How do I know when to replace my Conti 4000 ll Tires
Quoted: 33 Post(s)
The back tire shows 2 snake bite looking holes.
I probably have around 1500 miles but not really sure.
Tires are around 3 years old.
Should I replace front and back even though the front still has a slight center bead
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
There are little wear indicator holes in the tread near the label on the sidewall. When those are gone, it is time. The back normally wears out faster, so sometimes it is best to put on a new tire on the front, and move the old front to the back.
Quoted: 539 Post(s)
Liked 44 Times
TWI ? Tread Wear Indicators Explained | Continental Cycle Tyres UK
P.S. For tire wear, if you see the holes you're fine. It's when you no longer see the holes (because the tire has worn down past the holes) that the tire is worn out, according to continental.
Quoted: 1218 Post(s)
Liked 298 Times
So many Unknowns to offer a 'yes or no' answer to the OP's question on replacement.
the wear indicators has been answered.
as for replacement, the unknowns are dry rotting, or how embedded are they with rock chips/glass.
I personally could get 2x that mileage out of GP4000's yet I seem to be 2 years max on dry rot cracking and still being comfortable riding the tires. Depending on what tire pressure a person runs, a rider could have a flat spot worn into a tire also.
I have also ridden GP4000's down to where I started seeing threads in a couple spots.
Seems quite a low mileage to me. I'd have expected at least twice that, but, of course, it depends on what the roads are like around you. I recently had to replace a GP 4 Season with only 1000 miles on it because I'd done an emergency stop and worn a hole in it. I was gutted!
Sorry to hijack thread, but I have GP 4 seasons on my bike, I have checked and they definitely do not have the 2 tyre wear indicators! Have I got some fake tyres? I bought them last September.
Could it be that you wore them down? Or alternatively, someone might have filled the holes with shoe goo just to mess with you. My vote is for the second one.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 336 Post(s)
Liked 227 Times
I have 3k on my Conti Gp4k's, and I'm thinking it's getting to be time. I could probably go another 1k, but I'm a better safe than sorry kind of rider.
Bikes: Felt ZR3, Specialized Sectur
Quoted: 100 Post(s)
Liked 52 Times
I usually get 300-3500 out of my Conti Gatorskins without to much problem, but that is in one year. As others have said, 3 years and 1500 miles is not a lot. I'd be worried about the dry rot issue as someone else mentioned. So, maybe 3 years or 3500 miles which ever comes first.
If it were me, I'd change them out. 3 years going on no tire change is a lot to me.
john
Quoted: 3375 Post(s)
Liked 5,513 Times
The GP4's always had TWI's, but the Gatorskins never had them.
no to both, I've only covered roughly 1200 miles, and I also checked front and back tyres for them, they still look pretty new tbh! And no, no one has filled them in!
Quoted: 1638 Post(s)
Liked 741 Times
The GP 4k S II's do have them.
nine mile skid on a ten mile ride
last set I got almost 4000 miles, this set I'm only on 2000 + or -. so I'm hopeful for the same mileage
Quoted: 1814 Post(s)
Liked 923 Times
I don't ride them, but based on what I see & hear,
you know to replace them because the sidewall ripped out.
Kind of surprised at the uniformly good mileage posted here.
Quoted: 551 Post(s)
Liked 277 Times
Liked 298 Times
I am guessing that some people know how to gently install tires, while others...... are like a bull in a china shop with tire levers.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
When the cords are about to show through the rubber.
Bicyclerider4life
I replace tires if/when the sidewall fails or the cord is showing in more than 33% of the tread area; whichever comes first.
Liked 298 Times
I've never had issues installing them, or with bad sidewalls.
I did hit road debris at night and nicked the side wall on my 700x28. I had the tube coming out, so I booted the tire, and have not had any issues with the sidewall blowing out since then, (even with a cut). Thus I can conclude that peoples sidewall issues are from mishandling.
