Horrific foot cramps after taking shoes off, and general food pain while riding.
Quoted: 28 Post(s)
So, yesterday I rode 47 miles and after taking off my shoes I got horrible, horrible foot cramps. So much as moving my toes in any direction made me swear at the top of my lungs.
What could cause this? Bad shoe fit?
I have Sidi road shoes with Superfeet Yellow inserts. Pedals are Shimano SPD-SL. The insoles improved my previous arch pain somewhat, but now I have more forefoot pain while riding.
Is there some way to make these shoes more comfortable? Thinner socks to reduce food swelling? Wedges? Cleat adjustment?
Do I need to try another brand of shoes? Specialized? Shimano?
Quoted: 5788 Post(s)
Liked 2,580 Times
This happens. I get it from time to time both after riding and sometimes just waking up in the morning, and every once in a while from touching the bottom one against the other when they're cold.
I suspect that one contributing factor might be the extremely rigid soles on decent cycling shoes. They hold the foot immobilized, vs. the normal constant flexing feet are used to. That and maybe a drop in your potassium levels, or whatever.
I don't know if some people are more prone to this than others, but it's not anything except painful for a short while (yes, very painful), then it passes and all is back to normal. So I just consider it one of those things that I live with (and I don't let my feet touch each other when cold).
BTW- I sometimes would get the same cramp on very long rides, and found the best remedy was to take off my shoes and walk barefoot a hundred yards or so.
FB
Chain-L site
FB
Chain-L site
Bikes: 2015 Spec Roubaix Expert, 2016 Spec Diverge Expert X1, 2018 Allez Sprint eTap
Quoted: 63 Post(s)
I'm by no means an expert, but Do you tend to keep your feet fairly flat as you're pedalling or do you tend to point down, therefore increasing pressure on your toes?
I initially was doing the latter, which gave me pain in my toes after longer rides. I then made a conscious effort to switch to the former and, tada! Toes pain was gone
Since then, I developed some pain on the out side of my right foot on rides longer than 50 miles, but I believe I have now fixed it with the proper shoe insert (I have the Specialized S-Works shoes with mid-arch inserts)
hope this helps at all...
Geoff
Geoff
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
make sure you aren't over tightening your shoes.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,179 Times
Just a guess but do you have high arches?
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
I experience this. I even experience this when I'm not cycling.
For me, it helps to drink lots.
Yeah, I know, the jury is out when it comes to what causes cramping ... but from my experience, there's a direct link between not drinking enough and having my feet cramp.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 28 Post(s)
Liked 2,580 Times
I read this and had a quick laugh. Then I realized you meant water.
FB
Chain-L site
FB
Chain-L site
Quoted: 28 Post(s)
I would say medium. I tried green BG foodbets (for high arches) and simply putting the shoes on was excruciating. Cycling with those insoles was a non-starter.
That said I could have used a bit more arch support than the Yellows give.
Quoted: 28 Post(s)
I made an effort to drink plenty but it was pretty hot out and I ended up drinking something like... six liters of sports drink.
Quoted: 28 Post(s)
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
drink lots, and from my experience, water isn't enough.
Nuun has eliminated all of my cramping issues, and they used to be a major problem.
Quoted: 28 Post(s)
Geoff
Geoff
Successful alcoholic
Quoted: 21 Post(s)
Superfeet insoles and narrow, low volume Sidi shoes, combined with high arches, are a recipe for foot problems. I have high arches and narrow feet. At one time I was a professional skier, and had (have) several pairs of custom footbeds for my ski boots. Moving them to my cycling shoes was a big mistake. After taking them out of my Sidis and Northwaves, my feet stopped the cramping you describe.
Quoted: 28 Post(s)
Try Nuun.
It has worked wonders for me.
Also sip it regularly. If you crush a bunch of fluid, instead of sipping constantly, the fluid doesn't absorb like it should.
Quoted: 28 Post(s)
Foot cramps might be caused by fit, but it could also be a hydration issue.
Hydration issues are easy and cheap to fix. I'd try that first.
My recommendation may not help, but it won't cost much to try.
Foot cramps are usually a fit issue, but I'd look into a cheap fix first. If it doesn't work you aren't out much $$$.
Administrator
Liked 2,179 Times
People's feet need to move some when they press down, even with cycling. It's the body's normal movement and the way it dissipates the force of its weight. So if they are trying to move but are held in place, muscles rebel
Quoted: 741 Post(s)
Liked 412 Times
I have the Vents. I have found that the shoes fit very snug, even without the straps fastened. It is very easy to over tighten the straps. I use the straps to remove excess volume in the shoe, not to keep my foot from moving. That has seemed to help me.
Quoted: 63 Post(s)
geoff
Quoted: 28 Post(s)
GATC
She does also have higher arches.
Bikes: 2014 Cannondale Supersix EVO 3, 2015 Trek 520, 2017 Bike Friday Pocket Rocket, 2022 Moots Vamoots Disc RSL
Quoted: 285 Post(s)
Liked 267 Times
Ok. Are your feet cramping with spasms or do the arches and toes just intensely hurt? i have had the same issues but with no muscle cramps (spasms).
there are a few thing I have done that have helped me
1. Calf, foot and hamstring stretching everyday-- even on rest days. This helps a LOT.
2. Hydration and electrolyte replacement, as many have previously said.
3. Make sure the shoes are not too tight.
4. Add a little arch cookie under your arch, but not too high. You'd be surprised how only 1/8" can make a big difference. If it feels too high, try 1/16". It is possible that any addition may be too much, so you'll have to experiment with that. If your calf muscles are very tight, any addition to your arch height can be very sensitive. It's a bio mechanical thing that would take a long time to explain.
5. Are you bow legged? If so, that means your lower legs are pointing slightly in to the midline of the bike, instead of straight down. I placed a screw washer on the screw closest to the big toe side of my cleats. This caused my shoes (and feet) to be slightly tilted in toward the midline of the bike. Basically it was an external tilt to the shoes rather than a shoe insert with a medial wedge. Caution: I would do this last. I did this, and it helped my foot pain. But it made my Ilio-tibial band syndrome worse. If you try this, do a real short side first, then gradually increase your rides.
Good luck!
Good luck!
