Campy peeps....crankset question
I have 2014 11s Chorus with a 5 bolt crank.
My question is if a new Chorus crank that has 4 bolt/arms will be a direct fit in my Ultra Torque BB and be compatible with the rest of my group?
I'm thinking it would, but want to be sure.
I currently have a compact crank and want to find a 52/36.
Thanks in advance.
Brandon
Thanks in advance.
Brandon
Cheaper option would be to buy the 52/36 rings for the five bolt compact crankset. You can find them on ebay.
Mostly Harmless
Bikes: Have two wheels
Quoted: 13718 Post(s)
Liked 4,532 Times
Ah very cool! Thank you.
Think it'll be okay to have a 34/52? Also, how do you remove the bolt behind the crank arm?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Thanks in advance.
Brandon
Thanks in advance.
Brandon
50/34 FWIW but here you go...
NEW Campagnolo Chorus CT UT Carbon Crankset: Compact 50/34T, 172.5mm, 11 Speed - Bike Recyclery
Maybe they have a mid crank for you if you browse around. I have purchased from them with no problems at all. They are very helpful over the phone.
-Tim-
The older, better looking cranks were 110mm BCD for the compact and 135mm BCD for the standard. For the 110, the 50 goes with the 34 and the 52 goes with the 36.
Got it. Well then if the BCD is the same, why can't you interchange the chainrings? Thanks, and sorry the questions, I just want to understand.
Brandon
No clue. I wanted to do the same thing - run the 52 with a 34. I was told it won't work. When I bought the rings, the description said they had to be used together. I switched both my bikes from compact to mid compact.
Quoted: 1975 Post(s)
Liked 232 Times
the jump between rings is too big and the shaping and ramps on the big ring are positioned for the respective small rings. Why do you want 52/34? If you need a 34, then you probably don't need a 52.
Advocatus Diaboli
Quoted: 4738 Post(s)
Liked 1,533 Times
EDIT: I should say I've wondered the same thing. Since I've gotten a bit better at flats/rolling hill riding average speeds, my 50 with 12-29 while OK, might be better with a 52 and 12-29, meaning that without cross chaining, I could more often just stay in the big ring before having to transition to the 34 ring when presented with greater hill degrees. At the same time, once in a while you still want the bailout gears a 34/29 combo can provide. Ie.. it's maybe why there're lots of Shimano riders with 11-32 cassettes.
Not to speculate too much, but perhaps his cassette is a 12-25, 12-27 or 12-29, and now wishes he had opted for the 11-25, 11-27 or 11-29. A 52 ring instead of 50 might be considered somewhat approximately accomplishing his goal, without necessitating a cassette change?
There is some truth to that for sure. I have a 12-27 cassette now and thought it might be cheaper just to get a chainring, but I'm discovering that that isn't the case.
Maybe I'll just put on an 11-28 Ultegra cassette and call it good. Probably still want the 52 up front though.
Liked 232 Times
Huh? Moving to a 52 would mean the 52 would be less useful and you'd have to shift sooner compared to a 50.
Liked 232 Times
Quoted: 252 Post(s)
I have never understood the people that say 52/36 lets them shift less up front, unless what they're really saying is they ride around more in the small ring, in which case older compacts like 50/36 would have served the same purpose just as well. With a modern cassette, usually bringing a chainring closer to 39-42t will mean you won't have to shift the front as much. You diverge from this to get lower climbing gears and higher downhill/tailwind/sprinting gears.
Liked 232 Times
Agreed. That was added after I posted, but this is why I run a 48/34 instead of the more standard 50/34. The only thing a 52 gives you is a higher high end. At the same time it does that, it also makes the low end and the closely spaced range of the big ring higher as well.
Quoted: 252 Post(s)
50x11 is a higher gear than 52x12, and for first generation 10-speed 11t cogs were not standard and basically only came with 11-23 cassettes. 11t became standard when compacts hit the scene. If you're strong enough that you break 40mph on a regular basis, then just swap your cassette. If that's just downhill, you might want to try refining your tuck.
Liked 232 Times
