What Utility Rides/Trips/hauls/errands did you do today???
#251
Bikes: 2006 Falcon Explorer Hybrid, 2008 Landrover Visalia Crossover, 2010 Cargo Cycles Senton, 2010 Cargo Cycles Capability, and a 2001 AVD quad pedi-van, 1980 Peugeot Carbolite 10sp racer
Quoted: 21 Post(s)
Liked 24 Times
Now that I eventually have the Low rider Pannier frames fitted to the front forks on my Hybrid, my trailer is being used less & less
I have just got in from a 2 miles each way grocery run: 5 kgs of Potatoes, 2 kg Carrots, 2 Kg Sweet Potatoes, 1 Kg Parsnips, 1 Kg Leeks, 6 Kgs Plain flour, 1.7 kg Honey, 2 litres Milk, 2 litres Bleach, 1 litre Orange juice, 1 litre Red Grape juice, and various other smaller items. That's a little over 25 kgs spread between the two pannier bags, and is the largest and heaviest load that I have carried in them so far. Apart from the intial starting off, I did not experience any problems, in fact all of that weight concentrated around the centre of my bike's front wheel made cornering at speed safer: I had one dodgy moment on some wet and slippery leaves whilst negotiating the small roundabout at the bottom of the hill that I live on, and without the extra weight on the front of my bike, I would have probably ended up a bit of a bruised, bloody and embaressed mess in the gutter. All in all I am getting to like these low rider front panniers of mine a lot; roll on the spring and summer camping trips and short haul bike expeditions.
#252
Bikes: rockhopper, delta V, cannondale H300, Marin Mill Valley
Liked 5 Times
Bigshew, the tires were sort of an impulse purchase. I saw them in a bike shop/hardware store. I had been using basic kid's bike tires. At $33 each, these Primo Comets were almost 10x what I was paying for basic kid's tires (wholesale, through work). Unfortunately there are not any more puncture resistant. After I bought them, I found out a little about the tires over on the folding bike forum, apparently there is a kevlar belted version that is popular, but I think they go for around $50 each!
Pluses on the tires, smoother tread and higher pressure (100psi max vs. 45).
Good suggestion on the tire liners.
#253
Liked 5 Times
Gareth, why did you decide on front panniers rather than rear? I've never tried front panniers, always assumed the bike would handle better with the weight in back. Sounds like they are working well for you though. Riding without a trailer isn't really so bad, you'll get used to it. Haha. I rather enjoy running errands on weekends without the beast.
#254
Quoted: 21 Post(s)
Liked 24 Times
That's a very good question.
I already have a cheap set of rear panniers that I have used on and off for over 10 years now, and they are very far from ideal . I bought cheap from one of the catalogue stores, and for the first 2 years or so these rear panniers met my requirements. However they are of the one piece over the rack fitting type, with a zip on/off removalable back pack, and are very inconvenient for quick removal and installation. I've wanted a set of front panniers to suppliment the rear set for a long, long time now, and when a reasonably priced second-hand pair came up in the local classified ads, I bought them, along with a set of aluminum front low rider frames from ebay. These pannier bags have an elastic bungee type retainer and quick release clips, making them absolutely perfect for loadiing with groceries at the supermarket checkout point, and then fixing to the frames on the bike to haul the shopping back home. I originally bought them for proposed cycling/camping trips with my new partner (I am a widower of 5 years now) next spring and summer. Being the gentleman that I am, I intend that Lois will not have to haul anything on her bike, except a bar bag containing those absolute essentials that every woman seems to need everywhere that they go
The bags that I have are these: https://www.chainreactioncycles.com/M...&ModelID=13690 and are suitable for fitting to front Low Rider frames or a rear rack; so I'll be purchasing at least one more pair for fitting to my rear rack in the coming months.
Ironically, the front forks of my Hybrid bicycle were not suitable for fitting Low rider frames to, and I had to make adaptor plates to pick up on the braze-ons for standard/high mounting front panniers. As I am a very adaptable and skillful Mechanical Engineer/welder/fabricator it took me all of 20 minutes to make these from a scrap piece of 4mm thick mild steel plate, using a 75 mm diametre holesaw, a 50 mm diametre holesaw, 12 inch hand hacksaw, 2nd cut file, 5.3 mm drill bit, and a cordless drill: I'll post some photos later.
#255
Quoted: 7348 Post(s)
Liked 2,471 Times
It depends on the bike. Some bikes handle worse with a front load than when empty. Some bikes handle worse with a front load than when empty. I grew up thinking front loads are always bad. Then I had a Motobecane Mirage which loved to have weight on the front. Notice that front loads are common in France and on French bikes. And Velo Orange is reviving this sort of practice.
#256
Quoted: 21 Post(s)
Liked 24 Times
Here are the promised photos:
The frames fitted to the front forks of my Hybrid:
[IMG][/IMG]
Close up of the adaptors that I made, so that the frames will fit the forks on my hybrid; basically a steel disc cut out with a 75 mm diametre holesaw, then the centre removed with a 50 mm diametre holesaw, and cut with a hacksaw into two 130* sections, 3 X 5.3mm holes drilled for fitting 5mm diametre set screws, and a section filed out to allow wrench/spanner/socket access to the front wheel's axle nut:
[IMG][/IMG]
I did however make a disposable plywood template first: Measure twice and cut once:
[IMG][/IMG]
And the pannier bags in postion on the frames:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#257
Quoted: 21 Post(s)
Liked 24 Times
Lois has found a new errend for me now that I have these front Panniers fixed to my hybrid ..... ..... ..... ..... ..... the laundry run. She lives appoximately 2 km from me. I have a washing machine, and Lois has an Iron and ironing board; so I wash her laundry and she does my ironing ... ... ... an exceptionally good collaberation and sharing of resourses in my opinion.
#259
Trailer Nut
Bikes: Viking Urban Trail. Schwinn Spoiler
Nearly finished building my smallish shopping trailer, just a lid and a better towing arm for the hitch to build.
My telly packed in during the week so I though Sunday I'll try out the little trailer and take the telly off to the local recycling dump, a round trip of about 3 mile.
The telly was a bloody heavy one and ended up lifting the back wheel of my bike off the ground! but I think that's due to the tow arms hight. I may also have to set the wheels a little further back on the frame.
Going to the dump with BIG telly.
Back home after telly had been dumped.
As you can see from this picture the trailer is sitting at an angle.
Regards
Tom
Regards
Tom
#260
I would move those wheels back at least 4 or 5 inches. As you found out, you need more weight on the hitch to keep your back wheel earthbound.
#266
Didn't make it
Christmas shopping this morning. Ten degrees light wind,thought it was great! Snow should be here in a
couple of days.
couple of days.
#270
Liked 5 Times
Yeah, I try to get bikes in the pictures I post here. I waited for this guy to get in the frame. I wasn't paying proper notice to the sexy boot lady, but if her leg hadn't been in the picture, I wouldn't have posted that image here. The biker isn't in focus and my load is not impressive. The boot made the shot. The rest of her is left to your imagination. Chances are she is better looking in your imagination than in real life. Haha.
The image of the sexy bootie lady is one I've seen before, but only because people are willing to post it on forums such as this one. I think I may have done that once myself in fact. So while I'm sorry nwmtnbkr found it in poor taste, I thank whoever posted it the first time I saw it.
Boss, PM me the view from the front!
DC's sexiest utility biker.
Not just a pretty face, she's also a very friendly smart warm and caring type person. Lola's bike tour of Cuba with her sister was a cover story of our regional bike 'zine, Spokes a few years back. She built her own trailer. Sorry I didn't get her in good focus. I think my new camera is messed up. when I zoom in on the photos, I see a lot of black specks. I bought the extended service this time, and there is also another minor problem, so I will take it in for service, but maybe not until after the holidays...
#271
Liked 5 Times
What trips did I do today while I wasn't taking pictures of sexy biker chicks and other riders? In addition to the usual, tubs of mail, boxes, rolls of drawings, etc., some Christmas gifts.
I sold my first picture today. Sort of. I saw some people in an office posing around a chocolate Capitol, so I shot them.
When I got outside, a lady asked me if the picture came out OK. I showed it to her and she asked if I could email her a copy. When I said sure, she asked me if I wanted one. My chocolate Capitol.
While I declined an opportunity to transport cupcakes today, and thus redeem myself after destroying a load of cupcakes a few months back, I'm happy to say this confection survived undamaged nestled by plastic bags and a tarp in my Rubbermaid bin while I knocked out a flurry of "friday before Christmas" rushes.
#273
