Teach me: Schwinn Paramount PDG OS 26
Bikes: '14 Cannondale CAADX
Quoted: 8 Post(s)
Liked 5 Times
Teach me on value of a Paramount Schwinn on 650x23 wheels/tires
White paint (has multiple scratches, scuffs etc - this is the one to ride, not hang on display)
Shimano 600 Tricolor hubs/Mavic wheels
Shimano 600 indexed downtube shifters
Shimano 600 Tricolor front (2x)
Shimano 105 rear
Shimano 600 rim brakes
Toptube internal cable routing
Campagnolo headset
2x8 set up
Missing: tires and tubes, brake levers, saddle.
Shimano 105 rear
Campagnolo headset
2x8 set up
Need to see pictures. (A Paramount with 650x23 wheels & tires sounds like a XS or junior sized racer).
Quoted: 8 Post(s)
Liked 5 Times
Top tube is 22 inches center to center. Could not locate the serial number. The license number on the seat tube sticker says T 002381. Its a 2x8 speed. I removed some of the parts to clean up.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
try to slip a set of 700c wheels on there --- there is an odd amount of clearance at the bottom bracket and fork on that one
There were plenty of full size bikes made with 650c wheels but they were generally marketed towards the tri crowd
You might want to contact Rechard Schwinn at Waterford. There dont seem to be any tiged OS Paramounts in the catalouges. I wonder if ita a Paramount or sompthing else
Quoted: 8 Post(s)
Liked 5 Times
https://www.worthpoint.com/worthoped...s-26-650-tires
Quoted: 2363 Post(s)
Liked 1,749 Times
The 1992 catalog references a Series 7 model with 26" (571) wheels, 28-hole front, and a 56-tooth large chainring.
Quoted: 2323 Post(s)
Liked 4,990 Times
Hmm....So. at the same time Panasonic was making a set of lugged steel frames for Schwinn to validate they could make something worthy of the Paramount name there were also a set of white tig'ed ones done.
I just don't remember all the details or if this is one of those.
It is Tange so it wouldn't surprise me if it was.
Steel is real...and comfy.
Liked 4,990 Times
Oh, and another note from Scooper. Waterford didn't do unicrown forks on the PDG bikes they made, Panasonic did.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,405 Times
One of these passed through The Lab about ten years ago. If I recall correctly, this was not made by Panasonic, but was an earlier PDG frame experiment manufactured in Taiwan or China. No lugs.
Note that the top tube says 'Series' but there is no series number, unlike the later lugged PDG frames. The fork had a Tange label on it but don't remember if the frame tubing was identified.
This particular bike came to me with Shimano 1055 7 speed components with upgraded Dura Ace hubs and an absurdly small 8 speed cassette. The 7 speed DT shifters worked across the 8 speed cassette pretty well, with the lower limit screw acting as the backstop for the final shift to the largest cog.
Pretty sure I sold this to a woman in DC; even though it was a 57cm frame, the 650 wheels brought the height down enough that it fit her.
Liked 4,990 Times
Here's the breakdown on the numbered PDG Series bikes.
PDG Bikes
Here's the actual catalogs.
Catalog Scans
Liked 4,990 Times
The lugged ones look like this.
One of my favorites, it's a great ride.
Notice like the one you have there is no PDG Series number. All the normal production ones has a number associated with them. Somewhere I've posted Richard Schwinn's comments on these pre-production models but I can't find it right now.
Liked 1,749 Times
Takeshi , looks like your small-wheel series should indeed get a 56-tooth chainring, which makes sense wrt. gearing and wheel diameter.
And YES, it's definitely worth re-animating it.
Liked 4,990 Times
Quoted: 8 Post(s)
Liked 5 Times
Slowly but surely it came together.
Shimano 600 hubs/Mavic rims
Shimano 105 rear/600 front derailleur
Shimano 105 indexed shifters
Campagnolo headset
Prologo Kappa saddle
2x7 gears
650c x 23 tires
New tires
New tubes
New cables/cable housings
New chain
New bar tape
Campagnolo headset
2x7 gears
650c x 23 tires
New tires
New tubes
New chain
New bar tape
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
I believe that some P's did come with 650c's.
https://forums.roadbikereview.com/ot...ls-161946.html
I see you posted the same link
Op's bike looks great!
Ben
Takeshi
