Help with bar tape - end plug hell
#51
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Why would you want to reuse bar tape?
#52
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,533 Times
#54
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
#55
I still don't see the need for any tape. I cut the taper across the tape so the 'finished' (non cut) edge is at the end of the bar, it looks way better this way. As soon as you start wrapping the tape holds itself, so no tape. Been doing it like this for over 20 years. I can't see how cutting the tape after wrapping looks good at all.
#56
Quoted: 804 Post(s)
Liked 2,985 Times
#57
Quoted: 1106 Post(s)
Liked 1,328 Times
I put a short bit of tight inner-tube on the bar, folded double close to the stem, before wrapping. After it's done at the top the inner-tube bit gets unfolded over the free end to hold it. Works great, no sticky,
Likes For oneclick:
#58
Occam's Rotor
Liked 2,331 Times
#59
while we are on this tape thing, i would like to put in a plug to a product that another forum member mentioned in another thread,
i bought a set and they are killer!
might be just the thing for the heavier tapes.
https://domaincycling.com/collection...ebar-end-plugs
i use Velox old fashioned tape over some nylon lined 3/16" neoprene on the top surfaces of the bar, learned this from Spence Wolfe at Cupertino Bike Shop back in 68.
i put the nylon side up to resist rain.
#61
I wrap a length of dental floss around the end of the tape, between the plug and the end of the bar. As I push in the plug, I tighten the floss. Pop out the floss, or trim it off. Works great.
#62
Occam's Rotor
Liked 2,331 Times
That's ok. I am already sick of it.
I just put mine on, so start the clock. At least I did not snap it in half.
It does, however, look like an amateur hack job. The Bontrager gel gooey crap I put underneath it surely doesn't help.
I used the Park Tool video tip for the bar ends. Now it looks like crap in a new and different way.
#63
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I've read from bike fitting articles and threads that excess padding can cause the hand discomfort it's trying to solve. The padding can encourage a tighter grip, putting pressure on nerves, and well as directly pressing on the places the nerves pass through.
I opt for thinner tape and gloves with grip but no padding (when i can). Loose hands!
#64
Bikes: lots
Liked 2,932 Times
#65
uncle sam i hear you on the padding, so we wrap the tape down pretty hard which gives the neoprene a whole new coef. of compression. in other words, this takes a lot of the sponge feel out of it,
been using this stuff for about 50 years now. a lot easier on the hands than cork tape etc,
#66
Occam's Rotor
Liked 2,331 Times
#67
Bikes: a few
Quoted: 92 Post(s)
Liked 379 Times
I just installed new Lizard Skins tape yesterday after watching the installation video from this website:
dressing up a vintage '83 Raleigh never looked so good. Now if the snow was gone I could do some riding!
Likes For tjfastback66:
#68
Bikes: lots
Liked 2,932 Times
#69
Occam's Rotor
Liked 2,331 Times
#70
Advocatus Diaboli
Liked 1,533 Times
After a fit of boredom, and watching a few different "how to" videos on bartape installation, I noticed for the bottom to top normal way, that it's not far from a 50/50 split on whether to wrap away from the bike, or toward the bike when starting. Does the answer on what's correct depend on how one routes the tape at the levers (type of figure eight, or using a strip)? Or does this really not matter?
#71
Quoted: 576 Post(s)
Liked 1,003 Times
The other day I was trying to wrap a Campagnolo hydraulic lever my traditional way: inside out from the bottom and reverse direction at the lever; and couldn't reverse the tape at the lever due to the shape and size of the lever body. The
shows the tape outside in from the bottom so I did it that way.
#72
The lizard skin video has some shortcomings. I put the clamp cover tape on first and cut it so there's no overlap onto the shifter body. I never have to use a figure eight wrap. The trick there is for the wrap to end closer to or slightly overlaping the lower edge of shifter body. Some shifters allow the tape to slip under the body slightly. Then, only a single wrap will cover everything. The other mistake comes near the end, where the angle is cut at the end. The tape should be held at the wrap angle and the cut made perpendicular to the bars, with the end of the tape just slightly narrower than the electrical tape and the length of the tape ending under the bar, behind the cables. Cut the proper length first, then the angle. Since I always use black tape, carefully applied electrical tape, with about 1/16 inch hanging over the edge of the bar tape creates a perfect edge that curls over the bar tape.
The plug installation is exactly what I do, except that it should be done after only a couple of turns. Is something doesn’t look right, that's the time to fix it.
#74
Quoted: 550 Post(s)
Liked 325 Times
I shift like I have ADHD and break rear shift cable strands within 2500 miles so I proactively replace them every 2000 miles. With housing going high friction in less than two cables I swap it at the same time.
Conversely, I get at least 8000 miles out of Cinelli cork tape before it tears.
So I save time and money only unwrapping to just past the shifter then rewrapping after I've installed new housing.
#75
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
This thread reminded me that I need to wrap the Spectrum. I've got off-white and yellow, and have watched a few videos on how to do harlequin wrap. If I get it right, there's a can of amber colored shellac to finish it off with. This is for top down and no tape.
I've been meaning to do this for a while. The reason I haven't is because I'm scared.
I did wrap the bars on my new Ritchey Swiss Cross V2 today. Easy peasy going bottom up and finishing with tape.
