How low is your gearing?
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I live in a fairly hilly city and have started using an old Burley Cub trailer for errands. Right now, I've been using the same bike for light-to-medium trips with front and rear racks and then the trailer for multiple cat litter purchases. My gearing is 45/30 and a 12/32 cassette. I'm thinking of dropping my granny to make using the trailler easier, but not having it be so low that I'm crossover gearing backwards when I drop into it.
Quoted: 19 Post(s)
My gearing isn't low enough sometimes. I've got a triple in the front. I've seen many mountain bikes with a small chain ring with just twenty-two teeth. Maybe a triple crank set would be better for you. A Megarange cassette has a low gear with thirty-four teeth. I don't know which would be cheaper for you to get.
No longer here
Yep,LOTS of mtn bikes run a 22t front granny,and 32-34t rear,and it's getting more and more popular on 29er's to run a 36t granny out back. I run 32x24 (pretty low by mtn SS standards) on my mtn 29er SS,but my former local trails were pretty hilly,and a 22/32 double front with a 11-34t rear 9 speed on my geared mtn bike.
On my CX bike (my goto in town),I run a touring triple (26/36/46) up front,but a mtn 9 speed cassette out back with 11-34t. So far(just moved here a few months ago,and due to spinal injuries,I don't get to ride everyday...just not up to it some days),my granny gear combo being 26t front/34t rear has been plenty low enough for the moderate hills we have,but I haven't hauled much weight yet,let alone a trailer.
But yeah,you have lots of options depending on your frame
Bicycle Repair Man !!!
I have many bikes that range from ss/fg to 27 speeds but the main commuter and tow vehicle has a 28/38/48 triple and a 13-30 6 speed with a 3/3 split in that the bottom 3 and top 3 have a slightly wider gap between them to give closer steps at both ends of the cassette range. The 28/30 gives me a 24 gear inch low.
The extrabike has a 28/34 to give a 21 gear inch low.
The touring bike has a 28/34 and the mountain bikes have 24/34 and 24/30 which gives me some truly stump pulling gearing although these uber low > 2 gear inches are for climbing on the trails and are not anything I would need for utilitarian purposes.
For geared bikes that do not carry or tow a 40-100 range is more than sufficient.
In the right lane
I use my trailer with a 44-33-22 MTB crankset. Cassette is a 7 speed. I think 28 is the big cog. Really great for making the hill back home from the grocery store.
I ride a number of bikes. The FG is a 42/16, roughly a 70-inch gear. The road bikes use compact 50/34 chainrings and 12/25 and 12/27 cassettes. The tourer uses a Rohloff hub, again with a 42/16 ratio. It has 26" wheels, so that gves it roughly a 19" to 100" range.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
My gear ranges are from 21" low on my expedition bike to a 40" or so on my 3 speeds. I have one single speed that is geared to around 64". For heavy hauling anything under 30" works for me. The terrain around here is gently rolling hills with only a couple of short steep ones.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
My low is around 33", my high is around 85". I don't mind walking up hills tho. If I routinely hit one of the (very rare) 5% grades in Madison, I'd probably have more like a 20" low.
I have a standard 27-speed mountain bike configuration. I have an Xtracycle mounted on it, and commute with my wife and our lunches on the back for a total weight of about 350 pounds all together (myself, the wife, the lunches, and the bike). There are two hills on the mile and a half to work, both averaging around an 8% grade with one peaking out at a 10% grade. The total distance is 1.5 miles and the total climbing is 80-100'.
I have found that the second chain ring is best in a 2-4 configuration, and dropping down to 2-2 on the 10% grade, while maintaining a high cadence. The thing I've learned about hills on bicycles (and this is especially true with heavy loads) is that if you go too low of a gear, things just get harder, because you're exerting for such a longer period of time with no recovery. Therefore, I found it is best to use the gear where you're at peak exertion, but still maintaining a good cadence (don't start lagging or you'll hurt your knees).
Another thing to consider if you're having a hard time hauling loads would be an electric system. We have a BionX system that we use in the winter to assist in riding through snow and it works great. Since it has a torque sensor, the motor is completely hands free - if you need more power from the motor, just pedal harder. The regen braking is also very nice in winter, as it is basically anti-lock braking, and worked well enough such that I never actually had to use the actual brakes.
Shameful product placing, I know, but this is the configuration we've been using for around three years now and it works great.
18.6"
I swapped the granny chainring out for a 20-tooth, so with a 28 in the rear & 26" tires my low end is 18.6". On the next bike I'll be dropping that a bit further for touring and general load hauling and mountain climbing. Nothing's flat here and there are a few (avoidable) 20 degree hills where it's hard to keep the front wheel on the ground climbing in the saddle and no shortage of 10+ degree climbs on my regular routes. I like to keep spinning up hills and my knees don't need the abuse of a taller gear.
Bikes: Gunnar Crosshairs, K2 Zed Team, Eighth Inch Scrambler
71" My main bike is a singlespeed set up with a 42x16 and 38mm knobbies. Most of the hills that I go up on a regular basis aren't too steep so it works out alright. I am thinking that I will drop down to a 66/67" once I have to start riding on snow covered roads.
In the right lane
I think 42 by 16 is a very common gear for most riders... at least on the flats. That where I ride my bike most of the time. On windy days I might move to the next sprocket up on the rear cassette though.
I'm running a 1x7 set-up on my commuter right now that consists of a 38t chainring and a 11-30 casette. 38-30 does feel tall sometimes when riding trails but is fine for commuting. Also, whenever 38-11 is too small, I just coast.
WNCGoater
51
11-23-17 10:19 AM
Nanaterry
Touring
26
02-02-13 10:19 AM
