Saddle Plumbing Question
Quoted: 659 Post(s)
Liked 595 Times
Plumbing. Yes, you read that correctly. Here is my question for the Resident panel of experts. That 1898 Glenwood I redid over the winter deserves a better saddle, for looks if not for my hinder parts. Prob is, the saddle mounting rails in the TOC era was built on a .81” seat post. Is there some way possible to mount a modern seat to a post that small or is there a steel seat post that small in diameter to fit the modern era wider rail width?
Scratching my head in N Michigan.
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,696 Times
Clamp with shim?
Commence to jigglin’ huh?!?!
Quoted: 659 Post(s)
Liked 595 Times
Not sure how that would work. The seat rails are wider on newer saddles. I was thinking if I could find a straight pipe that size and use your clamp/shim method, I could use the kind of saddle clamp you find on kids bikes. That kind of seat clamp System is steel and “clampable”.
Quoted: 659 Post(s)
Liked 595 Times
Here is a pic. Maybe I can squeeze down the rail width another 3/8”. That may work. I want the one on the right to fit. The one on the left is 122yrs old. Things were a little different back then.
Quoted: 1607 Post(s)
Liked 2,214 Times
Would you consider new leather? If so we have resident saddle refitter.
OR one of these with shims.
P1000603 on Flickr
P1000603 on Flickr
Likes For SJX426:
Friendship is Magic
Bikes: old ones
Quoted: 26392 Post(s)
Liked 10,366 Times
...I have narrowed the rails on a saddle once by carefully squeezing the (steel) rails in the jaws of a vise. But it was constructed differently than the saddle you show as a replacement. If you do it on that saddle, I think the rails will pop out of the plastic shell. Then you are stuck trying to reinsert them with the rails deformed. Think about using a saddle with a solid welded frame, like a Brooks or similar.
Likes For 3alarmer:
Liked 2,214 Times
Quoted: 2337 Post(s)
Liked 2,813 Times
Likes For squirtdad:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
Tidy workshop! Liking it.
Likes For gugie:
Liked 5,790 Times
I have no doubt that Rudi can releather this, but if the seatpost OD has to be 0.81", I think you'll need a lathe, which I don't have.
Quoted: 4791 Post(s)
Liked 3,918 Times
Or, with $$s and time, a TiCycles project. (Says he with two ti posted TiCycles units with 65mm setback and Thompson hardware. Complete joys to use and adjust.) Dave could either modify a Thompson clamp ( maybe) or make a similar one.
Ben
Ben
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Assuming the frame has a removable seat post, there are three separate interfaces: frame-to-post, post-to-clamp, and clamp-to-rail. If you can fit a different post to the frame, then you have the option of fitting any seat that fits the post. If you can fit a different clamp to the existing post, you can fit any seat that fits that clamp; and so on.
Most seat posts made to work with a separate clamp --which was normal until fairly recently-- measure 7/8" where the clamp goes. It wouldn't take much of a shim to make up the difference between 0.81" and 7/8". But I'm sure I have clamps made for smaller posts. Do you want a better clamp, or a better saddle?
As for the saddles in the photo you posted... I don't understand how the clamp on the original saddle works. I assume it clamps to a horizontal section of seat post (i.e. a 7-shaped post). Could we have a photo, with dimensions, of the seat post and all the clamp parts?
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 659 Post(s)
Liked 595 Times
Quoted: 659 Post(s)
Liked 595 Times
Here is the arrangement:
Quoted: 4722 Post(s)
Liked 3,036 Times
Are you sure that you want a modern seat post? Those TOC bicycles generally have such a laid back seat tube that the forward extension posts are necessary to get the correct saddle position.
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
I have this, which you're welcome to have for cost of postage if it works. The post only measures 0.625" though. It's about half as old as what you have there (my best guess).
Likes For USAZorro:
Liked 2,214 Times
Will look for it after work. I'll let you know. It is off some old folding tadem that was only worth junk. The brooks one in the picture (Chrome) was on a 1972 AL post on a Le Champion. It may be the 7/8 version of post as it was necked down from the ST ID.
P1000590, on Flickr
P1000590, on Flickr
Likes For SJX426:
Quoted: 659 Post(s)
Liked 595 Times
I’m trying everything I can to get around this problem. So far, that’s why I’m at the point of keeping the original post and trying to fit a more C&V seat to it. You know, too much time on my hands and it’s cold out.
Quoted: 767 Post(s)
Liked 1,898 Times
A Schwinn Varsity seatpost is 13/16", or .8125, and necked down to 5/8" at the top. I may have the guts here. I'll look.
I have seat guts to fit a 5/8" neck down. If the Varsity post option works and you need the guts they're yours.
Likes For BFisher:
Quoted: 659 Post(s)
Liked 595 Times
Thank you, this might work. I need to back away from it until later this week. I appreciate that!
Liked 2,214 Times
OldsCOOL Still looking for complete clamp but did find this. It measure .,878 in its relaxed state. I can imagine it will nearly fit. The cross bolt was stripped so I tossed it. Why I don't have the nuts, I don't remember. Its yours for shipping if you want it.
P1030126, on Flickr
P1030126, on Flickr
Likes For SJX426:
Quoted: 659 Post(s)
Liked 595 Times
Liked 2,214 Times
I was able to find the Brooks one, it is on my Bottecchia. Don't know where the others are. The pic is 6 years old!
Likes For SJX426:
