Trek dual sport gen 5 or specialized sirrus x
I have been riding trek fx sport (2021) and while I enjoy the bike, it gives me back trouble after my rides. I’m considering getting something more upright (but not trek verve) in hopes that my back pain goes away.
is the dual sport gen 5 more upright or sirrus x ?
on paper DS gen 5 is , compared to sirrus x 1,2,3, but sirrus x 4 is more upright than DS gen 4 based on stack and reach measurements. Has anyone had experience with both ?
Clark W. Griswold
Quoted: 4445 Post(s)
Liked 4,102 Times
Sirrus X 4.0 would be my go to I love the color which has zero bearing on anything but more importantly it is standard thru-axle wheels both front and rear. That means upgrading is easier rather than one being a QR and the other being a thru-axle (thankfully rather than their "thru skew") and it is 11 speed.
However the Trek does come with wider tires out of the box but you could get a nice 650B wheel set for the Specialized and run wider tires pretty easily. My Vado SL has 650x50 tires and is excellent.
Overall I like the look of the Specialized better but that Trek isn't as bad compared to older DS' I have seen which I hated.
In terms of back pain, I would look at something maybe like the Velo Orange Crazy Bar which gives you some sweep back and a position where your hands might be on a road bike (ish) so it gets you a bit more upright but also gives you a position to stretch out a bit. I know my back tends to like those bars as I have essentially 3 of them though one is a Koga Denham bar and the other is a Surly Moloko Bar (but the sweep back is identical or nearly so) 34˚ seems to be pretty optimal for sweep back more and it doesn't feel as good and less is not as bad.
However it is possible maybe a fitter could really help you get more comfortable on your current bike and help you choose your new bike. One can really never have too many bikes (at least to a point)
I did ride sirrus x 4.0 year ago and recently dual sport gen 5. I remember sirrus x 4.0 being more playful bike and about same upright med
Quoted: 6315 Post(s)
Liked 4,905 Times
You need to put those bikes next to each other and then stand back to the side and look at them. There is quite a bit of difference in the Sirrus and the Dual Sport for the position given in the same size. If you have your FX with you, put that with them two. Then you'll know how much difference from that if you compare your contact points on the bikes (butt & hands and then BB center).
Sirrus in the same size should be the higher more upright position. But coming from your FX which is lower and more aggressive than the other two, then you may prefer the more in between the two position the Dual Sport gives.
You can try a size down or up of each. Larger size will give you less saddle to bar drop, but might stretch you out a little more. Smaller size will do the opposite. Be aware of things that change on the bike as size changes. Such as bar width and crank length
Clark W. Griswold
Liked 4,102 Times
I done lot of research and understand bike fit pretty well. Also I have no pain while riding the bike , it’s when I’m done riding .
The only reason for the Trek is wider tires and the bag integration but I am personally fine with my Oveja Negra frame bag with straps it doesn't take a long long time to install.
That could still have a lot to do with position and fit on the bike and is still worth getting a fit over. You could also try some stretching which may help a bit.
Clark W. Griswold
Liked 4,102 Times
Precisely! It can do wonders for your comfort on the bike and for dealing with pain off the bike. You want to find someone who does dynamic fit meaning they have you on a bike they can adjust in real time and track your motions and really get in depth. Also a good fitter will know some sports medicine and a lot about bikes and such so it can be quite a good experience. My fit happened to be Retül but I know there are others,
The problem is there is a stigma built around fitting that it is only for those who race but that is beyond the case. Fitting is designed to optimize your position on your bike. For someone racing it is probably to get the most comfortable aerodynamic position and trying to eek out every last little bit of performance but for really everyone it is about getting someone comfortable on the bike. Everyone's fit will be different but in the end it is trying to get comfortable on the bike and make you be able to ride it better.
I remember getting mine and I felt relatively comfortable before but after it felt like a rocket ship because I felt really good on it. I like being comfortable and I like to be more upright and more so now but I remember my first ride after the fit and I was racing up a hill I would normally not have done so on I just felt really good everything was perfect fit wise and the pedal extensions helped and the insoles were excellent it just improved things so much.
I
I
Clark W. Griswold
Liked 4,102 Times
This is what is looks like (with a person on it but I didn't easily find a better photo but you can see the adjustment dials and such. It is really quite a neat machine:
https://www.balancephysio.com/wp-con...dude1-copy.jpg
Your fitter will put the correct bars on there and easy peasy. For other bikes they can take the numbers and put it towards other bikes as well as much as possible usually there is a fee for other bikes set up but that varies fitter to fitter. However a road to a mountain bike would be a different fit but if you let your fitter know I am sure they can make some accommodations and get you closer.
