Old-style new cantilever brakes?
Quoted: 765 Post(s)
Liked 660 Times
Are there any currently manufactured cantilever brakes with straddle cables that are easily removed at both ends, like on the old Dia-Compe 980? My travel bike has a set of cheap Tektros that work fine, but it's annoying to undo an allen bolt to remove one end of the straddle cable when taking it apart, then have to readjust when it gets put back together.
I'd replace them with a set of 980s, but my understanding is that current cantilever posts are too widely spaced for that to work well. The frame in question is a Long Haul Trucker 26--not C&V, sorry, but everyone needs one modern-ish bike, right?
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Quoted: 1361 Post(s)
Liked 423 Times
Perhaps consider Paul Components. Tall pricing but if you've seen them up close and the quality.... tempting.
edit: Sorry but I missed the request for releases at both ends.
Link
https://www.paulcomp.com/product-cat...onents/brakes/
Link
Bikes: a few that I can't recall
Quoted: 346 Post(s)
Liked 302 Times
Likes For Reynolds 531:
Quoted: 765 Post(s)
Liked 660 Times
Good idea--I'll think about that.
--Ogden Nash
--Ogden Nash
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,702 Times
Just out of curiosity, why do you need both ends to disconnect?
Quoted: 765 Post(s)
Liked 660 Times
When I pack up the bike for travel, I remove the stem and handlebars from the steerer, then remove the fork. That involves freeing the cables from the brakes. If I leave the cables attached, I can't store the handlebars where they need to go in the package.
I'm trying to avoid the word "rinko" here, but that's basically what I'm doing. It works really well for me. I just don't like messing with the brake-cable connections
--Ogden Nash
--Ogden Nash
Liked 1,702 Times
I see- with the Tektro and other “triangle” yokes, the straddle cable goes thru the yoke, instead of just being suspended by it.
Check out the Cable Yoke thread!!!
https://www.bikeforums.net/classic-v...ble-yokes.html
Commence to jigglin’ huh?!?!
Quoted: 1829 Post(s)
Liked 3,376 Times
I've been able to remove the straddle cable, although it does require the brake cable to be bent a bit.
Here's a shot of the front brake....
Would this work for you?
Steve in Peoria
Quoted: 765 Post(s)
Liked 660 Times
I've been a dim bulb about this. I've never had a set of modern cantilevers before, and had somehow assumed that the Shimano-style straddle cable--where the brake cable itself goes through the center fitting and forms half of the straddle cable--was somehow specific to the Tektro brakes. If I'd taken the time to look more closely, I would have found (as I just confirmed) that a standard Dia-Compe-type single-ended straddle cable fits right into the Tektro calipers.
Now all I have to do is attach one of those j-shaped cable yokes to the brake cable. I assume that anything will work--Mafac, Dia-Compe, Weinman, whatever. I have tons of those kicking around. Then it's just a matter of unhooking one end of the straddle cable from the brake, and unhooking the yoke from the straddle cable to break things down for packing.
I can often figure out difficult problems on my own. It's the easy ones I need help with. Thanks again!
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Quoted: 765 Post(s)
Liked 660 Times
I've got SunTour XC Pro canti's on my S&S coupled touring bike. The hangars for the straddle cables are similar to the Weinmann centerpulls... the cross-section forms a "J", and the straddle cable fits in the curve at the bottom of the "J".
Steve in Peoria
Steve in Peoria
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Liked 3,376 Times
Yes, something like that should work very well. As I noted in my previous post, in reply to The Golden Boy, I really should have been able to think this through on my own, but started off on the wrong foot by assuming something I shouldn't have. I tend to overthink things, but in this case I managed to underthink them. Thanks for the photo. I like the colors--what's the bike?
The frame was built by Rich Powers (sometimes seen on the I-Bob list), back around the year 2000. Nothing too fancy, but he was kind enough to indulge some of my desires for weird braze-on's.
Steve in Peoria
Bikes: Peugeot Mont Blanc . Bianchi 28c 1980. Coppi Giro di Lombardia. Vitoria Vintage 1990. Orbea Luarca 1977. Trek 950.
Quoted: 51 Post(s)
Liked 12 Times
https://velo-orange.com/products/gra...tilever-brakes
Not cheap at all! But they are beautiful!
Liked 1,702 Times
If you can think it, someone's started a BikeForums thread about it.
Or made pr0n out of it.
Or both.
ick.
Or both.
ick.
PeopleCode delaminator
Thanks for the link. That was useful as well as entertaining.
If you did end up wanting to mount a set of Dia-Compe cantis, Pork Chop BMX has 988 cantis for sale. 28 bucks a brake including all the small bits. Available in black, silver, gold, red, purple, and blue.
Quoted: 331 Post(s)
Liked 332 Times
Older cantilevers
If it is any consolation, removing the grandaddy of all cantilever brakes is a nightmare.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
You can fit new brake pads into those holders. There's room for two standard coolstop blocks in each one, I know cuz I've done it.
Quoted: 331 Post(s)
Liked 332 Times
Resilion Renaissance
Oy! Have they been powder coated? I'd like to see more detail on how your cable is set up. Looks like some original hardware with new cables and housing?
The splitter was the hardest thing to rebuild. But once I realized the cantilever and the splitter are two independent outer /cable arrays I was able to have brand new cables and outers thru the entire loom.
I uses Razor insert pads that are 10 bucks for 10 and they slide straight in. I use old SS rims that have very little clesrence for bigger pads.
Razor inserts do the job on a tight fit.
Looks simple enough but took me ages to figure out how to refurbish wiithout lead crimping. So now all the cabling can brand new.
Expansion spring works the tight arc of the cantilever of these compact one-piece Resilions much better than the traditional spring piston/ cylinder arrangement that works on the bigger floating arm cantilevers of the traditional much more common Resilion that I have on my Sunbeam.
Rene Herse cantilever is like that. And it certainly qualifies as "old style."
https://www.compasscycle.com/shop/co...ilever-brakes/
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Tektro 720's don't work;
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times
[QUOTE=Johno59;20678460]
Johno how did you rebuild the splitter?
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Another option is a detachable cable hanger like the Dia-Compe 1243 (Velobase). Just unhook the cable hanger.
