94 Stumpy Headset Bearings?
Old 01-26-21, 12:23 PM
MarkusT
MarkusT's Avatar
Bikes: 2020 Giant Talon 2, 99 GT XCR 3000, 01 Titus Racer X, 80's PUCH Meteor MTB, 14' Crosstrail Elite, 92&93 Bridgestone OX-3, Marin Point Reyes (polished), 80's Mongoose Hilltopper, Giant Cypress SX, 96 Giant ATX 890, 94 Stumpjumper FS
Quoted: 24 Post(s)
Liked 11 Times in 9 Posts
Hi All!
I picked up this bike with a bum front Future Shock. Taking it off I see the headset has sealed tapered bearings top and bottom. Can I use any threadless shock up front or will the headset bearings need replacing? I have a RockShox Silver 30 I was thinking of using.
Thanks for any feedback!
Mark
File Type: jpg
MarkusT is offline
Likes For MarkusT:
Old 01-26-21, 04:28 PM
merziac
merziac's Avatar
Quoted: 4511 Post(s)
Liked 6,378 Times in 3,667 Posts
Pretty sure you might want to check with the MTB guys too.
Plenty here may have thoughts as well, but..........
merziac is online now
Old 01-26-21, 04:45 PM
wesmamyke
Quoted: 196 Post(s)
Liked 86 Times in 76 Posts
Firs thing check if it's 1", specialized held out pretty long there. Not sure what year my purple/green aluminum Stump Jumper is, but it's still 1"
Threaded, or threadless? If it's 1" and/or threaded you don't have many options. Even the cheap RST forks with steerers you can swap are long gone.
Any marking on the headset? The only headset I've seen with bearings like that are American classic threaded headsets. Same weird fiber reinforced bearings seals.
wesmamyke is offline
Old 01-26-21, 06:26 PM
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times in 601 Posts
I doubt you'll be able to fit your Silver 30. Isn't that a 1-1/8 steerer? The '94 Stumpy is a "1. At least mine is. Threadless but I have Chris Kings on it.
2cam16 is offline
Old 01-27-21, 06:03 AM
MarkusT
MarkusT's Avatar
Quoted: 24 Post(s)
Originally Posted by wesmamyke
Firs thing to check is if it's 1", specialized held out pretty long there. Not sure what year my purple/green aluminum stump jumper is, but it's still 1"
Is it threaded, or threadless? If it's 1" and/or threaded you don't have many options. Even the cheap RST forks with steerers you can swap are long gone.
Hi, it is a 1 1/8” Aheadset threadless headset.
Thanks!
MarkusT is offline
Old 01-27-21, 08:18 AM
2cam16
2cam16's Avatar
Then it's probably not just a Stumpy but a Stumpy FS or not a '94.
2cam16 is offline
Old 01-27-21, 09:48 AM
tricky
Quoted: 634 Post(s)
Liked 444 Times in 298 Posts
I think 2cam16 is onto something here. @MarkusT can you send full pics of the bike?
tricky is offline
Old 01-27-21, 10:57 AM
MarkusT
MarkusT's Avatar
Quoted: 24 Post(s)
Hey Tricky, yes, it's a 94 Stumpy M2 FS. The bike is on the stand apart, but I'll get some pics posted later today.
Parts on it:
*Coda suspension seatpost
*XT shifters, brakes & FD
*RD has no label but the color looks like an STX RC
*Specialized Future Shock (stripped canti stud hole and leaking oil)
*rear wheel was replaced at some point
*Titanium stem
*8 spd SRT500 twist shifters (never seen melted rubber grips before!)
My plan is to just set this up a a nice paved/hard pack trail runner.
Thanks!
MarkusT is offline
Old 01-27-21, 12:09 PM
tricky
Quoted: 634 Post(s)
Parts on it:
*Titanium stem
Thanks!
I believe the Future Shocks were rebranded Rockshox. If the headtube is indeed 1 1/8", then you should be able to just reuse the headset. You can slide the steerer of the RS Silver (I'm not familiar with that fork) into the old headset to verify that it's a fit. If yes, take the crown race off of the old fork, swap it over to the new fork, install and Bob's your uncle.
tricky is offline
Likes For tricky:
Old 01-27-21, 12:11 PM
tricky
Quoted: 634 Post(s)
btw, is the Future Shock the carbon version? Post a pic of that too! Those are cool. I haven't seen many pics of them.
tricky is offline
Old 01-27-21, 04:43 PM
2cam16
2cam16's Avatar
There you go! It's an FS. Just remember a more modern fork may throw your geometry off if it has more travel.
2cam16 is offline
Likes For 2cam16:
Old 01-27-21, 05:37 PM
krakhaus
krakhaus's Avatar
Quoted: 206 Post(s)
Liked 460 Times in 176 Posts
All of the M2's are 1-1/8", that headset should work fine. The Future Shock has Mag 21 internals, so you should be able to find some seals and do an easy rebuild if you wanted to. Especially if it's the carbon FSX. Those things were really nice.
You could also easily heilcoil the canti post, and it would probably be better than new.
krakhaus is offline
Old 01-28-21, 06:32 AM
MarkusT
MarkusT's Avatar
Quoted: 24 Post(s)
Thanks for the feedback All!
Here are some pics. Shocks aren't Carbon, unfortunately. I've pulled the top plugs off and there certainly isn't much to the guts!
File Type: jpg
File Type: jpg
File Type: jpg
MarkusT is offline
Likes For MarkusT:
Old 01-28-21, 07:02 AM
MarkusT
MarkusT's Avatar
Quoted: 24 Post(s)
Thanks Krakhaus. I've never done a shock service. I have a RockShox manual and it looks like special tools are required. 2Cam16 brings up a good point. If I'm going to use it as a paved/hard pack rider, maybe I'm better off sticking with a lower travel fork, like the original. I'll look and see if I can find a seal kit for a Mag21 and see what I might be able to do. Worse case is maybe my local LBS can do it. Is there a newer vintage shock that has more available parts?
Thanks!
MarkusT is offline
Old 01-28-21, 08:18 AM
sloppy12
Quoted: 166 Post(s)
Liked 252 Times in 147 Posts
Do you have to keep the shock? I would swap it out for something like a surly ECR fork. doesnt sound like you really need a shock for the use case.
sloppy12 is offline
Old 01-28-21, 08:25 AM
MarkusT
MarkusT's Avatar
Quoted: 24 Post(s)
Thanks Sloppy12, thought about that to. The ECR doesn't come in 26" and isn't suspension corrected, I believe.
MarkusT is offline
Old 01-28-21, 10:46 AM
sloppy12
Quoted: 166 Post(s)
Whats your axle to crown?
sloppy12 is offline
Old 01-28-21, 12:23 PM
MarkusT
MarkusT's Avatar
Quoted: 24 Post(s)
The original fork, fully extended is 16.5" - 42 cm.
Thanks!
MarkusT is offline
