Ask your small, random, track-related questions here
#1401
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
Speaking of power meters, can anyone with Dura-Ace FC-7710 cranks do the community a huge favor and measure the width of the interior surface of both crank arms at roughly the center of the crank? It would be to fit a 4iiii Precision which currently requires a 24mm wide surface.
Diagram:
Diagram:
#1402
Yeah that looks about right, thanks. Maybe they'll narrow the power meter before release.
edit: Although I noticed Stages overhangs on this crank too, maybe that'll be ok.
#1403
Bikes: Bianchi Pista, Bianchi Vigorelli
Mine look like they are closer to 27-28mm
and the Stages is the same width at the widest point.
#1406
VeloSIRraptor
Random questions for those who monitor this thread:
How long should I hold on to my track gear after I think I'm done racing?
background: I had a good year last year, but 2014 I ended up not training or riding or racing other than teaching beginner's clinics.
At this point, I don't anticipate racing next year, and I've already sold off my various race wheels & SRM...
So, what I've got left is a 46-54t track bag of DA rings, a Giant Omnium w/ DA/OP clinchers... most of what I need, but stuff that is always available used were I to want to start again.
I mean, DA rings aren't losing or gaining value, a sturdy track frame isn't gaining or losing... there's not much here that I can't get again were I to start racing in a few years.
Thoughts?
I live in a small apartment w/ the wife+cat+dog, so space is sorta at a premium, and the $$ wouldn't be terrible to have.
Thoughts?
#1408
Elitist
Liked 92 Times
+1
Keep it. Track Cycling is a life-long activity. If you don't absolutely *need* the money, then it's worth it to keep the gear because it doesn't depreciate in usefulness. I know guys who race gear that is 30 years old.
#1409
I think once you're married, your parents don't accept donations to their basement anymore . But yes, keep it. Break it down to a frameset and you can store it easier. Also, it's a hell of a lot easier to restart if you already have a bike you can put together. Less expensive too.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
#1410
Quoted: 141 Post(s)
My track bike hung on the wall as art for 18 years until I got motivated to race again. Having the gear on hand made the decision to ride easier.
Unless your bike is a 54cm. Then you should sell the lot to me for $500. I'm one of those guys riding 30 yr old gear.
#1411
VeloSIRraptor
mmmm, yeah- easier to re-start if I have the bits, it would be more likely to help me get out there were I to have the bits already.
If I stay in a place w/ a track, I probably will keep it for at least another year.
If I do end up moving to Bend this winter, PDX is too far away to bother with, so I'll be selling to fund a better mtb
#1412
carleton and Mukman have a couple of cool iOS apps for different cycling needs...
i was wondering if there was an app or other resource out there that allows you to record your bike fit data.
it would be great to have that stuff in a handy place- but would be even cooler if the app could give you equipment adjustments to adapt to different frames..
ie: your new frame has a longer top-tube, a shorter head tube, and a slacker seat tube angle- so you need a stem that is "this length and this angle"
yes i realize now that i type this out I'm basically asking someone to make this app
#1413
Elitist
Liked 92 Times
#1414
One thing that Tiemeyer used, that I believe is also used by Retul is the XY/XY coordinates.
the center of your bar clamp on the stem was one- with X- being the distance forward of the bottom bracket and Y the distance above the bottom bracket.
and the second set was center of the saddle rails. Also vertically and horizontally..
#1415
VeloSIRraptor
#1416
There was a video posted (I think it was on this forum anyway) of a race which mixed Points and Elimination, think it had the word "wolf" somewhere in it? Anyone know where I might find it?
#1417
VeloSIRraptor
#1418
Quoted: 141 Post(s)
I moved this over from the Show Off thread:
I popped out of a Look Carbo Pro in a standing start, so I switched to the original Look style Dura Ace pedals (PD-7401) with adjustable tension. Cranked them down to the max and never had a problem. Still ride them today.
#1419
Quoted: 141 Post(s)
In this case the tubular peeled off completely and the rim did contact the track surface. He must be a track god.
#1420
Bikes: T1, S2, P3
Quoted: 5 Post(s)
Ive had the same problem, I think the carbon pedals come in different tensions now and I guess I had whatever the middle was (i think it was yellow). Anyway, I use the cheaper spring clip pedals now as like you say the have adjustment and they hold much better. BUT if you have worn cleats, you can easily pull out too. Always keep a spare cleat in my bag after one day of getting yelled at by coach...
#1421
Not sure why people are arguing this point. It is more dangerous to flat on the track than the road, and in the case of a flat, you have a better chance of staying upright if you use tubulars over clinchers. How is this controversial? The flip side is, because there is nothing to pinch or puncture the tire, flats happen only rarely, so you have that going for you if you want to use clinchers.
#1423
Bikes: T1, S2, P3
Quoted: 5 Post(s)
Flat or not, I cant stand the feel of clinchers anymore. Ive been ridding all year on my road race wheels (the benefit of low mileage) which are 22m tubs at 140psi. Yesterday I threw my power tap on the rear to make sure it still worked and stopped 3 times because I thought I had a flat. Nope, just what 110psi clincher feels like lol
Track is the same, I feel so much more in control with a billion PSI under me. Dont let the fear/annoyance of glue stop you from using tubulars. Just close the windows, turn on some pink floyd, and have a glue party on a Friday night. woooo weeee
#1424
Elitist
Liked 92 Times
#1425
