Shimano MF-7400 x 3 & MF-6208 - mix 'n match possible?
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
I have three Dura-Ace MF-7400 freewheels, one which is six-speed and has a range which looks reasonable (24- or 26-T big cog, not in front of me ATM). Two are seven-speeds and more corncob-ish. I also have a MF-6208 six-speed, again with what I consider a reasonable range.
Before I attempt to get all Hulk-ish with my chain whips, is there any chance I can mix-n-match the cogs among these four freewheels to get one or even two wider range 7sp freewheels, or despite the part numbers are 6sp and 7sp MF-7400 cogs and bodies incompatible? (I'll worry about the 6208 later, if the 7400s turn out to be sympatico...)
Bikes: Too many, but sometimes not enough.
Quoted: 225 Post(s)
Liked 17 Times
Yes, the 6 speed MF-6208 and MF-7400 are identical from a functional point of view. I think the cogs may have had a different (nicer) finish on the Dura Ace model, but they're the same beyond that. The 7 Speed MF-7400 is a bit different, as it lacks the dust seal on the outside face, and requires a unique 1st cog that screws into a unique 2nd cog. You can certainly mix and match between any of the MF-6208 and MF-7400 cogs (other than the 7s specific ones.)
LeicaLad
Classic and Vintage Sales
1
03-24-15 09:10 PM
gtexbush
Track Cycling: Velodrome Racing and Training Area
28
02-10-14 10:01 AM
