Mystery 70+ Garage Flat (this is a NON-Helmet Thread) - Your Prediction?
Liked 12 Times
So, I walk out to ride the mtn bike to the mailbox, and . . . garage flat. I won't even mention whether or not I was going to wear a helmet for the .1 mile ride.
So, I inspect the outside of the near-new Vittoria 1x1.75 semi-slick tire very closely and see nothing suspicious. OK, I take the wheel off, and pump to 60 lbs and give it the bathtub treatment, wanting to get a bit closer fix on where the cause might be - fully cognizant that the bubbles can come out in a very different place than the puncture. I rotate the fully covered with water tire and rim and Schrader valve very slowly - and NO BUBBLES. I continue doing this for many minutes (yes,I am persistent) and still no bubbles.
So, I leave the wheel/tire sitting out for several hours and it is still rock hard. I plan to leave it out all night.
So - your prediction
Will it be flat in the morning or still pumped to 60 lbs?
And, your guess as to the cause. I am suspecting an intermittently defective Shrader valve at the moment.
And, I did NOT wear my helmet while typing this post.
And the 70+ bit in the title? I haven't a clue, my hands just type that way
you didn't have anything concealed when you were working on it did you ?
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I've had a garage flat recently on the rear tire of my Masi, a Vittoria Open Corsa Evo SC. I'd ridden it the day before and it showed no sign of low pressure (that I noticed). I pulled the tube and found no obvious leak, so I pumped it up for a ride the next day. Next day it was flat again. So I rode a different bike, and later pulled the tube and did the water bucket thing. It did have a leak but a very, very, very, very, very tiny one. That's not enough very's. I had to pump the tube a lot so that it blew up like a balloon. Then I searched the tire and found a tiny curved thorn-like pointed object sticking through the tire, no more than half a millimeter long if that much, and much thinner. Perhaps it was organic in origin or perhaps it was a piece of wire. I'm not sure I would have seen the leak if I'd dunked the entire wheel.
Real cyclists use toe clips.
jimmuller
jimmuller
Liked 12 Times
I was just hoping . . . !
sorry this thread was moved like yours recently also after the trolls started there stuff
it ended up being a concealed firearm argument
https://www.bikeforums.net/showthread...4#post15832864
Quoted: 1572 Post(s)
Liked 643 Times
My prediction is your tire will be fully inflated when you check it. It won't lose it's air until you get all the way down to your mail box. Then you'll have to walk back.
Liked 12 Times
To further explain, I only have 7 bikes in the garage. But, my Lemond requires clipless, and I was wearing Crocs. My Utility Road Bike was hanging and needed air. My wifes Mtn Bike was also hanging and air less. I had 2 Worksman tricycles for Andy, but my weight would crush them. So, I took my wife's hybrid to the mailbox.
Could this have contributed to the problem?
Momento mori, amor fati.
Liked 645 Times
In desperation, I rode my wife's bike. No way I am walking to the mailbox
jimmuller
jimmuller
Liked 12 Times
Speaking of concealed carry....as I had a cardiology appointment today, I carried about three months of Bicycling magazine to read. In a maintenance tip column, they mentioned that if you keep a bicycle out in the garage and the tiyers sit directly on concrete, the moisture in the concrete can contribute to degradation of the tiyers. They said if you must, at least have a layer of cardboard between the tiyers and the concrete.
ES&D
Bikes: 3Rensho, Merlin XL, Melton custom, Michael Johnson tandem, Look 481SL, Pedal Force RS
Leak at the stem base.
Time for a change.
Liked 5 Times
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
Liked 12 Times
UPDATE
6:00 am - the tire is fully inflated. BTW, the tube is almost new, also. I did jiggle the valve stem a bit to see if it was the stem base, but did not remove the tube to really check. I think I will just put it back on and ride. In any event, it seems a slow leak (if any), and if it leaks again, I can likely get home just by pumping it up. (Famous last words!!)
I'm still betting on an intermittently defective Schrader valve core, and I will be sure the current one is tight.
Rolling along
Well, when had it last been aired, do you sleepwalk?
As it's a schrader, and there's an if, I'd pop out the valve stem oil it and re-install
Bikes: 1997 Specialized M2Pro
Liked 12 Times
And I really appreciate the info.
UPDATE 2
I pumped the tire this morning, and I do believe that I lost about 10 pounds overnight - from 60 to 50. It is still rock hard, of course, but has lost a bit of pressure.
So, I will go the next steps and pull the tube, etc., etc., etc.
UPDATE 2
