Prevent rear derailleur from shifting highest gear
If I were to adjust the rear derailleur so that it doesn't shift into the 2 highest gears, would anything bad result? Thanks.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
No. You just have two fewer gears available.
Quoted: 2026 Post(s)
Liked 1,096 Times
You will have slack cable if you forget and shift into those locked-out cogs. No harm but you will have to down shift a couple of empty clicks to get to a larger cog when you want one.
Quoted: 1572 Post(s)
Liked 643 Times
Maybe. It really depends on why you are doing this. If you're trying to make a 7-speed shifter work with a 9-speed cassette, it isn't going to index properly.
I have 3x9 friction shifting. I just don't want to have to worry about shifting into those two gears at all. And I don't want to take it apart and take them out, so I figured if I limited the rear derailleur it would give me the 3x7 that I want.
I have a hard time judging where I am in the cogset with bar-end shifters, so to prevent constantly looking down to see where the chain is, I figure I could limit the derailleur.
Thanks for all the replies, I appreciate it
Liked 1,096 Times
Even so, the lockout will not prevent you from moving the shift lever to the unavailable gears.
Really Old Senior Member
Your legs tell you if you are in a suitable gear. You don't need to look!
Constant tinkerer
No, it won't cause any issues. But as HillRider said the shifter will still have two "dead clicks" in it which might be annoying.
I would suggest getting a different cassette that is more useful to you, since those two gears apparently are not.
Leaving dead clicks/excessive slack in the cables could allow your housings to come out their guides.
Quoted: 5779 Post(s)
Liked 2,576 Times
Yes, every once in a while you'll find yourself bumping the end of the cassette's range when you should have shifted the front, but the extremes of the lever travel are fairly easy to recognize so after a short while that will become instinct.
While no harm will come from locking out the two higher gears, it means you won't have the use of them when they might be what you need with the middle chainring.
The bike is there to serve you and not the other way around, ride it and enjoy it, and don't sweat details.
FB
Chain-L site
FB
Chain-L site
If you're really set on ignoring two perfectly good gears, the trick is to set the limits to lock out the gears you don't want, then set your cable tension so that the highest position on the shifter is the highest non-locked out gear. The low RD limit will keep the shifter from moving into it's last two positions. It's very important that your low limit be set properly, and that it stays set, because the shifter will try to put the RD into the spokes if you do try to shift into those "gears".
No. What you are doing, in this case, is moving the indexing over two gears. The highest gear on the shifter is actually your 3rd highest gear. The 2nd is the 4th, and so on. The last two indexes on the shifter are off the end of the cassette. Since there is no higher position on the shifter than your setup allows, there is no cable slack. Even if you backed the limits out, it would not shift into those gears (But it would shift into the wheel).
I see. Thanks for clarifying.
I suppose I'll gain more experience with the bike before deciding what action I may take.
Thanks for the advice everyone, greatly needed/appreciated!
Liked 2,576 Times
Also, while not ever having a slack cable may be desirable, the risk of over stressing a cable when accidentally shift to a ghost position at the low end is more of a problem. It can shorten cable life, and lead to cable failure, which isn't a crisis, but tends to happen at inopportune times.
The OP should either leave things alone, or leave the two ghost positions at the slack (high) end of the range. If his cable guides are open and the wire tends to slip, that can easily be fixed with a piece of electrical tape over the slot.
FB
Chain-L site
FB
Chain-L site
Liked 2,576 Times
Not true, the low gear limit would prevent that in any case. (if correctly set). It's the low limit's job to protect the wheel, and that's independent of the cable and lever.
FB
Chain-L site
FB
Chain-L site
Quoted: 1438 Post(s)
Liked 1,092 Times
"Also, while not ever having a slack cable may be desirable, the risk of over stressing a cable when accidentally shift to a ghost position at the low end is more of a problem. It can shorten cable life, and lead to cable failure, which isn't a crisis, but tends to happen at inopportune times."
My concern when you accidentally try to shift into one of the "ghost" positions would be jamming the ratchet in the shifter due to the overly-taut cable, leaving you unable to upshift and possibly damaging the shift mechanism trying to get it unjammed.
Liked 2,576 Times
Yes, I misread the "the backed the limits out phrase" thinking you were still referring the the high gear limits the OP wanted to change.
FB
Chain-L site
FB
Chain-L site
Quoted: 9 Post(s)
No disrespect intended, or trying to over-simplify this, but how 'bout learning to ride. Once you get it your biking experience will be so much better.
