Garmin Edge 510 inconsistent speed and distance readings
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
My 510 is paired with a GSC 10 Speed/Cadence sensor which has been working well until lately. The battery in the sensor was replace a couple of months ago. The magnet interface distances are within spec. I always run my Garmin paired to my Android smartphone and run the Livetrack feature to keep my wife happy. The Garmin unit automatically uploads activities through my phone as well.
Lately speed readings on the 510 have been very erratic. When I get done with a ride, distances on Garmin Connect for known rides are less than they should be. But here's the weird thing, when my rides are pushed to Strava the distances are more in-line with what I know they should be (with a differential between the Garmin and Strava of about 9% for the same activity). Here's an example:
Garmin Connect
Strava
So what's going on and how do I fix it? I'm guessing the problem is somehow with the GSC 10 sensor?
Garmin Connect
Strava
Bikes: Space Horse Disc, Domane SL5 Disc
Quoted: 64 Post(s)
Liked 29 Times
Do the distances on Garmin Connect match what your 510 displays, or are they different too? I have the 510 and same sensor, and I have only noticed very small differences in distance between GC and Strava. Nothing like the examples you posted.
Quoted: 1186 Post(s)
Liked 289 Times
Interesting! I just looked at my data on Garmin connect and Strava and the distances seem to match up perfectly.
i would export data from Strava and Garmin connect and compare the two rides in Excel. You should be able to see where the problem is. PM me if you want some assistance looking at the files.
I'm curious as I was contemplating getting a 510. I use an 800 and have a cadence sensor but don't think it's active as I also have an SRM which provides cadence. GPS speed is good enough for me.
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
My real concern is not the discrepancy between Garmin and Strava, it is the erratic readings on the device. I think when I get that taken care of the rest will fall into place.
Thanks for your response!
Vain, But Lacking Talent
I'm going to take a stab an guess that you did this ride using the route feature on the 510. There was a known issue for the 510 being about 10% short on distances when used with a course file. I thought they fixed it in a later revision, but I haven't been on the Garmin forums in a while. I also have the 510 and noticed the problem when I used the course feature, but rarely use it now, so it hasn't been an issue.
I love my Garmin, but they seem to not be able to execute fairly simple fixes. I think it was something like 4-5 updates before they finally nailed it down.
However, the issue with using a course was buried in the file itself where there were just big gaps in the data. It also affected average speed. Perhaps Strava is using it's own distance calculation based on maps vs. what the file itself says, or some other similar correction.
Here are the updates:
Garmin: Edge 510 Updates & Downloads
Looks like it was supposed to be fixed in version 2.9, but I forget when the last time I did an update was.
Stand and Deliver
Bikes: Cannondale R1000, Giant TCR Advanced, Giant TCR Advanced SL
Garmin Connect
Strava
Garmin Connect
Strava
It could be the battery life is already exhausted, so try a new battery. Another possibility is the sensor might have been slightly bumped out of place. It might still be picking up your cadence fine, but may be getting intermittent readings from the wheel magnet. In either case, if signal is lost, it will then depend on gps speed unless you have that turned off.
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
No Courses used.
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
Good responses--thanks!
BTW, the GPS and sensor unit have been in use for about 18 months.
You must have been flying around the ride. I see on Garmin Connect your max speed was 120 mph. On my 510 Garmin Connect an Strava are almost identical. This link shows my ride today.
Cycling Texas | , Texas | Bicycling, Texas
I also use 2 other programs: SportsTrack and Golden Cheetah. SportsTrack is slightly below GC while Golden Cheetah agrees with Garmin Connect except for average speed. I also upload to RideWithGP.com to backup. This site agrees with Garmin Connect too.
You might want to consider a hard reset and since it was working and then went off track.
I'd love to know more about how to analyze this data in Excel, but don't have enough postings to PM you (I tried!). Could you PM me and clarify? FYI I'm very familiar with Excel, so no help needed there. Just uncertain how to get data off Garmin in a format Excel will read. Thanks!
Bikes: 2001 Trek Multitrack 7200, 2104 Fuji Sportif 1.5
Quoted: 18 Post(s)
I have opened a few .fit files as maybe "csv" files , meaning comma separated values ? You can read the data values, I was looking for a speed value in a trainer road file actually.
Liked 289 Times
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
I changed from "Smart Recording" to 1 sec. Data shown on Garmin Connect is same as what is displayed on the Garmin unit. I carefully went through the GSC 10 sensor/magnet interfaces and that is all good. I'm beginning to believe the sensor is fine and that the problem is with the GPS unit.
Still reading slower speeds and shorter distances than what is accurate and what is displayed when uploaded to Strava. Here is last night's ride:
Garmin 39.54 mi Distance, 2:26:55 Time
Strava 43.6 mi Distance, 2:27:21 Time
While riding, speeds seem low in the 10-20mph range, but more accurate in the 20-30mph range (not including the occasional momentary outlier).
Quoted: 18 Post(s)
I have looked a little trying to figure out how to export files from Garmin connect, need to get on that, and look into smart recording too :-). I want to email files to cyclemeyer and better to start sooner rather than later :-). I put like 3 months worth in and it was tedious :-)
Quoted: 18883 Post(s)
Liked 10,646 Times
The FIT file your Edge records has a list of time/position/hr/power/whatever else covering your ride. But it also has a summary of all that data. I think that summary is what the device calculates and displays as you ride. Anyway, Strava ignores the summary and recalculates distance from the list of data points, eg by adding up the distance between each of them. It's not uncommon for the raw data to be pretty good and the summary to be a little off.
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
Master Reset Proceedure
gauvins
10
09-24-19 11:49 AM
johngwheeler
3
07-10-17 09:29 PM
