Tool marks on a new hub axle
Recently bought a Bitex BX103R hub due to endless troubles with previous ones.
Now discovered that it has a single tool mark/pit somewhere around the main hub bearings or closer to the centre as far as I can remember. Will have to take a picture sometime. Looks like something as a result of mishandling.
Since it looks fairly shallow and not overly sharp then I'm not sure if there should be any concern about stress risers/concentration?
Got too many other things going on so sending it back for inspection seems like a too much trouble at the moment.
Quoted: 6972 Post(s)
Liked 10,970 Times
Likes For Koyote:
Quoted: 3514 Post(s)
Liked 2,927 Times
It's a shallow mark on aluminium or stainless steel (non-magnetic) axle without any sharp angles as far as I can remember. Somewhere it was advertised as steel axle though.
Liked 10,970 Times
2) Your hubs have cartridge bearings, which will likely go many thousands of miles (or even tens of thousands of miles) without needing service.
3) Most people don't lube cartridge bearings. Just replace them.
And...
4) Your hub is probably just fine.
Quoted: 540 Post(s)
Liked 416 Times
Why hasn't the OP already completed the repair, so they can be cycling instead ranting on this thread that will not provide any help at all?
Do they require the support of strangers here to agree, so they can print it all out on hardcopy and provide it as "evidence" to the supplier of the new part?
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Likes For SurferRosa:
Discovered there is some knocking in the bearings. Probably due to threaded endcaps being finger tight only (without using allen keys) so decided to take it apart again.
Liked 2,927 Times
Not sure what exactly I'm looking at. Almost looks like a chip in some paint.
Likes For smd4:
Liked 2,927 Times
Quoted: 913 Post(s)
Liked 515 Times
From what I read that hub has several interchangeable "axles" available so you can easily swap the wheel onto different OLD bikes? Someone that actually sells or services these things can explain. Looks like a paint chip to me.
Can't see any paint there. With paint chip there wouldn't be an uneven surface.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
Liked 10,970 Times
Likes For Koyote:
Liked 2,927 Times
What I see in the single photo you posted looks more like a paint chip than just about anything I've seen. But like I said, I'm not exactly sure what it is I'm looking at--or maybe what you really want us to see. Maybe zoom out a little?
