Do U trust tire patch
Road runner
Hi, do you trust tire tube patches ??? I've never was home for a flat so just replacing tubes on the road is what I've done . But today I put a hole in a tube walking distance from home and have another 1 or 2 hanging around that I could patch.
Also doing a century this coming weekend and not sure about patched tubes???? Right now it's holding air and seems well but do they hold up over time**********
Should Be More Popular
Quoted: 22610 Post(s)
Liked 8,934 Times
A properly patched tube is as good as a new tube.
That means the "old fashioned" type, where you rough up the tube, apply vulcanizing fluid ("cement"), blow it until the shiny part appears dull, then put on a patch and rub the back of the patch with a coin (or your nail).
The self-stick patches are NOT permanent and are designed just to get you home.
I advise you to take a tube with you but also a patch kit in case you have multiple flats.
I save old tubes and once/year do a "batch patch" where I patch them all at once.
This.....
Cardiac Case
Bikes: Trek, Cannondale, Litespeed, Lynskey
VFL For Life
Bikes: Velo Volmobile
Quoted: 28642 Post(s)
Liked 1,858 Times
In tyre patches we trust.
Quoted: 551 Post(s)
Liked 277 Times
I don't want to anger the flat tire gods by making a comment on trusting tire patches.
Quoted: 3376 Post(s)
Liked 5,526 Times
The cold-vulcanizing patches, yes.
The self-adhesive patches, no.
But I do carry the latter just to get me home from a flat, where I put on a proper patch.
Bikes: '07 Trek 520, '09 Gary Fisher Triton, '04 Trek 8000, '85 Trek 500, '84 Trek 610, '85 Trek 510, '88 Trek 660, '92 Trek 930, Trek Multitrack 700
Quoted: 19 Post(s)
Yes. I carry a spare tube, but will often patch on the road so I can take a break.
"When I hear another express an opinion, which is not mine, I say to myself, He has a right to his opinion, as I to mine; why should I question it. His error does me no injury, and shall I become a Don Quixot to bring all men by force of argument, to one opinion? If a fact be misstated, it is probable he is gratified by a belief of it, and I have no right to deprive him of the gratification."
T. Jefferson
T. Jefferson
Quoted: 2952 Post(s)
Liked 3,106 Times
Those patches are tough. Sometimes I wish I could get a whole tube made of patch material.
Road runner
As long as I put it on I do
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Liked 8,934 Times
Quoted: 50 Post(s)
Patches rule. I just repatched 5 tubes this past weekend.
I do admit that even though none have failed for me, I get a bit paranoid about it, and what I ended up doing is actually removing the nonpatched tires from my bike and replacing them with the patched ones. That way, if I do flat on the road, there will be no question about patch failure.
Again, have never had a patch fail yet though, and I've patched about 15 tubes thus far in the past few years. However, I HAVE had 2 patches which were not placed on correctly, meaning I basically missed the hole, or only partially covered a linear larger tear, allowing air to leak from the free edge. That's what I'm really worried about - my own user error, as opposed to patch failure over a well covered hole.
Bikes: Fuji Roubaix 3
I trust patches, but I don't trust patched tubes that I have fixed. In my inpatients I have rushed the job and done a bad patch. Just need to do it a few more times so that I know I can get it right. (Maybe I shouldn't have said that, could anger the puncture fairy)
KingoftheMountain wannabe
Bikes: V.O. Pass Hunter & Specialized Hardrock
I'm sure my patches are fine, but normally I still don't trust them. I usually bring an extra tube on future rides just in case I did some shoddy work.
Bikes: quite a few
Yeah sometimes I take off the plastic and sometimes I leave it on. Doesn't seem to make much difference.
Fresh Garbage
Unless you amazingly applied just enough glue to match the size of the patch, you want to keep the plastic film on. The exposed excess glue will bond the tube to the tire, which sucks when you have to remove the tube and it ends up tearing.
i thought the plastic was extra safety for a fresh patch..
i love patches! a good friend just tosses blown tubes to the garbage cause he doesn't want to carry the blown tube...i grab the sucka!
