FS: Various Dura Ace 7400 parts in mostly excellent condition
Quoted: 1136 Post(s)
Liked 650 Times
Update: everything is sold
These are Dura Ace 7400 components in excellent condition, with a couple of exceptions. If you buy more than one, I will take off $10 for each additional item you buy.
Bottom bracket - $15 shipped
113mm spindle. English threads I believe.
The worst of the group. The lockring is pretty mangled. The races are not pitted but a little bit of storage rust needs to be polished off them. The bearings look good as do the tapers. Comes with crank bolts.
Downtube shifters - $30 shipped
Lightly used. Anodizing is in great shape. Rear can be used in friction or SIS mode.
Brakeset - $50 shipped for the set
These are basically new. A tiny storage scratch on the bottom of one of the caliper arms.
Front derailleur, braze-on (comes with clamp-on adapter) - $35 shipped
Basically new. A little rubbing on the inside plate. Besides that looks unused. Comes with a 31.8mm clamp-on adapter if you need it. Pivots and spring are smooth.
Rear derailleur - $40 shipped
Short cage. A few scratches in the anodizing here and there, but looks basically unused. Pulley bearings are smooth, as are pivots and spring.
Quoted: 5888 Post(s)
Liked 3,472 Times
I'm tempted to buy the whole lot. I actually have the crank and the hubs oddly enough.
Are these 7 speed? And isn't this pretty finicky? Dura 7 speed has to be mated to a dura RD?
Liked 650 Times
According to a comment on Velobase (YMMV) the 7400 rear derailleur 6sp indexing only works with 7400 shifters, not with any other 6 speed Shimano shifters. Something to do with the cable pull.
Also I just looked at the brakes and they are labeled 7402 with a 39-48mm reach range, if that helps. They are both recessed nut. The rest of the components are labeled 7400.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
These should be 6 speed if trying to index. I believe Dura Ace 7401 was the 7 speed option.
And IIRC that color shift lever is the 7401 7s, but you should be able to see the speed under that d-ring, I think.
Liked 650 Times
DA 74xx 6,7,8s are all interchangeable, but only among themselves (except if you want to use any Shimano 9s in 8s mode, but that rabbit hole is outside this discussion).
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone, Cinelli, Merckx
Quoted: 430 Post(s)
Liked 476 Times
PM incoming re: BB
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
Hey, I'll take the whole lot (less BB if sold). PM me with shipped price and I'll send funds.
Thanks
Doc
Thanks
Doc
Brewsmith
Classic and Vintage Sales
13
12-21-19 12:46 PM
Brewsmith
12
09-12-18 06:02 AM
