Penetrating oil in fork
I want to know if I can use penetrating oil in fork? I want to inject some oil in the travel tube. The penetration oil is Abro AB80 Spray Lubricant & Penetrating Oil. The purpose of it is to lubricate a little inside. I have the SR Suntour XCM30 coil fork.
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
What's a 'travel tube'? If you mean the headset, then don't. The only lubricant that should be in a headset is bearing grease.
Lopsided biped
Quoted: 316 Post(s)
Liked 160 Times
The telescoping suspension arms, then. I looked for information on just what this Abro was, but the company doesn't say what's in it. I assume it's something like WD-40.
It probably won't hurt anything, but you can find better stuff. My favorite light oil is Tri-Flow.
I have no experience with spring shocks, though. Can you find the fork manufacturer's recommendation?
WALSTIB
Might try asking in Mountain bikes if their not all out in the woods building ramps to jump over something completely insane.
Likes For hillyman:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I suggest googling “parts of a suspension fork” so people undertand what you are talking about and vice-versa. There is no such thing as a “travel tube”.
Are you talking about the stanchions? You want something to put on the stanchions that will work its way into the lowers?
Is this penetrating oil something that is used to free up stuck parts (like WD40)? If so I would definitely NOT use it.
The proper way to lubricate a fork that needs oil is (usually) to pull the lowers, clean them out, put them back on, and add oil through the bottom of the lowers.
Adding lubricant to the stanchions can cause more problems than it creates, unless it is something that dries and does not attract dirt. 99% of the lubrication happens INSIDE the fork. And if the seals of your fork are doing their job, most lubes won’t make it past them, anyway.
Likes For Kapusta:
Quoted: 427 Post(s)
Liked 699 Times
I would not use penetrating oil as lubrication. Penetrating oil would may have additives designed to help dissolve rust in threads. I use WD-40 to get grease OFF of my leg if it brushes the chainrings. Nothing takes the grease OFF like it! What not use fork oil or just regular oil-why do you think you want penetrating oil?
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
Likes For dedhed:
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
To completely disassemble the fork in order to thoroughly clean and regrease everything, you'd need the Suntour proprietary tool for unscrewing the plastic top caps that hold the coil springs and other parts inside the stanchions; those plastic top caps are very soft and will round/crush if you try unscrewing with something like pipe wrench.
However, for a light maintenance that may not be necessary. Just unscrew the bolts at the end of the lowers and pull them off, then clean and regrease the stanchions and inside of the lowers, reassemble. It is a pretty simple task, see youtube videos for the correct procedure. There are dedicated greases for that, but pretty much any lighter (i.e. not very thick) grease should work. Worst that can happen is it gunks up sooner and you'd need to repeat the procedure.
I use for these purposes Motor Oil for Summer, usually I use a slightly thicker oil, for example 10W30. Although it is machine oil, it suits me. I lubricate the oil seals after about 700 km of run, at least - every season, and I sort out and lubricate the entire fork with a lubricant - with a frequency of 4000 km. If the vehicle is operated in conditions of increased exposure to sand and other abrasive materials, its fork will have to be lubricated more often.
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,992 Times
Nick2515 Just FYI this thread hasn't been active since June of last year. It is probably bad advice as well using thicker oils when all you would really want to use is something pretty light if you need to use something and not using the proper grease.
