What are these brake things?
Bikes: 1977 Trek
Quoted: 34 Post(s)
Liked 22 Times
The triangular things attached to the outside of the shoes. Googling around it seems they might be exclusive to Dia Compe. What are they called and what is their purpose?
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
They are wheel guides They are to aid in getting the wheel in faster when changing a flat wheel out in a race
Most upper end brakes have them but a lot Dia Compe models didn't have them attached to the holder, like CampI and Shipmano
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Quoted: 1607 Post(s)
Liked 2,216 Times
ts99 Guides the tire/wheel between the pads while inserting the wheel into the drop outs. That way you don't have to pay too much attention to the tire hitting the pad or other spot outside of the slot between the pads
P1010557, on Flickr
P1010557, on Flickr
Bianchi Goddess
Liked 2,923 Times
^ My favorite brake.
Bikes: 2018 Specialized Crave, 2018 Fuji Tahoe, 1989? Nishiki International, SOLD Miyata 712, SOLD Stumpjumpers- several, SOLD Specialized Sirrus, SOLD Raleigh Technium, SOLD Lemond Zurich...
Quoted: 29 Post(s)
Liked 20 Times
What kind of brake caliper is that? Window on the side to allow for a wider arm, nice....
Quoted: 4806 Post(s)
Liked 3,928 Times
In a race, doing a fast wheel change, they might make a second or two difference. That second or two might be the difference between getting back into the peloton after a flat and not making. So nuisance items for most of us but could be Tour de France deciding.
Quoted: 1639 Post(s)
Liked 829 Times
Uhmmm........I don't think caliper wheel guides are in the same category as reflectors, turkey levers and "dork discs"......
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Liked 2,216 Times
Quoted: 4722 Post(s)
Liked 3,036 Times
Nobody in my region removed them. They were considered a status symbol, as they were an indicator of a higher grade bicycle or at least a higher grade brakeset. Eventually, their status diminished as the feature trickled down to lower grade brakesets.
Likes For T-Mar:
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
I think you'll find that the inner side of the Dia-Compe caliper is slotted for the wheel guide. If you leave them out the brake shoe won't tighten properly- it doesn't have enough surface area to hold it in place.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
They also come in very handy when making brake adjustments.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Wheel Guides
Better bikes didn't have suicide levers and rarely dork disks or reflectors either.
The cool thing was to remove the dust caps on the cranks.
Campy Monplaner brakes are beautifully sculpted and stop very well! Really beefy too. I have them on several bikes plus a couple of sets in a drawer.
The original brake blocks had rounded ends. Someone used standard Campy NR carriers and pads on this set.
Rounded ends, sometimes gray pads.
.... and yes they do help getting a wheel in quickly.
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Liked 2,216 Times
Yeah and why not use the pad/mount itself instead of a leveraged appendix?
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Using them as landings for a third hand tool instead of positioning the tool on the pad nuts. If you have used one of these tools, you know that you first anchor the far end and then pull toward you to spread the spring to anchor it on the inside pad. The pulling force is a bit too much for the thin guides, it seems. I made a mental note to not use the guides this way again.
Quoted: 4560 Post(s)
Liked 2,802 Times
Those non-aero doodads cost me a time trial podium spot.
Well, that and my puny 200 Watt output.
Quoted: 1079 Post(s)
Liked 1,899 Times
Where the ones in your pics came with rounded blocks which did away with the plastic wrap. However, I'm sure there were overlaps and leftovers and swaps and and and...
...great brakes though.
verktyg
Liked 1,238 Times
Campy Mono-Planar Brakes
My understanding is the 1st gen Monoplaners with the not quite so beefy arms came with square blocks which had a white (and black?) plastic wrapping on the wheel guides:
The 1991 Chorus Mono-Planar brakes had rounded blocks and no covering on the wheel guides.
I've never heard about any complaints or differences in the mono-planar calipers. All the ones that I have are the same.
Could be someone have confused the 1990 Athena single pivot brakes with mono-planars??? They look similar.
I've seen some mono-planars on eBay that had a flat non-anodized finish from lower level gruppos. They looked cheap.
BTW, I've never seen the steel Campy brake pad holder bend while being used to adjust the brakes. They're pretty strong. The aluminum carriers that were used on SR brakes, now they bend and break easily.
verktyg
Chas. ;-)
Chas. ;-)
Liked 1,899 Times
I couldn’t get my 1st gen Monoplaners to stop squealing, so I ended up replicating toe-in by cutting the pad at an angle. Didn’t have that problem with the fatter arm version, but there are a few variables I didn’t do a thorough experiment with.
