM
