On-the-fly flip-flop hub
Armageddon wasted.
Bikes: Cinelli 84, Masi 83, Bareknuckle, GT Mach 1
A friend and I have been trying to conceptualize a freewheel with a fixed "lock-out". It's applications are, of course, questionable (why not just ride fixed OR free?), but it's just for the sake of curiosity. Anyway, I've heard of fixed converted Sturmy-Archer 3-speed hubs, but never a hub that's capable of fixed-free shifting. Anyone else?
Bikes: some piece of s h i t
it would be sweet to be able to ride fixed till you get to a big downhill and then flip a switch and coast. i dont know of a way to do it though. it seems like it would be sketchy even if it did work.
ya'll can't mush me
The pin that would be required to "lock out" the freewheel would come under considerable sheering forces.
It would need to be on a spring that would rotate until it found the receiver hole on the freewheel, then pop into place. You could always have more than one pin, and even have one pin do the "hunting," then have two others pop in. That way, the lock-out pin would have 3 (or more/less) places to pop in, making the fixed/free switch near-instantaneous.
This will be very, very difficult to construct without considerable design experience, and access to a cnc lathe.
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
I would love something like this.
Edificating
Bikes: Spooky + Sachs
what if there was just a clutch in the hub and you could pull a lever to coast?
Cat 3 // Dylan M Howell
Are we not men?
Sounds like the kind of idea that my friend and I will waste hundreds of hours and dollars on, only to end up frustrated and with a pile of tools we'll never use again....
awesome!
awesome!
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
sounds like a good way to get hurt.
Easy like Sunday morning
As usual, Sheldon's already on the case: https://sheldonbrown.com/bichain-fixed-free.html
harrospokes!
Lamb of God
Bikes: Masi Speciale Fixed, Surly 1x1, 2 70's Bianchi folders, Swingbike, Columbia Cruiser 3 spd, Specialized Big Hit and P.2, Cove G-Spot, Xtracycled Bianchi San Jose.
there is a freewheel with a pin to fix it, but it's a stop and switch option it seems, not sure how you could engineer one with shifting on the fly.
this is what you are looking for...
https://bmxmuseum.com/forums/viewtopic.php?pid=254038
simply krafting.
Bikes: 53cm Mercier Kilo TT Special Limited Edition (Black/Chrome)
ride around with a mig welder... the problem is it only converts once.
Bicycle Repair Man !!!
I love Sheldon's idea but it is a rather complex solution and I like my fixed gears for their simplicity, among other things.
"So we don't have to bring wrenches for when we feel like switching"
If wrenches bother you they make these things called wing nuts...these came stock on my 1955 Raleigh.
Lamb of God
Bikes: KHS steel SS
Would be no problem to build, no problem to make strong enough, the biggest problem would be cost/market. There simply would be enough of a market to make it worth setting up to build these.
