Review of Microshift Adventx
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
This video talks about gearing on a gravel bike for hills and focuses on the Microshift AdventX. I posted it to the gravel forum but figured some folks might want to know about the AdventX that don't ride gravel. That section starts around 2:10 in the video:
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
What Microshift has done over the last 3+ years with their Advent line is really cool. Affordable, reliable, available- heck of a trifecta.
...but that exposed shift cable. I get it, they said they couldnt route it under bar tape without violating patented designs, but still- oof.
Likes For mstateglfr:
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
My kid with the AdventX conversion just replaced the rear derailleur with a "SHIMANO Deore RD-M5100-SGS Rear Derailleur - 11-Speed, Long Cage, Black" for $50 (Amazon). He managed to strip a few bolts trying to do maintenance on it (and broke my T15). He says this derailleur (nominally 11 speed, but the same pull ratio as the Advent X) actually works better.
The AdventX derailleur lasted about 2 years. (He is very hard on the equipment and rides a lot.) He found the high cogs in the cassette (Mk 1) wore rather quickly. Apparently they have addressed this in an Mk 2 version that will be available shortly.
Liked 3,443 Times
BTW he converted from 12 speed GX Eagle. He likes AdventX a lot better, and found the 10 speed more robust.
Bikes: Way too many
Quoted: 900 Post(s)
Liked 607 Times
I had a 1x10 Advent X and it certainly worked fine with no complaints. I changed bike and now have a 1x10 Deore and can't say I notice any real difference.
Sunshine
Liked 7,495 Times
Maybe that changed?
Liked 3,443 Times
He said that particular derailleur in the Shimano line (despite being 11 speed) had the matching (correct) pull ratio (see quoted text). My main involvement in this was to supply the money, but it is now working, possibly better than the original, according to him.
Sunshine
Liked 7,495 Times
Liked 3,443 Times
I'll have to ask him, but I had the impression it was unique to that particular model. (I'm not sure that is actually correct or even makes sense, but I am pretty sure he said something iike that. Since it was only $50, and I have bought him several more expensive derailleurs throughout the last 5 years or so, I didn't question it.) What I can tell you is the quoted model works as a drop-in replacement.
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
My own experience with Microshift is several years old at this point. They were the only ones to carry a front derailleur with a cage the size needed for the large ring on (our) Catrikes. It was pure junk over multiple replacements. I had issues both with the cage itself as well as the indexing in the shift lever. The rear derailleur on both bikes worked fine aside from a similar indexing issue. I don't own anything with that set anymore, but make a conscious effort not to purchase. I look at items equipped with it as a detractor.
To add to the 11 speed shimano working thing. It isn't a specific 11 speed shimano RD that has the same pull ratio. That specific 11 speed RD is made to work with up to 51 tooth cassettes while the others are rated for 42 or 46. I just bought one myself but I also bought a 11-51 cassette, keeping my hard tail 11 speed but still need them easier gears.
Liked 3,443 Times
Apparently (according to my kid) the newer 12-speed-hub-compatable 11 speed cassettes require a different pull ratio than the older 11-speeds, and that happens to match that of the AdventX.
I think that is consistent with what @Canker just posted.
Likes For CrimsonEclipse:
Quoted: 1109 Post(s)
Liked 1,200 Times
I have a gravel bike with Advent 1X9 speed and it works great and I like the shifting design (the levers) very well. Much better than Shimano and on par with Sram for my liking.
The only thing I would like is if they were compatible with Sram/Shimano 8 and 9 speed MTB and cassettes like other Microshift offerings. Not a big deal, but it would be nice.
