New Chain Lubricant
Quoted: 167 Post(s)
Liked 11 Times
New Chain Lubricant
I have been using White Lightning to lubricate my chain. This past week I decided it was time to spread some of my bike funds around to another LBS so, I bought some Finish Line lubricant based on their recommendation. The difference is like night and day, I really like the Finish Line product.
Time for a change.
Liked 5 Times
Chain lubes are as Varied as types of Pie. Some are good and some not so but it is down to personal choice. I have never used White Lightning and my favourite is Pedro's. Mainly because it is the one that is readily available in the UK at most good bike shops.
Spike Milligan
Spike Milligan
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,173 Times
The night and day difference with Finish Line is when you have to keep cleaning the chain and wiping off the dirt with a cleaner, degreaser, or new lube with a rag. The lube quickly turns black and filed with dirt and chain wear. White Lightning is clean and easy to use. The chief downside is you have to apply it frequently (every 100-200 miles). But you can leave the bike alone for a long time.
Really Old Senior Member
Poster FBinNY, in the Mechanics forum sells Chain-L.
Really quieted things down on my bike.
https://www.chain-l.com/
Trek 500 Kid
Quoted: 2904 Post(s)
Liked 382 Times
Starrett micrometer lube has worked for me since about 1980 or so. It's thinner than silicones and I figure it gets where it needs to in bicycle chains and it doesn't attract dirt like WD40. If I run out then I'll use some generic silicone.
Liked 6 Times
Interesting thought, you actually lubricate your chain.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
Palmer
Quoted: 1665 Post(s)
Liked 1,818 Times
Chain lube is the 'religion' of bicycling: fanatical impassioned faith backed up by well reasoned arguments and mysticism. Polite, thoughtful folks generally steer clear of internet chain lube threads.
Fun fact: One of the oldest continually produced things you can buy is 3-in-One Multipurpose oil. It debuted as a bicycle chain cleaner/lubricant/rust preventer (three uses in one product, hence the name) in 1894 - just a few years after bikes first got chains.
Trek 500 Kid
Liked 382 Times
Here's something from the thread on Parrafin Chain Lubing (which I've never tried myself yet), that is more appropriate for this thread, concerning WD40 that I found in a clock collectors forum
excerpted from the bottom of the page:
"The problem with WD-40 is that once the solvent evaporates it leaves behind a residual coating of grease"
(end of excerpt)
That is going to collect grit and grime I might add. Using WD40 on micrometers is also a no-no.
Generic silicone is readily available at any auto parts store and seems to me to do just fine on bicycle chains.(I don't use it on micrometers) They have a more expensive version for chainsaws that someone in the other thread uses.
Bikes: Colnago EP with Campy chorus
Quoted: 23 Post(s)
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
Wax base lubes don't last as long as petro based lubes but wax stays cleaner to the touch, so it depends if you want long lasting protection or just one or two rides protection.
Finish Line changed their ingredients in the Teflon Plus Dry and I will no longer buy it, it use to last about 250 miles and now it lasts only about 75 to 100 miles, not sure what they did to it but I won't be buying it.
I like Chain L but it's expensive, I'm now trying ProGold Extreme, not sure what to think of it yet.
Procrastinateur supreme
My only complaint with White Lightning Dry is that I feel most of it doesn't penetrate my close tolerance chain, no matter how much I try to keep the slurry suspended... but then, I'm not getting any chain stretching lately so it must be working. I don't want to go back to a lubricant that picks up grit now that I am a fair-weather cyclist. Used to use DrySlide moly lubricant - very slick and good in weather, but what a mess.
Hmmmmm.... that got me to thinking - could one use an ultrasonic cleaner to lube a chain to ensure that the lube gets everywhere it needs to in the rollers/bushings? Any reason not to? I'm thinking I might try it with the new chains I just got for my road bikes. Clean the new chains in the ultrasonic cleaner using a degreasing solution. Change ultrasonic reservoir solution to something like Break Free CLP or Clenzoil to lube chain. Wipe excess lube off chain. Install new chain.
Was using White Lightning Wet lube, only it didn't last long. A couple of rides and chain noise started increasing.
I've switched back to tri-flow in a squeeze bottle. Seems to last longer with less chain noise.
As a kid, I used to use 3 in 1 oil for anything that squeaked, including bicycle chains. Anyone know how this oil compares to current chain lubes?
For such a small bottle, chain lube is another product that seems overly expensive. There must be a less expensive option.
Liked 253 Times
Pedals, Paddles and Poles
Bikes: Santa Cruz Tallboy, Ridley Noah, Scott Spark 20
Quoted: 1233 Post(s)
Liked 69 Times
I've used all of the above and also Dumont Tech Light. Work well for me. But the recent thread about waxing the chain has caught my curiosity.
I think its disgusting and terrible how people treat Lance Armstrong, especially after winning 7 Tour de France Titles while on drugs!
I can't even find my bike when I'm on drugs. -Willie N.
Quoted: 167 Post(s)
Liked 11 Times
Boy was I wrong. Today I needed to change the battery in cadence sensor on the bike and my hands were black from rubbing against the chain. Needless to say I am not pleased with the recommendation by the LBS (as some have also mentioned here).
I put the bike on my car rack, ran the chain through a rag for several minutes and saturated the chain with my remaining White Lightening. My driveway looks like my car had an oil leak.
Liked 253 Times
ProGold Extreme, Rock-N-Roll Gold and dry, Chain L, and Squirt, all run clean to the touch for about the first 120 miles then gets dirty, so you have to wipe it down after every ride to maintain some degree of clean and then do a complete cleaning about every 200 miles and reapply the lube.
Bikes: 20" Folder, Road Bike
E-pray Wolf's chain lube. Cheap and works very well IMO.
rgds, sreten.
I slap on a load of WD40 from the inside and wipe
off most of it along with the black stuff it frees up.
Then sparingly oil inside with the Wolf's, about 1CC.
I've found a small 5ml plastic dropper bottle very useful.
Half fill it with WD40 and then dump in all on the chain.
Wipe the chain down, fill with 1cc of lube, lube the chain.
Quoted: 41 Post(s)
Chain? Hmmm...how about something made for chains under high speed and high stress. It is cheap and readily available. Chain Saw oil from the local hardware store. Last gallon I bought was something like five bucks.
Liked 253 Times
Hi,
rgds, sreten.
rgds, sreten.
Seat Sniffer
Quoted: 945 Post(s)
Liked 1,985 Times
Cripes. At one point or another, I've used:
White Lightning
Finish Line Dry
Finish Line Wet
Pedros
Tri-Flo
Kinda reminds me of my days as a lad, when I'd go ga-ga over one breakfast cereal over another, and like the fickle snot I was, decide, overnight that I didn't like it anymore. Used to drive my mother flippin nuts.
I'm currently ga-ga over White Lightning. It doesn't last as long as the other lubes (200 miles or so ... although I used it on a recent triple century with no problems), but the chain stays a heck of a lot cleaner. Not that that really matters all that much ... but it looks nice.
Thinking of doing the waxing thing too. Maybe I'll wax my legs while I'm at it.
White Lightning
Finish Line Dry
Finish Line Wet
Pedros
Tri-Flo
Liked 253 Times
Crap, I've been spraying my legs with TriFlow and waxing my chain, I knew something wasn't right.
Bikes: TREK 7200 Hybrid
I've been using rock n roll. I try to clean and lube every 100 miles or so, so I guess maybe I'm lubing more often than required? What say you about rock n roll and 100 miles? Thanks
