Stepping off a Fixie
Ok here
What are your techniques for stopping/getting off a fixed gear bicycle?
Quoted: 2236 Post(s)
Liked 1,314 Times
For me it depends.
For clipless...
If I have a brake it's about the same as a freewheel bike because I can stop on the part of the stroke I want.
If I don't have a brake I think about where I want to end up and unclip the planting foot just before I get there while my attached foot is in the down stroke. This gives enough time to plant my free foot before the clipped foot makes another rotation. The upstroke acts as the last bit of stopping force.
For clipless...
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
There's the "Sheldon Brown" dismount:
https://sheldonbrown.com/fixed.html
Instead of getting off to the side of the bicycle, the fixed-gear rider can go straight off the back. This technique works best if you ride with clips and straps, but if you are really proficient in disengaging from clipless pedals, try it at your own risk.
As the bicycle slows to near walking speed, disengage your left foot, then wait for the right pedal to get to the bottom of its circle. As the right pedal starts to rise, straighten your right leg and let the motion of the pedal lift you up. Let go of the handlebars, let the saddle move forward between your legs, and put your left foot on the ground. As the bike goes ahead, grab it by the saddle.
It takes a bit of courage to try this, but it is actually very easy to do. It is also extremely impressive to watch. When executed properly, it is very smooth, and you can go from riding to walking in a single fluid motion, without ever coming to a stop.
When I want to stop bike, I time the bike to slow down, no stop. I decided I want to get off bike to the non drive side, I unclipped the drive side, kept non drive clipped in. Let's non drive's momentum lift me up, I also stand out of saddle as it lift left leg up, my right leg swing over the top tube and saddle toward the rear tire.
When non drive side lifted me at around 90 degree, my right legs (should be at non drive side now) will touch the ground then unclip left side afterward.
Note: if you fail to unclip left side as moments your right touch the ground, you may finds it awkward. Practice make perfects.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I unclip just before the bike comes to a stop. Put one foot down, then lift the other leg over the back. Hmm... that's just how I get off any bike.
www.rhmsaddles.com.
www.rhmsaddles.com.
tumbleweed
Quoted: 4806 Post(s)
Liked 3,929 Times
Ben
-Bandera
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I never get off my fixie.
Liked 1,314 Times
Just lift up the road and move it back a bit.
Or accept certain death as Seau says - we all gotta go sometime. Might as well be while doing something we don't fully comprehend.
Old fart
Liked 3,400 Times
Apply front brake to lock the wheel, push forward, lifting the rear wheel off the ground, rotate the pedals until they're properly oriented, release front brake, done.
Or, lacking a brake, just pick up the rear of the bike between your legs and rotate the pedals to reposition. It's less graceful, but would work assuming you aren't riding a fairly oversized frame.
Quoted: 71 Post(s)
Liked 12 Times
also that meatloaf sandwich looks good, thread jack the topic to favorite sandwiches?
Who said anything about getting off? You're still astride the bike, just lifting the rear wheel between your legs to spin it.
Quoted: 71 Post(s)
Liked 12 Times
You mentioned the potential awkwardness that a large frame might pose, that only seemed to make sense to me if your foot or feet were on the ground, hence the "getting off" aspect, astride or not. I was just saying it's possible to re-position your pedals without actually having to remove your feet from the pedals.
tumbleweed
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
It's too late Hffy Addict has already been overthinking it to the point the old brain got so hot it turned to liquid and poured right out ; )
They have no plans to ever buy a bike and if they do it will be another wally-mart special so they can avoid mountain biking like the plague.
When I make plans for bikes I usually try and follow through with them if I have the money or I will at least put parts to use on frames I pick up. I do like to sit around and say "oooh new bike should I do it" but then usually at some point I will have a new bike (or an old bike) In this year alone I have done about 7 different projects granted a lot of it was free stuff that I put a little money into to build up (or the Langster which was a replacement for a cracked frame) and two of those builds I am 100% not keeping because they aren't my size and one build I am probably selling but wanted something extra to play with for this winter. Our Addict in the past three years hasn't done anything. Granted I probably won't take on that many projects again for a long time because it has been overwhelming and hard to get things finished but on the plus I have gotten rid of some spare parts and cleaned up a little(ish)
