$300 Vintage Touring Bike Showdown: 1983/4 Fuji Series IV vs. 1986 Schwinn Voyageur
Member at Large
Bikes: 1974 Peugeot PX-10 | 1974 Motobecane Grand Record | 1975 Windsor Professional | 1988 Schwinn Voyageur
Quoted: 49 Post(s)
Hi-
I'm checking out two touring bikes in the next couple of days (finally bit the bullet and sold my commuter) and was wondering if the group has strong feelings one way or another. The Schwinn asking price is a little higher than the Fuji, but it's close enough that it doesn't make much difference to me. I plan on riding both and seeing what fits best, so I just want to know what sets these two apart in terms of handling and load carrying ability. Want mostly for loaded touring. Thanks!
Bikes: '02 Litespeed, '99 Bianchi Alfana. '91 Fuji Saratoga, '84 Peugeot Canyon Express, '82 Moto GR, '81 Fuji America, '81 Fuji Royale; '78 Bridgestone Diamond Touring, '76 Fuji America, plus many more!
Quoted: 181 Post(s)
Liked 224 Times
Ask the guys over in touring, too.
Quoted: 5888 Post(s)
Liked 3,471 Times
It would be helpful to know what the components are as that will help distinguish the bikes. My gut is that there isn't a big difference between the two so, as you suggest, fit is critical. Also I'd pay attention to the condition of the wheels. They are more expensive to replace than other wear items. Check to see if they are badly out of true; sometimes you can fix that, sometimes you can't. Personally I like vintage fujis and I would lean towards that; plus I think it looks better. But YMMV.
Quoted: 377 Post(s)
Liked 14 Times
Doesn't the Schwinn have the Wolber 58 wheels? Those seem to be well regarded.
I looked at a 87 Voyageur last year that had almost all original equipment and was decent but was not up to snuff cosmetic wise so I passed. The only thing I personally don't like about the 86 thru, I believe, 89 is the way the seat stays connect to the top tube. That's likely just me though.
I like the Fuji color better.
Frames look to be of different sizes based on headtube size - Fuji looks to be maybe a 23"/58cm or 24"/61cm, and the Schwinn a 25"/63cm??? The Schwinn is double-butted Columbus Tenax, and the Fuji is quad-butted VALite. Drivetrain components are Shimano on the Schwinn, SunTour on the Fuji. The Schwinn does have a mid-for braze-on for rack, and the Fuji does not. With similar frame sizes, they weigh about the same at 24 pounds (for 23"/58cm).
Fuji specs: https://www.classicfuji.com/1984_12_T...iesIV_Page.htm
Schwinn specs: https://bikecatalogs.org/SCHWINN/1986...1986Ltwt31.JPG
To-MAY-toe, To-MAH-toe. I'm a Fuji guy, so I lean that way. BUT get whichever one fits you best!!!
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Looks like both have adequate clearance for fenders front and rear but be sure that is the case if you also plan to use fatter tires than come on either bike. Check for tire clearance between the chainstays, as well. Many '80s bikes were pretty tight in there.
Bikes: '68 Raleigh Suberbe, '92 (German) Centurion Equipe, '85 Schwinn Peloton, 1983ish Zunow Road Racer project, '69 Squanch Super Tourer, 1980 Bianchi Super Corsa, '82 Austro-Daimler Vent Noir, '89 Miyata 914 project, 1982ish Bianchi Rallye
Quoted: 294 Post(s)
Liked 9 Times
Gotta go with the one with the spare spoke holder on the chainstay - - Fuji! So cool.
But I have a slightly earlier Voyageur and it's a great bike too.
Go for the better fit.
Quoted: 377 Post(s)
Liked 14 Times
The Schwinn's rear appears to be 40H with a 36H front. This is supposed to make for a stronger rear but if you biff a rim it might be harder to find a replacement. I've sold both bikes and test-ridden both but never for a significant distance and I would eagerly grab either but would probably prefer the Fuji.
Quoted: 1119 Post(s)
Liked 2,255 Times
My 1984 Fuji Touring Series IV also has a 40 rear, 36 front.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Fuji, you get a funked in Brooks Pro and those bikes have a great rep AND you get to tear off the foam crap and put new tape on it, cmon!
That Voyageur is a 1989. I just sold one last weekend. Nice bike. Shimano light action derailleurs.
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
Quoted: 4512 Post(s)
Liked 6,386 Times
And both have rear rack mounts albeit different ones, plus the Schwinn has 3! bottle mounts. Never had a C+V Fuji, but have always been a fan and have 2 newer ones right now, great bikes but gotta vote for the Schwinn in this case.
That Fuji is classy!
Member at Large
Quoted: 49 Post(s)
Dang! Quite the debate. I can't wait to try them both. And I'll try not to take them both home with me. That would not go over too well.
Quoted: 1627 Post(s)
Liked 630 Times
The Fuji looks like it's been upgraded to a more modern wheel set. I don't think that bike originally came with dark anodized rims. Maybe a 700c size (?), which arguably gets you a better selection of tire choices. Better saddle, too, if you like a Brooks. (I know I do)
I found the Schwinn on CL, but not the Fuji; got link for more pix?
Member at Large
Quoted: 49 Post(s)
Fuji main triangle is actually chro-mo
Member at Large
Quoted: 49 Post(s)
Quoted: 294 Post(s)
Liked 9 Times
Member at Large
Quoted: 49 Post(s)
The Fuji is way cooler. Riding the Schwinn in a couple hours; Fuji tomorrow morning. Will keep you posted.
Pedal to the medal
eagerly awaiting your ride impressions
Liked 630 Times
Those bikes are both pretty cool, and both are on my list. Let me know which one you DON'T buy, then I'll start scooping.
