New Track Bike, help with stuck nuts and rust & wheels
Quoted: 1074 Post(s)
Liked 295 Times
I thought that was clear enough by the way I wrote Finding a stem to act a donor for a new Allen bolt is usually quite easy.
Allen heads are nice in the way they allow for easy centering of the drill. Some finesse is required, but its not like you need to be a verified power tool genius or anything.
Quoted: 1088 Post(s)
Liked 1,024 Times
I shall try the allen socket and breaker bar combo. What is a drift?
Is the frame really that bad? What are you looking at that scares you? Is it the rust or the "custom" brakejob that the owner assured me it was professionally done. Not sure I understand what you mean by installing new cable routing bosses with a tube in between. Are you referring to the internal cable routing holes? Or the holes drilled for the brakes? Are you trying to say that the brake mounting holes or the internal cable routing holes can be stress points which will cause the frame to eventually fail?
I will try to look for a pro framebuilder but thats quite unlikely in my area. There is only really one pro framebuiler shop with a good rep but they have a long wait line and dont really do small jobs anymore. Most other options are "self taught" frame builders which I am equally scared to go to. Would there be alternatives?
Not certain what is meant by professionally drilled, it looks like holes in a frame to me. Being a shop tech if I dimpled and then drilled the frame you could claim it is professionally done but it wouldn't mean much. Today, and since at least my 88 DeRose there is a tube that can be run through the frame that your cable housing will run through, it starts and ends at a braze-on that helps hold the tube in place while reinforcing the holes in the frame since the tubing can be thin away from the butting. It also serves to seal the top tube so that water can't pour in the randomly drilled hole. That's just my view. Its a nice frame and should be more then worth riding but I'd want it done right.
Quoted: 194 Post(s)
Liked 204 Times
My only problem now is the stem is still stuck. I have tried the methods suggested except for using a drill since I couldnt find a shop with one. Right now I have added more penetrating oil and will try again tom to see if I can make progress. What solutions can I do if I cannot get the stem to free up? Its actually the right height so its ridable but I would it be good to get it painted with the stem and fork still on?
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
A drift is similar to a punch but instead of being used to make an indent for a drill bit or counter sinking finish nails its a bit harder and thicker to whack things with, in this case the end of the bolt that's let if the head comes off.
Definitely agree with you on the "professional" drilling. I meant that statement as satire since I wouldve have preferred those block type brake mounts to keep the frame as intact and original as possible. Im just a bit heartbroken coz I only got to ride her once since getting her and now im even more scared to do further damage.
That is a lot of corrosion in there, and I would be surprised (but pleasantly) if that bolt comes out without drilling. A few solid but careful whacks with a medium hammer of the head of the nut might be good to try and break down the corrosion bonding the bolt to the clamp, then apply the hex tool. I usually would use the hammer with the bike leaning against me to absorb the shocks unless I could find something solid to lean the other side of the clamp against.
SE Wis
Quoted: 2747 Post(s)
Liked 3,394 Times
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
The dropped
Liked 1,014 Times
I'm very confused by what looks like pitting on what should be an aluminum stem (right there under the bar clamp bolt). There also should not be any rust at the handlebar/stem clamp interface. Are the bars steel? A magnet is your friend here.
I would try a torch to the bolt (enough to make it too hot to touch) before I used a wrench with a hammer. If that clamp was assembled without grease, you could also be facing the dreaded aluminum weld that locks stems and seatposts inside bike frames.
Quoted: 645 Post(s)
Liked 797 Times
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 923 Times
All that rust scares me. There would be a lot of sanding, grinding and chemical treatments to that bike before I even thought about keeping it. That rust looks nasty.
Old fart
Liked 3,400 Times
Quoted: 1034 Post(s)
Liked 1,290 Times
I dont own an impact driver no, but I will happily visit a car shop to borrow theirs. Do I try to use the impact driver to unscrew the recessed nut or just destroy it completely. Can the stem still be saved if I destroy the nut? Its an NJS stem as well so I would like to keep it if possible. Would it be worth it to try with a drill to unscrew the nut first?
So I will try penetrating oil first, if that fails I will go the drill/impact driver route.
https://www.amazon.com/CRAFTSMAN-Imp...5227896&sr=8-5
Likes For phughes:
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
I've fixed up way worse rust then this.
On the rusted bolts you should use a penetrating oil first, and let it soak over night. But an alternative which I find actually works better for me is a product called "Rust Check" I don't know if it's available in America or what the equivalent is there but I've found it to loosens up rusted bolts way faster.
With the frame I use a tub mixed with water and citric acid and leave it a few hours or over night depending on how strong the solution is. You can also use oxalic acid which is a bit stronger but you need to do it outside. After you neutralize the acid with some baking soda and spay a bit of frame saver in the tubes. Then you might need a little scrubbing with some steel wool or a brass brush but it will look much better.
You will have to remove all the cups, but the beauty of powder coating seems to be not as much of prep work is needed. The one I go to he quickly sand blasts everything and frame forks and bars are powder coated for $150-250 cdn. If I was to get the same job done with auto paint I'd probably be looking $500-$900 to get it done by a Professional.
Also, is sandblasting ok for this kind of frame given the thin tubes?
The dropped
Liked 1,014 Times
I will check this tom, have to find my old magnet from the toolshed.
I was actually thinking how do I make sure the inside of the frame is rust free? I might be repainting it only to have a rust problem that spreads again from the inside. The LBS that referred me to the powdercoat company said they treat the metal before painting. Is that sufficient? Should I try submerging the frame in some sort of solution like you mentioned?
BMX Connoisseur
Quoted: 399 Post(s)
Liked 108 Times
If the powder coaters are going to sand blast it then you really don't need the acid bath. And the sandblasting only removes extremely small amounts of the surface so don't worry about it. The reason I do the acid bath first is to see if the rust is hiding any cracks or pinholes. That way I know if I need to visit a metal fab guy I know first and get that damaged repaired properly. Some powder coaters will simply fill the crack / holes with a little bit of bondo and not say anything about it.
BMX Connoisseur
Quoted: 399 Post(s)
Liked 108 Times
SE Wis
Liked 3,394 Times
With rust you take your chances. This was a couple years commuting after a blast and powdercoat. There was rust around the cable guide and I suspect the bike saw extensive trainer duty before I got it. Reynolds 531 tube.
The dropped
Liked 1,014 Times
And they all tipped a splash of beer from their mugs in memory of the loss.
Likes For Unca_Sam:
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
That bike looks like it was sadly abused and that ain't good. I would strip it and send it to a frame builder and see if they can take a look and bring it back. There are some parts on that I would just toss or have to spend a lot of time cleaning and polishing and removing rust.
Likes For veganbikes:
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
Find a powder place that does chem stripping, not mediablasting.
the acid tanks will clear rust from inside
Ask to go and have a look at it after it's been stripped, and decide if it's dead or not. Or, you could strip and aggressively remove the rust yourself, just to check. Getting the rust spots back to bare metal won't be that hard. Removing good paint is harder. Then you can decide if it's worth continuing.
I also suggest you shop it around a lot. Some places will do like $100 for strip and powder. Some, many times more. And some will hate bikes and some be fond of them.
It's really a shame because that original paint is great. But this way you can go metallic purple
Liked 1,024 Times
Result looks like this, looks really slick and this bike is designed to run through the rain, mud and snow and none of that is staying in the frameset to rust it out.
Likes For Russ Roth:
The sand blasting might be able to do some of inside like the bottom bracket. The acid bath can remove rust on the inside but you need to spray it with a rust inhibitor like "frame saver" after. On the inside once the rust is gone can "Flash rust" after depending on the climate you live in. A quick google search and I found this guys how to with frame saver. How to Use Frame Saver Velo Orange (velo-orange.com)
So I took a wire brush mounted on a drill to that old glue and this is the result. I noticed after going through the rim that there were some damaged areas. I dont know if that was cause by me using a steel brush or not. I tried to be as careful as possible and I think it might have been previously existing damage. What do you guys think? Rest of the rim seems fine. Do I need to do another pass to completely remove all of the glue (batteries are currently charging)? The remaining residue is quite difficult to remove even with the brush and the drill.
Does this look like rim damage from the brush?
This is what I used
Tape or Glue?
As for gluing the tire on, I will be using this guide
This has been a fun thread to read through. A restoration like this can be really satisfying. Some thoughts, most of which have been mentioned:
- That frame is in rough shape. Im not sure if it is from sweat or sitting in the elements, but I’d want to deal with the rust first, particularly around the headset and the home made cable port. The good thing about rust is that it is usually only on the surface, not a structural concern. Either way, strip all the parts off the frame.
- If you don’t care about aesthetics, you could up just use a rust stabilizer around the rough parts. This is cheap and easy at home. I’d be particularly interested to see the inside of the bottom bracket shell, as moisture (and corrosion) tends to collect there.
- If you do care about aesthetics, bring the stripped frame to a powder coater. They’ll bead blast the corrosion off. before powder coating.
- After you deal with the corrosion, invest in a can of frame saver. Also cheap and easy (though smelly) to do at home.
- given the corrosion and possible refinishing, when you’re ready to build the frame again, I’d visit either a good shop or a frame builder to face the headset and bottom bracket, chase the bottom bracket threads, and possibly ream the seat tube. This requires specialized tools, but shouldn’t be expensive. Getting the surfaces faced might be particularly important, as bad surfaces will cause the headset / bb to loosen over time.
- once the frame is in good shape, you can build it with whatever new/old parts you like.
- I wouldn’t bother finding someone to braze on a real cable port unless you want to spend the money. Obviously, you’d do this before refinishing.
- That stem doesn’t look good. I’d call around to local shops to see if they have a used quill stem sitting in a parts bin.
- You’ve removed plenty of the old from those rims. Take a look at the hub bearings to see if they need service.
